❓Just bought 2001 Tacoma- Help a girl out with questions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by _Lisa_'01Tacoma4x4, Jun 26, 2018.
  1. Jun 26, 2018 at 11:25 PM
    _Lisa_'01Tacoma4x4
    _Lisa_'01Tacoma4x4 [OP] Well-Known Member
    Lisa
    SoCal
    2001 Tacoma 3.4L V6 4x4 Dcab
    Lifted (not sure of height), Falken RockyMountain 285/75/16 tires, unsure of wheel details, auto leveling kit, moded to HID H4 headlights from previous owner. Recently Upgraded to LED headlights.
    2001 Tacoma 4x4 automatic Double Cab (177k miles): (it's got some things need fixing & have some questions)...
    • Would this be a some kind of security alarm?
    If so, how can I get it working?
    • Headlights (previous owner had HIDs conversion installed. I recently upgraded them to LED's): Why doesn't it have a "headlights still on" warning chime? And Highbeams dash light indicator doesn't come on, when Highbeams are on. How could I fix that?
    • Tires are rubbing inside wheel well... Have Falken Rocky Mountain 285/75/16 tires and MB Motorsports wheels, with a 2.5" Lift (??) (Not exactly sure of any of the details of lift/suspension, etc.) Also has Leveling kit installed. (Again unsure about the details)... How would I go about cutting/trimming to remedy this? And how much?
    Input and advice Greatly appreciated! Cheers.
    -Lisa
    2002Tacoma4x4 and MarX like this.
  2. Jun 26, 2018 at 11:47 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    It looks like an alarm to me, but no idea how to get it running, my truck had something like that and it never worked, except randomly going panic mode on me once, so I removed the speaker for it and now just have the little red light.
    I have aftermarket HID's in mine and I have the warning chime if I leave them on. I don't have high beams at all though.
    As far as the rubbing, it looks like some of the plastic liner has been cut to try and help, hard to tell in your pic but under that is something called the pinch weld (look up pinch weld mod) basically a small piece of the body that sticks out, it will need to be beaten flat or cut off. That should help a lot but won't for sure take care of all the rubbing. It could also just be not aligned perfectly and that is causing part of it.
    I would do the pinch weld and cut out the plastic liner, and if it still rubs check the alignment, but depending on your wheels backspacing it might just be a fact of life.
  3. Jun 26, 2018 at 11:51 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    Passenger seat eject module??
    Def needs some cutting/trimming if your going keep those 285's
  4. Jun 26, 2018 at 11:52 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Welcome to Tacoma World! The most expensive free membership you'll ever have.:thumbsup::rofl::wave:
    The red button thing appears to be part of an alarm but I'm not familiar with that one.
    The Head light issue from what I know is just part of having LED's. LED's are a diode so no power can get past the bulb to turn on the high beam indicator or chime.
    The rubbing you need a BIG F'n Hammer and do the pinch weld mod.
  5. Jun 26, 2018 at 11:54 PM
    E30325
    Nick
    I had to do the pinch weld on my truck just going from one set of 31's to another because of wheels with different back spacing, imo it needs to be done on basically any truck not staying on stock wheels and tires. Used a benchmade and a framing hammer :rofl:
  6. Jun 26, 2018 at 11:55 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Welcome.
    Not sure about the other questions but I can almost 100% gaurentee the rims are MB Vdrive. Same as what I rock, blacked out like yours.
  7. Jun 26, 2018 at 11:56 PM
    E30325
    Nick
    Hot damn that's a sweet truck :thumbsup:
  8. Jun 26, 2018 at 11:58 PM
    Matic
    Tricky Dick
    Easley, SC
    And yes OP as Jonny 9 and Nick mentioned...Pinch weld mod.
  9. Jun 27, 2018 at 6:07 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Ghetto fix for the LED lights: Purchase these two connections from Amazon, https://www.amazon.com/gp/product/B009NYH9YE/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1. You will then splice and solder the two female ends (that connect to the bulbs), with the one male end, creating a Y cable. One female goes onto the LED bulb, and put an incandescent bulb on the other. Then slide the incandescent into something like a little tomato juice can to protect it from getting knocked around and broken. I put this Y on the driver side, and there is a nice hole in the front inner fender where you can locate the extra bulb to hide any light escaping and protect it. The incandescent bulb provides the needed resistance to keep the chime, high beam indicator, and auto off (if you have that) all working as intended.
  10. Jun 27, 2018 at 6:44 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^ no, don't bother.
    get this instead: https://www.superbrightleds.com/mor...ad-resistor-h4-led-headlight-bulbs/2932/6284/
    one simple plug in, no splicing.
    also, with the 01-04 we got "courtesy lights" which automatically fade the interior lights out and when you shut off the truck and open the door, all lights go off. this is a safety feature to prevent having the lights drain the battery. no more door chimes unless you have the key in and door open.
  11. Jun 27, 2018 at 6:56 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
  12. Jun 27, 2018 at 7:32 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah, some Amazon and eBay junk doesn't work. I trust SBL products. I've been using this module for a couple of years now myself. :)
  13. Jun 27, 2018 at 1:39 PM
    Glamisman
    Glamisman Well-Known Member
    a radio install shop "should" be able to tell you either how to get the existing alarm functioning or take it out and put another one in.
  14. Jun 27, 2018 at 1:43 PM
    eon_blue
    Azusa, CA
    Gonna have to trim that plastic and most likely trim and/or beat in the metal pinch weld behind the tire. An angle grinder works well to notch it first so you can fold it with a hammer, or just cut a piece out entirely. Or, could go down on tire size to 265/75s....1" smaller. Even those sometimes require trimming depending on your wheels.
  15. Jun 27, 2018 at 1:58 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  16. Jun 27, 2018 at 3:14 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Yes! That's what they are! However, the previous owner seems to have only wrapped the wheels in black, as you can see here in this pic... Is it possible to just paint them black instead? So to avoid this horrid peeling off look.
    MarX and Matic[QUOTED] like this.
  17. Jun 27, 2018 at 3:21 PM
    _Lisa_'01Tacoma4x4
    Lisa
    SoCal
    Hmm... You know, I never checked(or at least noticed), if it had had the chime with the previous hid's... Oh but the dash light never came on, because the hid's only had the low beams. The new LED's now have both low/hi beams. (Which are awesome by the way! Especially given that I live on a ranch, off dirt roads).
    Low beams
    Hi beams
    MarX likes this.
  18. Jun 27, 2018 at 3:54 PM
    Smash8ight
    Smash8ight Well-Known Member
    04 trd
    Bone stock
    Rip all that alarm stuff out as neatly as you can.....if you don't know what it is, kill it....
    It could cause ignition issues if you don't...
  19. Jun 27, 2018 at 4:32 PM
    Smash8ight
    04 trd
    Bone stock
    How does the truck ride?bump handling....
    If it has a 2.5 lift then why would it need leveling kit?
    Not sure about all that...
  20. Jun 27, 2018 at 4:37 PM
    sedapsfoeca
    sedapsfoeca Member
    Nancy
    Northern Virginia-ish
    2015 Barca Red Tacoma
    i definitely had the same issue running 285/75 nrg at first with slight rubbing, even with a proper alignment. luckily all it took was a slight trim off the fender, trimmed some of the plastic in the tire well, and (if you have a grinder/cutoff wheel) trim off a bit from the cab mount. you can pretty much see where the tire rubs up against those pieces.
