ramonortiz55 4runner build: La Venenosa - For Sale!
Discussion in '4Runner Builds' started by ramonortiz55, Apr 9, 2015.
  1. Sep 16, 2017 at 8:28 PM
    #541
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Great thread GB king!
    I've a 99 3rd gen T4R with Locked center and rear riffs.
    uurx, ChadsPride and inesshell like this.
  2. Sep 16, 2017 at 8:58 PM
    #542
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    soo sexy
    GPsevinSixx[QUOTED] likes this.
  3. Oct 16, 2017 at 6:40 AM
    #543
    ramonortiz55
    Ramon
    Texas
    stock
    Installed new swingout last weekend!
  4. Oct 16, 2017 at 6:47 AM
    #544
    ChadsPride
    Sponsored by TacomaWorld.com
    Sweet build!!! :thumbsup:
    BassAckwards likes this.
  5. Oct 16, 2017 at 6:49 AM
    #545
    ramonortiz55
    Ramon
    Texas
    stock
    I think I am going to need some cables for securing the water cans @Shmellmopwho :boink:
    Shmellmopwho and ChadsPride like this.
  6. Oct 16, 2017 at 7:08 AM
    #546
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Bumper looks awesome!! Just lemme know about the cables when you figure out measurements! :thumbsup:
    ChadsPride likes this.
  7. Aug 6, 2018 at 9:00 AM
    #547
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
  8. Aug 27, 2018 at 11:58 AM
    #548
    ramonortiz55
    Ramon
    Texas
    stock
    My 4runner's shifter had too much slack for my liking. I was worried that one day I wouldn't be able to turn on the 4runner or have it release my key from the ignition. So I decided to change the shifter bushings as preventative maintenance.
    This writeup also applies for 1st generation tacomas.
    Each shifter assembly requires four bushings, here is the part number:
    Stare at the center console for 5 minutes. Give it a long mean mug stare.
    Set hand brake and grab pull out the cup holder:
    Next pull out the trim around the shifter, simply tug:
    Remove the center console. This is held down by two bolts inside the console:
    Remove the screw holding the center console to the shifter trim, one each side. This will allow the center console assembly to pull out of the way:
    Next remove the 4x4 shifter head, my particular setup is not threaded. Therefore, I remove the set screw and pull the head off carefully.
    Be very careful not to pull the wiring that leads to the 4x4 shifter (black).
    I placed it to the side, did not really disconnect the wiring because I was afraid of messing up the pigtail connection.
    Next I removed three screws that hold the shifter down to the assembly:
    Once removed, it revealed this white device thing:
    I removed the three screws that held it down. Pay attention to how it is mounted, there is a rectangular piece that goes inside of it. This needs to properly seat within a slot that is built into this device thing:
    Before continuing, I went under the truck - Driver's side, and I disconnected the shifter from the transmission. Making sure to mark the location where it is bolted along the slot:
    Once that is complete, I went back up to the shifter assembly and removed 8 of these bolts. They are located on the perimeter of the shifter panel against the floorboard:
    Disconnected a couple of plugs to allow removal of bolts:
    Had to pull the radio bezel off the dash to access one of the bolts:
    Pull away! - here you can see the location of all 8 bolt holes, for reference.
    Now that the shifter assembly is out, stare at it. Show it some attention. Give it love.
    See this nut? Remove it.
    It will release this bolt:
    The shifter bushings go in each end of the bolt housing:
    Old shifter bushings, rotted away:
    Make sure to clean out any remaining bushing pieces within the bolt housing:
    Install bushings and install bolt.
    Next, I located the other two bushings, these are in here:
    Remove nut and bolt, just like previously done:
    Once the nut and bolt is out, you will need to break the linkage as shown here. This is done by removing a C clip.
    Once the linkage is apart, I wiggled the housing up so I can pull out the old bushings:
    Installed the new ones:
    Install bolt and nut, reinstall linkage and C clip.
    Reinstall into truck:
    Reattach rod to transmission:
    Carefully assemble the white thinga-machig to the shifter. Make sure that the rectangular portion shown in the photo earlier lays within the channel:
    See this? - How does it go?
    Let's find out:
    It directly connected to the emergency shifter release button:
    Looks like it toggles when I move the button back and forth, two positions:
    Looking down into the shifter assembly I see this triangular piece of plastic. Lets set it BEHIND this piece.
    Once it is set, I check for functionality:
    See that white plastic cylinder? Its right above the screwdriver tip. Toggle the release button, this white cylinder should move in and out, if installed properly.
    Once you confirm functionality, reinstall everything else:
    How is the shifter?
    Mine is tighter than a frog's arse!
    boostedka and 05Aztacoma like this.
  9. Aug 27, 2018 at 12:03 PM
    #549
    ramonortiz55
    Ramon
    Texas
    stock
    Propane carrier:
    Tundra Brake Upgrade:
    BassAckwards, 05Aztacoma and uurx like this.
  10. Aug 27, 2018 at 12:04 PM
    #550
    ramonortiz55
    Ramon
    Texas
    stock
    happy?
  11. Aug 27, 2018 at 12:11 PM
    #551
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    ramonsitos savage culito
    05Aztacoma likes this.
  12. Aug 27, 2018 at 12:42 PM
    #552
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    Gracias perra :laugh:
  13. Aug 27, 2018 at 12:51 PM
    #553
    ramonortiz55
    Ramon
    Texas
    stock
    GET OUT
    JWaldz[QUOTED] likes this.
  14. Feb 20, 2019 at 4:14 AM
    #554
    ChadsPride
    Happy Birthday!!!! :cheers:
    Bastek likes this.
  15. Feb 20, 2019 at 8:20 AM
    #555
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Happy Birthday!!
  16. Feb 20, 2019 at 9:05 AM
    #556
    ramonortiz55
    Ramon
    Texas
    stock
    wut!? I forgot it was my bday!
  17. Feb 20, 2019 at 3:03 PM
    #557
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    Happy birthday! :bananadance:
  18. Aug 15, 2019 at 6:17 AM
    #558
    ChadsPride
    :wave:
    inesshell likes this.
  19. Aug 15, 2019 at 7:07 AM
    #559
    ramonortiz55
    Ramon
    Texas
    stock
    HAI
    ChadsPride[QUOTED] likes this.
  20. Aug 15, 2019 at 7:09 AM
    #560
    ChadsPride
    How yew bean?
