0-60 times anyone?
Discussion in 'Performance and Tuning' started by Mudbug, Jul 13, 2007.
  1. Apr 21, 2015 at 8:35 AM
    #61
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    You can...just don't shift on the fly over 62 (I think that's what the manual says).
  2. Apr 21, 2015 at 6:52 PM
    #62
    Arizona
    Arizona New Member
    Tucson
    2015 Tacoma 4x4 4.0L
    Howdy. I'm new, from AZ, and am getting a 2015 Tacoma 4wd Double cab with the 4.0L. I've been seriously considering the factory s/c, but am having second thoughts. This truck is going to be my daily-driven vehicle, and I'd like it to last for a long time. Can anyone give me pros and cons?
  3. Apr 21, 2015 at 7:25 PM
    #63
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    I honestly don't have a clue as I'm too broke to ever look into it. However I can tell you the factory supercharger is going to be the safest bet for more power, really its your only option for more power...
  4. Apr 21, 2015 at 7:38 PM
    #64
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    how hard is that swap?
  5. Apr 22, 2015 at 5:06 AM
    #65
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Sure. It's installed by the dealer. You get warranty for the life of the warrenty. I got the 8 year warranty, the SC is covered. At 100k you'll have to do plugs, if they must pull the SC, expect a hefty $400 bill. Also, there is a recommended 100k service on the SC. You probably will need to replace the SC belt every 30k miles with a better one if you're smart. Expect prices from $4700 to $6000, depending on you're dealers in the area. Mine was $5900, went to a more experienced not idiot dealer, talked to the tech, they gave me a rental, 3 days, no rush.
    What you need to do is start reading here and soaking up info about the SC. Don't start thinking about the small pulley and bigger fuel pump etc etc, getting a boost gauge. If your asking such basic questions now you haven't done your homework or know much about this stuff.
    Now that's out of the way, it REALLY wakes the truck up. Lots more HP. Just do it.
    I made a big post to a guy just 3 weeks ago, it will explain more. Find it. Search my posts, I don't have a lot.
    Get to work, read up!
  6. Apr 22, 2015 at 8:21 AM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Eeeewww......mine is faster than that with one bad cylinder. :p ;) Yours needs a diet. :D
