00' Prerunner Running real rough
Discussion in 'Technical Chat' started by _Hammer, Jun 11, 2008.
  1. Jun 11, 2008 at 8:12 PM
    _Hammer
    _Hammer [OP] New Member
    I have a 2000 Prerunner 3.4 and the engine is running rough. The timming belt looks ok, could it have jumped? Has major power loss, runs rough until about 2k rpms unless driving. Possibly wires/plugs, bad head gasket idk? Did compression test with water neck to check for head leak(by hand).
  2. Jun 11, 2008 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sonds like your idle advance. Is there a code? I think there is a vacume line on the driver side of the engine by the brake booster. Check and see if it came loose. :)
  3. Jun 11, 2008 at 8:27 PM
    _Hammer
    Ya there is a code but not a place to read for about 45 miles away. probably wondnt make it. I just did a quik look, no hoses undun that I can see
  4. Jun 12, 2008 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm.....Need to get the code read.
