Can't Buy Supercharger Oil in California
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Sep 28, 2016.
  1. Sep 29, 2016 at 2:43 PM
    #21
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    I lived in Santa Cruz, so we were never in any real danger of having SMOG related issues and to my knowledge there is still a good deal of water there. Cali needs to be split, the desert lower can be South California which needs SMOG rules, the upper could be North California and be held to Oregon standards.
  2. Sep 29, 2016 at 2:46 PM
    #22
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Hmm I've bought em it twice in the pass few months and had no issues.
  3. Sep 29, 2016 at 2:52 PM
    #23
    eon_blue
    eon_blue [OP] Most Improved Member
    Online or in person? I haven't tried in person yet but as for online, it seems like this just recently started being prohibited. I wonder what would happen if I tried buying the Redline gear oil again that I bought a couple months ago...
    edit: just put the Redline in my cart and it allowed me to put in my shipping address which is more than I could do with the supercharger oil yesterday. Still won't let me add the supercharger oil. Weird considering they are essentially the same thing, just gear oil.
  4. Sep 29, 2016 at 3:03 PM
    #24
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    Adam
    Sacramento
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    I was in and out at TEC in like 10 minutes. Its 5 minutes from Tujunga, bet that is fastest. call first though
  5. Sep 29, 2016 at 3:04 PM
    #25
    eon_blue
    yeah I'm going there if I can't get it at the Chevy dealership I'm driving past after work. I'm just perplexed why some gear oil is okay to buy online and some isn't lol.
  6. Sep 29, 2016 at 3:05 PM
    #26
    99SuperTaco4x4
    Adam
    Sacramento
    It actually might have to do with Prop 65 labeling requirements. I have no idea for sure, but if the bottle has the prop 65 warning, it is in compliance. I know the GM 12345982 oil does not have any warning about it. Did the redline gear oil? Just a theory
  7. Sep 29, 2016 at 3:06 PM
    #27
    Speedytech7
    ゼイン
    The use of various sulfates and leaded additive packages will give you instant contact cancer (Only in the state of California though). :rofl:
    eon_blue[QUOTED][OP] likes this.
  8. Sep 29, 2016 at 3:07 PM
    #28
    eon_blue
    That wouldn't surprise me, knowing CA. Not sure on the labeling of the Redline oil but that would make sense.
  9. Sep 30, 2016 at 11:55 AM
    #29
    99SuperTaco4x4
    Adam
    Sacramento
    You end up finding the oil ryan? and what the proper amount is?
  10. Sep 30, 2016 at 12:06 PM
    #30
    eon_blue
    Didn't make it to the GM dealership last night, going on my lunch break soon to see if they have it.
    I searched high and low online for a definitive answer on the oil capacity for the supercharger, there's a thread on here that says you need TWO 8oz bottles of the GM oil (which must be a typo because they only come in 4oz bottles...)
    Found another thread on Yotatech where a member purchased the TRD Supercharger Oil change kit (they no longer offer this), and he mentioned it came with a single 120ml (4oz) bottle of oil for the project. So I'm leaning toward believing that's the correct amount. I'm going to pick up a couple of them to be safe.
    Basically, however much oil I'm able to suck out is the amount I'm going to put back in...I suspect it will be close to 4oz
  11. Sep 30, 2016 at 12:08 PM
    #31
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    late to the party................but did u call Gadget at URD?
  12. Sep 30, 2016 at 12:11 PM
    #32
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    What gen do you have? I believe the 2nd gen hold just above 4 oz. TRD's replacement oil bottle is 120ml so 4.057oz as stated above. It's safe to say you can just get one bottle and be fine but if you have any leaks then a second bottle might be worth it just to be safe. I always did 1 4oz bottle and never had issues.
    https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8881
    99SuperTaco4x4 likes this.
  13. Sep 30, 2016 at 12:16 PM
    #33
    99SuperTaco4x4
    Adam
    Sacramento
    I will caution that I was only able to suck out about 60ml, and I spent a considerable amount of time re-positioning the hose to make sure I wasnt leaving any in there. The Charger took the entire 4oz bottle with no overflow. So if 120ml is the proper amount, then I did get all of the old oil out and my S/C had burned off about half the oil (i do not beleive it to be leaking).
    The primary reasons I swapped oil: (1) history of S/C was unknown to me; (2) rattle in S/C at idle was not normal and inconsistent (I initially thought bad bearing).
    After replacing, idle is smooth and quieter (before at times, sounded like rocks in a tin coffee can). Truck seems to perform better. The old oil was black, smelled really horrendous. New oil is golden clear, doesn't smell horrible.
  14. Sep 30, 2016 at 12:26 PM
    #34
    eon_blue
    Nice, my superchargers history is unknown to me as well. Came with my truck when I bought it this past March, truck only had 24k miles on it but the dealer wasn't sure when the supercharger was installed, or if it was new. I'm pretty sure it was...its got all the original decals and warranty/smog stickers so I assume its got less than 30k miles on it but I want to change the oil as a good measure. Thanks for the info guys. Hoping to change it out tonight after work if I can find the oil
  15. Sep 30, 2016 at 12:58 PM
    #35
    eon_blue
    Chevy dealership has two left in stock, headed over there now :woot:
    OneWheelPeel and 99SuperTaco4x4 like this.
  16. Sep 30, 2016 at 12:59 PM
    #36
    anthony250f
    Anthony
    San Diego, CA
    Mine would only take 4oz and it was coming out of the port
    eon_blue[OP] likes this.
  17. Sep 30, 2016 at 3:41 PM
    #37
    eon_blue
    What kind of syringe did you guys use to suck the old oil out? And where did you buy it?
    Local auto parts store doesn't carry one
  18. Sep 30, 2016 at 3:50 PM
    #38
    99SuperTaco4x4
    Adam
    Sacramento
  19. Sep 30, 2016 at 3:54 PM
    #39
    eon_blue
  20. Sep 30, 2016 at 5:39 PM
    #40
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    John
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Just go to the GM dealership in parts there,
    That's where I got mine
