0 Gauge Amp Kit - Distribution Block to Two Amps
Discussion in 'Audio & Video' started by Commanderwiggin, Jan 3, 2012.
  1. Jan 3, 2012 at 8:56 PM
    Commanderwiggin
    Commanderwiggin [OP] Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    So I'm pretty sure this will work but just checking.
    I have a Stinger 0 gauge amp kit that I will run off my battery to a power distribution block.
    Battery ---0 Gauge Wire + Inline Fuse---Distribution Block 0 gauge in/two 4gauge outputs
    Distribution Block Output 1 ----4gauge---- 1 Farad Capacitor ----4gauge---- 750w RMS Mono Amplifier
    Distribution Block Output 2 -4gauge---- 400/4 Amplifier
    Throw out some ideas on where you would put everything and why.
    Going to have the amp in the middle section of the Sub box behind the rear seats...thinking of putting the distribution block inside the drivers side storage compartment with the capacitor...400/1 amplifier under the driver seat...crossover locations unsure.
    Or would putting the Capacitor before the distribution block work better...probably...0 gauge probably too big though.
  2. Jan 4, 2012 at 5:20 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    I assume that your distribution block is fused? If not, it needs to be. Other than that the capacitor is probably unnecessary, especially considering that you have the 140amp alternator, but you are installing in an acceptable spot in your system.
    If you are planning to remove both of the plastic bins in the back, put your amp rack on the box. If you are trying to keep one bin, place them under the front seats. If you delete the capacitor you should be able to fit everything but the sub under the seats pretty easily.
