01 Brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr.Fahrenheit, Nov 8, 2009.
  1. Nov 8, 2009 at 5:32 PM
    Mr.Fahrenheit
    Mr.Fahrenheit [OP] Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    Sup TW,
    Just bought a new 01 tacoma and holy moly the brakes are warped in the front. so im going to up grade but not sure what rotors and pad combo to use. was thinking of getting the power slot cyro rotors but not sure....what are your thoughts??
    http://www.autoanything.com/brakes/10A50530.aspx
    ps. it has fabtech coilovers with shackle lift in the rear running 32 10.50's
    -Thanks
  2. Nov 8, 2009 at 5:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I heard that Hawk makes awesome pads for our trucks...thats what I 'm gonna run when the time comes :)
  3. Nov 8, 2009 at 6:00 PM
    Mr.Fahrenheit
    agreed but which ones?? there are different kinds in the link on #1
  4. Nov 8, 2009 at 6:01 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    I wouldn't put a lot of money into rotors... these trucks are famous for trashing them at the drop of a hat. You might extend the life a bit with aftermarket and careful use, but mine ate them for lunch and in reading the forums, I am not alone.
  5. Nov 8, 2009 at 6:07 PM
    Mr.Fahrenheit
    ya thats why im thinking of the power slot cyro because of the rotors are cyrogenically treated preventing wrap age to an extent....
  6. Nov 8, 2009 at 6:52 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mine are also warped a little bit, and im also wondering if its a good idea to just upgrade and get new rotors and pads.
    Or just to have them turned?
  7. Nov 8, 2009 at 8:37 PM
    Mr.Fahrenheit
    well the cheaper route of course would be machining them but i have some extra dough and i want to blow it on brakes considering these rotors are super warped.......50 bucks to machine verses 250+ bucks for new rotors.......
  8. Nov 8, 2009 at 9:39 PM
    ETaco23
    Evan
    PNW
    true, So I think i will just get mine machined, and then get some really good pads next time.
    Do slotted rotors really last much longer, and not warp. I mean, long enough too really make a difference?
  9. Nov 8, 2009 at 9:47 PM
    Mr.Fahrenheit
    not really sure, i have heard different opinions, some saying that since they are slotted they have less surface area, thus less material and more heat and more chance to warp. but i have heard pros and cons but have not personally experienced brake upgrades....
  10. Nov 9, 2009 at 8:07 AM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    When I was still IFS, I switched to cross-drilled, then to slotted rotors. Both seemed to last a little longer, but I am not sure it was enough to offset the additional cost. Probably not.
    In my experimenting, one thing I did find, was that the cheapest organic pads I could find, reduced the warping the most. All the expensive semi-metallic pads lasted a little longer, but all seemed to eat rotors. When switched to the cheap ones, they didn't last as long, but I would get a couple of sets through before needing to play with the rotors again. Since replacing them is a five minute job per side, I did that until I cut the IFS off and was done with the problem.
  11. Nov 9, 2009 at 2:49 PM
    Mr.Fahrenheit
    hmmm well then i dunno what to do now. i work at a shop so i just machined my rotors but i kinda still want to get slotted rotors.....should i just get better pads, steel brake lines and keep the oem rotors???
  12. Nov 9, 2009 at 5:59 PM
    ETaco23
    Evan
    PNW
    I think thats what Im ganna do^^^
    I might try the Hawk pads, But Im ganna be ordering my SS Brake lines soon.
  13. Nov 10, 2009 at 8:05 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Brembo blanks w/ Hawk pads or some Auto Zone brakes with stock pads...
  14. Nov 11, 2009 at 5:45 PM
    Mr.Fahrenheit
    hmm really auto zone brakes???
    i machined my rotors so they no longer shake when braking. so ya dunno what i shall do, most likely steel brake lines but still in the air on pads and rotors...
  15. Oct 22, 2012 at 9:22 PM
    Mr.Fahrenheit
    ha update. just read all my posts......still rocking the same pads and rotors. machined them twice now...hit the max on machining so now i have to upgrade brakes......three years later..
