“Trac Off” and “Check Engine” lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrownTaco12, Feb 14, 2019.
  1. Feb 14, 2019 at 9:28 PM
    BrownTaco12
    BrownTaco12 [OP] Well-Known Member
    Tyler
    Mendenhall, MS
    2012 Tacoma, TRD Off-Road
    OME 884, Bilstein 5100, Generalspringskc HD leaf springs
    Okay, so this morning as I was on my way to class, I was watching the road and paying no attention to my dash lights. As I was trying to drive up a hill, I noticed my truck almost seemed as if it was choking down, and that’s when I noticed the two lights on in the dash. After class, on the way to the dealership to get this checked, I guess my truck went into “limp mode”, because it took me almost two minutes just to get up to 40 mph on the highway. I remembered receiving a service letter from Toyota shortly after I bought my truck, and carried it with me. After running diagnostics, they saw that it was the air injection pumps, air switching valves, and air pump covers. It wasn’t cold outside, maybe 50, and I didn’t do anything outside my normal driving routine. This problem just showed up all of a sudden. Attached is the paper I was sent. Just wondering how many of you have seen this problem with your Tacoma? Mine is a 2012 TRD OR. It was all covered under warranty thank goodness, but from what I can tell it will only be covered under Toyota warranty on these trucks until the end of this month if I’m not mistaken 58399D1E-E6A2-47F5-90E3-77FFE6470EA7.jpg
  2. Feb 15, 2019 at 4:05 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    If you search on here you will find 2012 are notorious for secondary air pump issues. Should be covered by Toyota
  3. Feb 15, 2019 at 8:08 AM
    Muddinfun
    Muddinfun Well-Known Member
    Your notice clearly states 10 years from 1st use. So, in your case, till 5/28/2022
  4. Feb 15, 2019 at 8:17 AM
    BrownTaco12
    Tyler
    Mendenhall, MS
    Well I don’t have “secondary coverage” or at least not to my knowledge. So I wasn’t sure
  5. Feb 15, 2019 at 10:21 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Secondary coverage is what that letter is about. Yes, you have it as well as everybody else that has a 2012.
    Muddinfun likes this.
  6. Feb 15, 2019 at 10:42 AM
    BrownTaco12
    Tyler
    Mendenhall, MS
    Well that’s good to know, I wasn’t sure how to interpret that note
