“Trac off” + check engine? Help!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FlyingMonkey, Dec 21, 2021.
  1. Dec 21, 2021 at 8:21 AM
    FlyingMonkey
    FlyingMonkey [OP] Well-Known Member
    2017 Tacoma OR/LB Quicksand
    Leer topper w/ Prinsu racks. Bilstein 5100's & Falken 285's
    Hey. 911 here. Was backing out of my driveway and the “TRAC OFF” and check engine lights came on. I assumed it was because there was some loose gravel and the traction control system detected some slippage, but it never cleared, even after turning the truck off. I limped to the closest dealership with no power in 1st or 2nd gear (it was fine in 3+) and the shifting was super rough. Service managers said they needed to look at it and rambled on about mice eating wires when it got cold and that they can’t get to it until after Christmas…which obviously screws me for family plans and work. Do y’all have any idea what is wrong? 2017 DCLB OffRoad. Thanks!
  2. Dec 21, 2021 at 8:28 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The TRAC light comes on for a lot of reasons and seems to come on with the CEL sometimes even if it has nothing to do with the traction systems.
    Easiest thing is get it to autozone or similar and have them run a code scanner. Could be as minor as a loose gas cap that needs tightened (get gas recently? tighten to the click), moderately annoying like a wheel speed sensor or battery starting to go out, or pretty bad like a P2441 emissions code.
  3. Dec 21, 2021 at 9:51 AM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    @Gunshot-6A is exactly right. I've got a new stant locking gas cap and if I don't get it quite tight enough, I get CEL and Trac-off. That wouldn't explain the lack of power and rough shifting though. Get a cheap OBD scanner so you can check and reset codes yourself.
    shakerhood and Gunshot-6A like this.
  4. Dec 21, 2021 at 10:02 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    You need to pull the codes but it could be as simple as a bad AF (air fuel) relay. Swap the fog light relay with the AF relay in the engine bay and see if that fixes it. That fixed my problem codes of P0031 and P0051. Also check the AF fuse
  5. Dec 21, 2021 at 1:05 PM
    FlyingMonkey
    Thanks for the responses, folks. She's at the shop now...hope I can get her diagnosed and fixed before I gotta go out of town.
    shakerhood likes this.
  6. Dec 21, 2021 at 3:19 PM
    FlyingMonkey
    dealership called and said it's almost certainly rats making a nest in the intake and chewing sensor wires. They're taking the intake plenum off to see, but apparently it's not that easy?
  7. Dec 21, 2021 at 3:23 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Dec 21, 2021 at 3:56 PM
    FlyingMonkey
  9. Dec 21, 2021 at 4:12 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That sucks, hopefully insurance will cover the damage if it was mice.
  10. Dec 21, 2021 at 8:46 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Same sentiment here. Just got my Kubota subcompact back with a new engine. Mice nested in the air intake and got sucked into the engine when I tried to start it. The debris destroyed the compression. $6K lesson and now I'm at war with the mice.
  11. Dec 21, 2021 at 8:52 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I carry a small aluminum pump mister in my truck that has several drops of pure peppermint oil mixed with water in it.
    At least once a week I go around the engine bay giving everything a spritz of this sharp smelling mist.
    Mice and most other rodents can't stand it.
    HV101 and shakerhood like this.
