007 TACO PRO ....
Discussion in '2nd Gen. Builds (2005-2015)' started by Jon G, Jan 8, 2018.
  1. Jan 9, 2019 at 5:13 AM
    #861
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    I would try a clay bar on the windshield.
    Jon G[OP] likes this.
  2. Jan 10, 2019 at 5:41 AM
    #862
    Jon G
    Jon G [OP] Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    @Juforrest Thanks
    Thinking about calling my insurance company and getting a new one put in as it would be covered and it has a huge crack going along the bottom
    In other news we had a huge ice storm here in Disneyland ah Newfoundland and i backed out of my drive way and pressed the brake and it seams like only the front brakes are working ...... More fun ..... :(
  3. Jan 10, 2019 at 5:44 AM
    #863
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I don't know that I would call that fun.
  4. Jan 13, 2019 at 4:34 AM
    #864
    Jon G
    Jon
    02, 04 & 07 Tacoma
    5E3A2C94-4D7E-4CD6-8142-5144EEEBB0B9.jpg 1E2B3608-960A-483F-AA91-C5ED403F3611.jpg
    Bocsy44 likes this.
  5. Jan 13, 2019 at 4:40 AM
    #865
    Jon G
    Jon
    02, 04 & 07 Tacoma
  6. Jan 13, 2019 at 6:49 AM
    #866
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  7. Jan 13, 2019 at 8:46 AM
    #867
    Jon G
    Jon
    02, 04 & 07 Tacoma
    No just stalked it at the ⛽️ station
    Kemosabe and Bocsy44[QUOTED] like this.
  8. Jan 16, 2019 at 5:43 PM
    #868
    Jon G
    Jon
    02, 04 & 07 Tacoma
  9. Jan 16, 2019 at 7:34 PM
    #869
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Swapping shocks?
  10. Jan 17, 2019 at 3:33 AM
    #870
    Jon G
    Jon
    02, 04 & 07 Tacoma
    @Juforrest yes sir
    Removing the shocks that came with the truck to install low Km OEM TRD stock crap slowly working my way up to 5100's
    The reason for this impromptu wrenching adventure is because a guy in my local Toy group hit a pot hole hard doing 110km and broke 2 springs and shocks, he was snow wheeling all day and thinks the shocks were packed with ice.
    So he is taking the ones that are in the truck now.
    But no good dead goes unpunished and trust me i have learned this lesson a few times in the last two months FFS
    Anyways i stripped the sway bar end link trying to remove it worst thing is that now it is loose
    I did not have a good night last night wrenching and did not enjoy it due to many reasons.
    and i have to do the other side tonight
  11. Jan 17, 2019 at 6:37 AM
    #871
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Cold concrete and life make working on your rig unfun sometimes. I don't know about in your neck of the woods, but down here there's tons of us that shit canned our sway bar. Any of your local guys have a bar laying around? I traded my sway bar to one of the local guys for a monster energy drink.
  12. Jan 17, 2019 at 8:42 AM
    #872
    Jon G
    Jon
    02, 04 & 07 Tacoma
    I was thinking about taking it out as i do know lots of people do But i only have the stock TRD suspension and wondered how it would react as this truck is my DD
  13. Jan 17, 2019 at 11:06 AM
    #873
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Pull it till you find a link or decide you don't need it.
  14. Jan 17, 2019 at 2:52 PM
    #874
    Jon G
    Jon
    02, 04 & 07 Tacoma
    007 Taco Pro
    Changed out the passenger side shock after work today. Took me 45min start to finish
    Did a simple step by step of it
    Jacked up truck
    Remove wheel
    Remove pin in upper ball joint
    Loosen crown nut down flush with end of tread on ball joint 1” wrench
    Hit side of spindle with hammer to pop ball joint out
    Remove Three 14 mm nuts on top of shock
    Remove the Nut and bolt 3/4” on bottom of shock
    Un hook abs sensor line from holder on spindle so it will not be pulled tight
    Check this line and brake line so they do not become tight during the removal
    Remove sway bar bushing bracket on frame two 14mm bolts
    Completely remove upper ball joint nut
    Pull spindle back
    Pull sway bar link and bar ahead
    Shock can be wiggled down and out
    Install new shock the same way old one came out
    The only thing different about assembling is the sway bar bushing bracket. One side is slotted, put bolt in frame and slide slotted end over bolt. Jack up bottom a arm this will push linkage up allowing second bolt to be put into frame
    Next time I am doing front end work I will be removing the sway bar
    Save a few $ Front shocks are easy to do yourself.
    Juforrest likes this.
  15. Jan 17, 2019 at 5:20 PM
    #875
    Jon G
    Jon
    02, 04 & 07 Tacoma
    I installed the TRD “off road” upgrade
    Some of you won’t get this
  16. Jan 17, 2019 at 5:46 PM
    #876
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Much time was wasted with that game.
  17. Jan 18, 2019 at 3:49 AM
    #877
    Jon G
    Jon
    02, 04 & 07 Tacoma
    @Juforrest after i completed the work on the truck last night i was thinking to myslef that was a bit of a upgrade and for some reason my mind went back to my childhood playing this game and upgrading your truck.
    CableTec likes this.
  18. Jan 18, 2019 at 4:34 AM
    #878
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I used all the points towards nitrous.
  19. Jan 22, 2019 at 2:48 PM
    #879
    Jon G
    Jon
    02, 04 & 07 Tacoma
    So my inside passenger electric door lock button is now down in the door :(
    Think the dog was standing on it
  20. Jan 22, 2019 at 5:12 PM
    #880
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I have the same,
    My kid smashed mine down with his heed sitting in the front seat. He's now big enough that he's in the back ( access cab ) and now my littlest one is in there, so I decide that it can live in the door until both boys are old enough to stop kicking my truck!
