Transmission Max Temp - Toyota Answers
Discussion in 'Towing' started by ttubb, May 29, 2013.
  1. May 29, 2013 at 4:32 PM
    ttubb
    ttubb [OP] Member
    Terry
    Tucson/Crested Butte
    Tacoma TRD Off Road 4WD
    I recently asked Toyota for the number that turns on the A/T High Temp light on my 2013 V-6 Tacoma with the tow package. I have a Scan Gauge and I have seen as high as 230 on the Trans Temp so I was curious. Here is the answer:
    Dear Terry Tubb,
    Thank you for your follow-up email.
    We apologize that the Owner's Manual does not include the temperature in which the automatic transmission oil light will illuminate in your 2013 Tacoma.
    If you are towing with your vehicle, the automatic transmission oil temperature light may illuminate at 302 degrees. If the light comes on, it indicates that the auto transmission fluid temperature is too high. If the light flashes, it indicates a malfunction in the auto transmission system.
    For further evaluation, information and assistance, we recommend you contact your local Toyota dealership.
    Regards,
    Kym Strong
    Toyota Customer Experience
    Now we know.
  2. Jun 1, 2013 at 3:23 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    300 plus sounds very high. The fluid should run around 165 normal driving. Towing up to 220. When you get above 220 you start shortening the life of the transmission fluid, some claim as much as by 50%.
    Personally I would add another cooler that was big enough to keep it under 200 even under heavy towing conditions.
    Here is an article you might want to look at. Even though this is not about a Toyota it does not change the facts about the fluid and the transmission.
    http://www.roscommonequipmentcenter.com/news_notes/nn15.pdf
    http://waynestransmissions.com/2010/07/20/the-secret-to-extended-automatic-transmission-life/
  3. Nov 11, 2013 at 2:04 PM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Thanks for the info! I'm driving froma Alaska and was curious on when the light turns on. I got up to 240 in 20 degree weather. 300 def sounds high. I pulled over when I'm driving over 200 to let the tranny rest. Thanks again
  4. Nov 11, 2013 at 2:12 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    Holy crap..... 300!?
    That's not a warning light, that's a $5K lightbulb!
  5. Aug 23, 2018 at 9:06 PM
    tow-coma
    tow-coma Well-Known Member
    I know this is old, but thank you for gathering this info
    Running Board Man likes this.
  6. Jan 31, 2019 at 2:29 PM
    tow-coma
    It is not a sealed system. Remove the drain plug and do not remove the inner sleeve. Squirt fluid into the drain hole until it starts coming out. You are now full. There is also a temperature range this should be completed inside
  7. Mar 6, 2019 at 3:48 PM
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    Does pinning the transmission thermostat open help?
  8. Mar 19, 2019 at 7:06 PM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I didn't know that it had one
  9. Mar 25, 2019 at 12:47 PM
    GarlicDude
    GarlicDude New Member
    2012 Tacoma Dbl Cab with tow package
    I had a long conversation with a mechanic that I trust and he said that with synthetic transmission fluids are able to withstand higher temperatures without breaking down and ruining the transmission. I would definitely not want to see the 300 deg. when the light comes on, but I would think 230 deg. would be fine. I put a larger trans cooler on our 2012 Tacoma and have seen 225 degrees on the Scanguage when towing in the mountains.
    bigbear1612 likes this.
  10. Apr 9, 2019 at 9:34 PM
    tow-coma
    Yes, as long as you monitor it. These trucks want to run at 190-200F. Pinning it open in the winter can cause 120-130F constant temperatures.
    Third gen has a transmission thermostat, second gen does not. I often pin it open when towing in the Summer. It allows the fluid temperature to start lower before hills than the 195F that the thermostat opens at. But the cooler works too well im most other conditions to keep it pinned open
  11. Apr 10, 2019 at 2:56 AM
    Cnasianfire
    Charles
    Wilmington, NC
    During the winter, mine stays at 130 and it doesn't get that cold here. I have a 2nd gen
  12. Jun 1, 2019 at 1:42 PM
    bigbear1612
    Gary
    Did you have the thermo pinned?
  13. Jun 3, 2019 at 2:16 PM
    tow-coma
    He's got a 2012 so he doesn't have a transmission fluid thermostat
