01-04 Blinker Relocation Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by PcBuilder14, Dec 2, 2013.
  1. Dec 2, 2013 at 12:28 AM
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    This is my write-up on how to relocate the blinker lights from the blinker housing to the running light housing. I am doing this mod so I do not have to run aftermarket blinkers for my plate bumper I will be getting.
    I have not completely finished this mod, but will update as I do.
    First off, there is a write-up out there by Blackdawg for this mod. But there are not very detailed instructions on how to do this on 01-04's since it requires us to do some different steps.
    So for those of you that own a 96-00 Tacoma, I will refer you to this thread:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/186115-free-blinker-light-relocation-mod.html
    On to the write-up!
    Here are the items you will need to do this:
    01-04 corner light housings
    01-04 blinker light housings
    Drill
    Various drill bits
    Dremel
    Watertight sealant
    Cutoff wheel
    Grinding stone
    Polishing wheel
    First thing was to figure out how to cut out the mount on the back of the blinker housing. 01-04 blinker bulbs stick out so far that you have to put the mount on the corner light to keep it back far enough to fit in the housing. And even then, it's a very tight fit.
    Began cutting around the edge on where there was plenty of room to cut.
    Once I got to this point, I stopped and began cutting from the top down along the side of the bulb mount.
    Once that was complete, I had to find a way to get to the back side of the mount. I was kind of timid on what to cut and what not to. Then I realized that you pretty much just have to cut all of this plastic out of the way to get to the other side of the mount.
    Once you do that, the mount should come off and you'll have this! I left the bit of plastic sticking out from the circle to keep as a reference of what's up and down for the mount. Shouldn't make too much of a difference, but this way the socket slides in the same angle as stock.
    [​IMG]\
    Next was to test where it would be mounted, so I set it on the back of the corner light housing to see where I would need to trim to get a good fit. I spent about 30-40 minutes trimming little by little, but honestly if you don't care you could just leave it how it was cut and just use the sealant all the way around to keep it in place.
    Here was my final shape for the mount. I used the polishing wheel to clean off all of the plastic burrs.
    Next was to trace out where to drill the hole for the bulb. I just used a pencil to draw the inside circle to get a good idea on where to start.
    Once I got the first hole drilled, I drilled it out bigger by going up one drill bit size at a time until I had this.
    Then, I used the grinding stone to bore the hole out a little at a time, constantly test fitting the bulb and mount to make sure the hole was still lined up correctly. Again, I used the polishing wheel to clean off all of the plastic burrs.
    Next was to re-route the wiring for the blinker up to the corner light location, very simple. Luckily the wiring for both lights have the same start point.
    There are two mounts that hold the wiring in place:
    Here:
    And here:
    You can remove both mounts, but I just removed the lower one by pulling on the wiring until it released itself from the mount and it allowed enough slack to run the blinker wiring up beside the corner light wiring like so.
    Next, I test fitted the mount to be sure everything still line up correctly. Once I was sure everything would fit, I cleaned off the area with a rag and the polishing pad from my dremel.
    At this point, I made sure to get as much of the plastic shavings out of the corner light. I just shook it around until I was able to get all of it out, but you can use compressed air as well.
    Next I began sealing the mount to the corner light. Don't be stingy with the sealant either, apply as much as you want.
    Here is the final product with a video. Thanks for looking!
    http://www.youtube.com/watch?v=esnGEWquYnI&feature=youtu.be
  2. Dec 2, 2013 at 12:31 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  3. Dec 2, 2013 at 12:33 AM
    PcBuilder14
    Brent
    Nor Cal
    Haha what do you think? Informative enough?
  4. Dec 2, 2013 at 12:47 AM
    95 taco
    95 taco Battle Born
    Yeah, It's kinda missing the end though.
  5. Dec 2, 2013 at 12:48 AM
    PcBuilder14
    Brent
    Nor Cal
  6. Dec 2, 2013 at 4:44 AM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    Good write up, I'm fixing to do mine as well!
  7. Dec 2, 2013 at 10:32 AM
    PcBuilder14
    Brent
    Nor Cal
    Thanks!
    Updated OP BTW...
  8. Dec 2, 2013 at 1:29 PM
    PcBuilder14
    Brent
    Nor Cal
    Write-up complete, with video at the end.
  9. Dec 2, 2013 at 2:01 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Note if you use LEDs they are pretty long so you may have to adjust the hole, I did the same but just drilled and made my own locking part with a dremel tool
  10. Dec 2, 2013 at 2:05 PM
    PcBuilder14
    Brent
    Nor Cal
    Where did you drill the hole then? That's the point of using the mount so that it pushes the bulb back farther.
  11. Dec 2, 2013 at 2:09 PM
    bellassaiw10
    Currituck NC
    Basically the same spot lol
  12. Dec 2, 2013 at 2:11 PM
    PcBuilder14
    Brent
    Nor Cal
    Then your LED's must be shorter? Because the bulbs nearly touches the lens with the extra 3/4" of mount.
  13. Dec 2, 2013 at 2:14 PM
    bellassaiw10
    Currituck NC
    They're pretty long, I have them slanted up slightly
  14. Dec 2, 2013 at 2:17 PM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, interesting.
  15. Dec 2, 2013 at 2:19 PM
    bellassaiw10
    Currituck NC
    I would take them out but I'm head to work haha Ill post some later though, nice write up though!
  16. Dec 2, 2013 at 2:24 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Good job, Ill use this once I get my bumper
  17. Dec 2, 2013 at 2:25 PM
    PcBuilder14
    Brent
    Nor Cal
    Sounds good! Thanks! :thumbsup:
    Thanks! My top plate for my bumper came in today! Rest should be here tomorrow.
  18. Dec 2, 2013 at 6:54 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    they come in two separate shipments?
  19. Dec 2, 2013 at 6:55 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, or at least mine did.
    Received the top plate that goes across the entire bumper.
  20. Dec 2, 2013 at 7:42 PM
    4banger4x4
    Eric
    Whorelando, Fl
    torture! im hoping mine comes all at once
