Do I have brake flanges on my trailer?
Discussion in 'Towing' started by bawilson21, Jan 9, 2014.
  1. Jan 9, 2014 at 3:51 PM
    bawilson21
    bawilson21 [OP] Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    I'm trying to put brakes on my trailer in preparation for a cross country haul across the Rockies in winter. I'll be towing with my rather light 1st gen Tacoma so I'll need some additional stopping power. I cant tell if there are brake flanges on my trailer though so I was hoping to get an opinion from someone who has dealt with trailer axles in the past. Does my trailer have brake flanges already mounted on it? I was thinking it would be more square shaped but I could be wrong.
    My trailer is a 10x6 Cargo trailer with a 3500lb axle with a GVWR of 2990lbs. Would adding brakes increase the GVWR to 3500lbs?
  2. Jan 9, 2014 at 6:04 PM
    BillJC
    BillJC Well-Known Member
    Bill
    Novato, CA
    2011 White SR5 DCLB 4x4
    No you don't. Adding brakes will no increase the capacity. Changing the axle will. In order to add brakes, you will need an axle with flanges. If you are looking to add brakes, you would be better off just changing the whole axle and get one loaded with brakes.
  3. Jan 9, 2014 at 6:08 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    to increase the capacity, in addition to a stronger axle with brakes, he would also have to upgrade the springs to the proper rating, and then verify that the frame and floor of the trailer are sufficient enough to take an increased load.
  4. Jan 9, 2014 at 6:26 PM
    BillJC
    Bill
    Novato, CA
    Absolutely. I would always get new springs when changing axles. However, if it's a single axle, you may overload the frame if you up the capacity. Most single axle trailers aren't built with much more than 1/8" to 3/16"angle iron.
  5. Jan 9, 2014 at 6:36 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    The trailer mfr wouldn't downrate the GVWR for the lack of brakes. Whether brakes are required by law is different from state to state. The trailer is already weaker than the existing axle. Adding brakes wouldn't increase the trailer's GVWR, but will make your drive more pleasant.
  6. Jan 9, 2014 at 6:44 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    exactly, hence the last part of the sentance. when i rebuilt my trailer (granted the extra strength needed was for off roading purposes, not load capacity), it got a stronger axle, beefier suspension, frame gussetting, and an entirely new tongue.
  7. Jan 9, 2014 at 8:18 PM
    BillJC
    Bill
    Novato, CA
    Any pics of the trailer? I've been getting plans together for building my own 6x10 utility single axle. I wanted to over-build somewhat and use a 6K axle so I don't have to worry about capacity.
  8. Jan 9, 2014 at 9:51 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Plenty of pictures. it may not be your best refference though, as it is build purely for offroading. i pull it on the street to and from wheeling, but that's about all of the pavement time it sees. the link geometry is dialed in perfect, but the springs and shocks are a temporary solution because i had to get the trailer up and running quick. they will be coming out and replaced with a full coilover as soon as i have the time. probably kings.
  9. Jan 13, 2014 at 2:18 PM
    bawilson21
    Bryan
    WA
    Thanks everyone. I'll probably take the trailer to a fabrication shop to have the flanges welded on... that or buy a new axle.
  10. Jan 13, 2014 at 2:24 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Please stop!
    You are wasting your time getting flages welded on this axle. You can buy the entire axle for less than $250 and do it yourself.
    I buld and sell trailers and I get this ? asked all the time. It is much more cost effective to get a new axle with the brakes already installed.
    Hope this helps.
    KO
  11. Jan 13, 2014 at 2:28 PM
    koditten
    Kirk
    Central Michigan
    Bill:
    I see you want to build your own trailer. Good on you.
    I have an example of the trailers I build over in the for sale section. If it is something you like, I have a complete build thread over on another forum.
    I spend a lot of time on the Garage Journal site. If you search the same name over there you can find my build thread by searching threads started by koditten. You may have to become a member to see the pics.
    Later
    KO
  12. Jan 13, 2014 at 6:10 PM
    bawilson21
    Bryan
    WA
    new axle for under $250...is that with brakes installed on the axle? I'm thinking I can get the flanges for $14 and welded on for another $60. Then that would leave the price of brakes/hubs/wiring which will be around $225? I'm not sure where I could purchase a new axle locally as I live in a small town right now. Factor in gas or shipping to purchase and it puts me close to the price of a new axle. But I will do some more research around my area to purchase a new axle. Maybe theres a place I'm not aware of that sells them.
  13. Jan 14, 2014 at 4:04 AM
    koditten
    Kirk
    Central Michigan
    $140 for a set of brakes and drums, I don't know what the backing plates go for, 75 bucks for the welder to put on the flanges, it adds up.
    Get a new axle and sell the old one.
