“Check engine” and “trac off” light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elite777, Mar 13, 2018.
  1. Mar 15, 2018 at 8:30 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Check your wheel speed sensors, I had the same lights on after cracking one while wheeling.
    Nvm.. that’s what I get for posting after reading 3 posts lol
    b_r_o and Elite777[OP] like this.
  2. Mar 15, 2018 at 10:02 PM
    Elite777
    Elite777 [OP] Well-Known Member
    2015 4 banger MGM Access cab
    That would be great to see the letter
  3. Mar 16, 2018 at 5:29 AM
    Elite777
    5am I tried leaving for work. The lights were back on. Back to the dealer
  4. Mar 16, 2018 at 6:38 AM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Everything I'm seeing is just for the 2012 model year. Again, I'm not sure if this is even your issue or not, so the info I'm providing may or may not be of any help. Anyhow, here is the letter that was sent to dealers as well as the one I received:
  5. Mar 16, 2018 at 6:38 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Fn dealer. Half of them always half assn stuff. You will need a new pump. Should be covered under warranty.
  6. Mar 16, 2018 at 7:13 AM
    Elite777
    I’m at dealer now waiting for a rental.
    They are trying to tell me it’s possible rodent damage. Bullshit!
  7. Mar 16, 2018 at 7:15 AM
    Elite777
    Ain’t that the truth I’m only at the dealer because this should be a warranty issue. Other than that I avoid here
  8. Mar 16, 2018 at 7:17 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Get your codes read and then come here asking questions. The CEL code will start your diagnostic procedures..
    I don't understand why that's not the first thing people do. The Auto Parts stores in most of this country will do it for free.
    Hunter.415 likes this.
  9. Mar 16, 2018 at 7:18 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Get your CEL code read elsewhere so you have something to stand on at the dealer... Hell it might even help you avoid the dealer..
    Elite777[QUOTED][OP] likes this.
  10. Mar 16, 2018 at 7:20 AM
    Elite777
    I had the code read by my friend that had a scanner. I got the info I needed before I headed to the dealer for exactly that reason. So I know what was going on.
  11. Mar 16, 2018 at 7:22 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I must have missed that, :thumbsup:
  12. Mar 16, 2018 at 7:25 AM
    CrazyCorn
    CrazyCorn Active Member
    Clint
    2010 Black Tacoma TRD
    6" Toytec Lift, Grill Bar-light, Heated seats
    I had something very similar happen, except I went off a curb and leaf spring hit the exhaust. Long story short, that exact sensor was broken from the event. They replaced the sensor and recalibrated something.. Ive already forgot what is was called, I wouldn't think the calibration and senor would cost that much. $55 part if I remember right, probably asking $100 for recalibration...
  13. May 14, 2018 at 6:19 AM
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    Well my truck went into limp mode and I have a p2442 code. I am sitting at the dealership right now and hoping they say it's covered.
    Fingers crossed
  14. May 14, 2018 at 6:34 AM
    Pigpen
    Dan
    Northwest Montana
    Show the dealer this. The pump and valves will be replaced for free. The replacement parts are not the same as the original parts, supposedly.
    Luke01 likes this.
  15. May 14, 2018 at 6:38 AM
    #35
    Luke01
    Luke
    Dallas, TX
    I have and they are still not sure. They have only done it for Tundras..... never a Tacoma.
    Blah blah blah.
  16. May 14, 2018 at 7:59 AM
    #36
    Luke01
    Luke
    Dallas, TX
    Covered and loaner car untill they get it fixed.
    Hunter.415 and Muddinfun like this.
  17. May 27, 2018 at 4:32 PM
    #37
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    How do you clean the MAF and throttle body?
  18. May 27, 2018 at 6:44 PM
    #38
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    Bravisimo[QUOTED] likes this.
  19. May 28, 2018 at 6:27 PM
    #39
    Bravisimo
    Joe
    Santa Clarita, CA
  20. Oct 10, 2018 at 2:32 PM
    #40
    Truex56fan
    Truex56fan Member
    MAA
    NJ
    I don't post on the forum but I do use for researching various things related to my 2012 Tacoma Thankful for this thread. I went to leave work this afternoon and as soon as I started my truck the Trac Off and Check Engine lights came on. Couldn't get beyond 25 MPH Thankfully Toyota dealer 3 miles away. Dropped it off as no one available. Came home Google'd and this thread came up. I then vaguely recognized the copied letter someone posted. Dug through my documents and I received it as well. I'm hopeful for a positive outcome when they call me tomorrow. Thank you all for the great info always available here. I'm a 60 yr old female w/ a 2012 42,300 mile Taco. I love it and am always careful when I bring it in for service that I'm being treated honestly and fairly. Thanks again!
    lispnik, Bravisimo and sioux like this.
