2011 which harness to purchase
Discussion in 'Towing' started by treadway47025, Dec 11, 2011.
  1. Dec 11, 2011 at 6:05 AM
    treadway47025
    treadway47025 [OP] Well-Known Member
    INDIANA
    2011 access cab 4cyl 5spd 4x4
    Fog lights, LCE Header
    I just purchased a new leftover 2011 access cab 4x4 4cyl 5spd tacoma. My question to you guys/gals out there is which oem wiring harness should I buy. They sell a 4 pin for trucks without tow package and a 7 pin. Both oem toyota harnesses and some sort of black box. Found both in the oem toyota parts sites and ebay. The 4pin would probally be ok, but will the 7 pin work on the 4cyl truck?
  2. Dec 11, 2011 at 7:44 AM
    treadway47025
    INDIANA
    Should I get the 4 pin harness or the 7 pin harness?
  3. Dec 11, 2011 at 8:11 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    What are you going to pull?
  4. Dec 11, 2011 at 9:08 AM
    treadway47025
    INDIANA
    Mainly a 74" x10' alum utility trailer with a polaris rzr on it. Firewood. general use like getting supplies for building this and that around the house from the hardware store. The trailer has a 4way plug on it. Didnt know if the 7pin harness would even work on my truck. I have 7 pin to 4 pin adpater plugs laying around. Having the 7 could be nice at times. I have a fullsize silverado as well but maybe selling it in the near future.
  5. Dec 11, 2011 at 1:57 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    If your trailer has a four - that's what I'd go with.
    I assume you haven't installed an electric brake controller.
  6. Dec 13, 2011 at 1:32 PM
    treadway47025
    INDIANA
    no controller. I decided and went with the 4pin. Thanks to all
  7. Dec 14, 2011 at 8:06 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I know this is a little too late but I had a similar setup on my first Tacoma and the 4pin was all I ever needed.
    You should be absolutely fine that way.
  8. Dec 14, 2011 at 8:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If cost isn't a concern, I'd get the 7-pin. You can always 'dumb down' a 7-pin to a 4-pin with the adapter, but you can't go the other way. Personally, I went with a 4-pin because it was a very simple install and I do not have the need for a 7-pin.
