00' 3.4 Valve Cover Gasket Just Replaced, Chk eng light returned.
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForumContributorsAreLife, May 19, 2017.
  1. May 19, 2017 at 2:06 PM
    ForumContributorsAreLife [OP] Well-Known Member
    Title says it all. I have an 00' taco with the 3.4l. I just replaced the valve cover gasket, along with some grommet/washers, spark plug wires, spark plugs, pvc valve, all that good stuff. I ordered the kit off of eBay from a Toyota dealer. Paid $200 all in all. I also replaced the injectors branded Denso. Everything was genuine parts. My question is..... The darned check engine light came back telling me I have a bad valve cover gasket....... what gives?
  2. May 19, 2017 at 2:07 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    welcome to tw
    ...elaborate on your screen name..
  3. May 19, 2017 at 2:13 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Not sure if there is a DTC for valve cover gasket. Do you know the actual code number by chance?
  4. May 19, 2017 at 2:14 PM
    Users who contribute their advice, opinions, or expertise to another fellow user in need of it are life. Life as in they make things easier and save headaches. :) thanks for the welcoming.
    SwampYota, otis24 and ramonortiz55 like this.
  5. May 19, 2017 at 2:16 PM
    Lost the paper that I wrote the code down onto, was an AutoZone scanner. :/
  6. May 19, 2017 at 2:30 PM
    cruiserguy
    Elijah
    SLC
    Mmmm, we're really gonna need that code. Also, the info on the taco. Which engine, tranny, mileage, the maintenance that's been done, etc. The more the specific the info, obviously as possible, the more specific of answer or help you'll likely get. Yeah welcome to the most helpful Tacoma forum online. :thumbsup:
    Edit: oops just noticed you had the engine and year in title of thread.
  7. May 19, 2017 at 2:49 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
  8. May 19, 2017 at 2:54 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Probably something not hook up or partially connected look over everything double check the work
    FirstTimeFirstGen likes this.
  9. May 19, 2017 at 3:19 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    I think Autozone gave you incorrect info. I don't think your going to find a code for such. How is the computer going to know that? It might see low vac. pressure but no way to make that a valve cover gasket. Get the code.
  10. May 19, 2017 at 6:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    code for a valve cover gasket? thats not even possible to detect...
  11. May 19, 2017 at 7:27 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    The real question here is why did you change your injectors?
  12. May 19, 2017 at 7:52 PM
  13. May 20, 2017 at 7:27 AM
    Codes were P0301 and P0440. And their computer suggested the part, I was already gonna replace it anyways because it would drip oil every now and then.
  14. May 20, 2017 at 7:29 AM
  15. May 20, 2017 at 7:34 AM
    1988Mercedes
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Google is your friend here. Nothing to do with valve covers. 301 is misfire on cyl 1 and 440 is the evap system.
  16. May 20, 2017 at 7:46 AM
    cruiserguy
    Elijah
    SLC
    Try swapping first coil pack with another and see if the MIL follows the coil pack or stays with that first cylinder.
    Can't remember if on the P0440 a new gas cap was a common fix or not.
  17. May 20, 2017 at 7:51 AM
    I ound the print out, and it says the most common fix seen by ASE certified technicians is to have the valves adjusted to OEM settings. I literally just saw that right now.
  18. May 20, 2017 at 7:53 AM
    I forgot to note, the misfires have been dealt with. I included it just incase theres a pattern with these two specific codes.
  19. May 20, 2017 at 11:10 PM
    otis24
    Mark
    California
    Reads codes as well as live data. I use the free version of OBDCarDoctor app. The pro version allows you to actually record the data as well.
