01-04 Tacoma LED Cluster&Climate Control light replacement sizes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Topher04x4Tacoma, Mar 13, 2018.
  1. Mar 13, 2018 at 7:29 AM
    Topher04x4Tacoma
    Topher04x4Tacoma [OP] Member
    CHRIS
    2004 Toyota Tacoma TRD 4x4
    -Gauge Cluster is 194
    -Climate Controls is Neo-wedge type B bulbs or T4.
    Hope this makes for a more simpler search.
    daviesjack808, Ritchie and Jorge_DC like this.
  2. Mar 13, 2018 at 9:05 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  3. Mar 13, 2018 at 10:03 AM
    Topher04x4Tacoma
    CHRIS
  4. Mar 13, 2018 at 10:37 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    there's about a dozen posts on this :)
    Sicyota04 likes this.
  5. Mar 13, 2018 at 10:38 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  6. Mar 13, 2018 at 10:47 AM
    Topher04x4Tacoma
    CHRIS
    I just wanted to create a thread where the first or 2nd post gives you the answer instead of clicking a link to a link to another link and then finally you have to scroll and then you find your answer.
    ChargedSHOTaco and wolfgang123 like this.
  7. Mar 12, 2019 at 9:52 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Do these also work for 2000?
  8. Mar 12, 2019 at 12:42 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    the cluster 194s, yes. as for hvac I'm not sure
  9. Jan 6, 2020 at 5:16 PM
    Jorge_DC
    Jorge_DC New Member
    Jorge
    '03 Toyota Tacoma Prerunner
    Thanks to all for your responses, this should help tremendously !
  10. Jan 7, 2020 at 11:18 AM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Anyone know of an indicator light for the brights indicator that isn’t so f-ing bright? I took the electrical tape off from in front of it because i hate the way it looks. Put the tape back on immediately after the first tome I hit the brights switch
  11. Jan 7, 2020 at 1:18 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    don't use an LED bulb?
    I've never switched that particular bulb so I've never had an issue.
  12. Jan 7, 2020 at 3:50 PM
    ToyotaDriver
    Idaho
    Not led. Original bulb. way too bright
  13. Jan 7, 2020 at 6:46 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    :notsure: what to tell ya then. if it's too bright then use the dimmer to make it less bright?
    you could maybe source out a bulb that's lower or use a bulb cover (condom) in white/frost for the size to diffuse
    idk, unless you are staring directly at it it's actually one of the lesser bright bulbs.
  14. Jan 9, 2020 at 4:54 PM
    ToyotaDriver
    Idaho
    I run down the highway and backroads with my dimmer all of the way down to where the dash lights are off (easier to see deer). The brights indicator is blinding when there’s no light. Its intolerable for my eyes. It would be really cool to run it through the dimmer, but I’m not sure that would be possible without putting a relay behind the dash. Seems a little excessive.
  15. Jan 10, 2020 at 7:40 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    oh my bad, I thought they all went through the dimmer, shows how much I notice it :D
    You must be tall/short enough to have direct line of sight for the indicator and most people rarely ever complain about it.
    another option is to pull the cluster and use some "smoke" covering/paint to put over that particular indicator to lessen the light output. I doubt they make less wattage bulbs as they are pretty low to begin with
  16. Jan 10, 2020 at 12:02 PM
    ToyotaDriver
    Idaho
    I might try a few of those things, but I’m leaning towards just pulling the bulb. It’s pretty easy to tell when they’re on without the idiot light.
