`01 Cat Back Exhaust
Discussion in 'Performance and Tuning' started by tacotoe, Nov 29, 2007.
  1. Nov 29, 2007 at 5:24 PM
    tacotoe
    tacotoe [OP] Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    New exhaust sys. arrived today.Inspected all parts& everythings all there,packaged well w/ no damages.Sprayed some foo foo on the o2 sensor nuts to let soak awhile.Kit requires re-using two fastners at flange, but thats not gonna happen,have stainless replacements already.If I`m real ambitious tomorrow after work it should be an easy install,otherwise Saturday.
    Let you all know how it goes.I`m a bit computer challenged but maybe I can do an audio clip too.Wait I cant even insert a picture here whats my url address?Help
  2. Dec 8, 2007 at 3:55 PM
    tacotoe
    Nebraska
    `17 AC Sport MT
    Finally installed Gibson Cat-Back system on `01 Tacoma.Sound is much improved and not obnoxiously loud.System took me 4.5 hours from start to finish by myself.O2 sensor had to be surgically removed with a right angle die grinder/cut off wheel,slicing mounting studs just below gasket.Made a trip to hardware store for (2) 1&1/4 x 3/8 bolts,nuts,washers, as originals had to be cut off.Hangers were kind of a booger to get out of the rubber but use spray lube and a sm. screwdriver to get them started.
    Factory muffler was not badly restricted due to corosion,as I thought might be possible. Reset M.I.L.
    Drove to gas station and filled up,but couldnt tell if performance is improved due to a fresh sheet of ice on the road.Definately sounds better than new.
    P.S.-Talked to a computer whiz guy @ work he told me I need to get a homepage set up through ISP to post pictures, I`ll work on that soon.
  3. Dec 8, 2007 at 4:04 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Register at photobucket.com and upload your pics and vids there and you can link to them from here.
  4. Dec 8, 2007 at 4:34 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Post your photos in your gallery here if you like.
  5. Dec 8, 2007 at 4:38 PM
    tacotoe
    Nebraska
    `17 AC Sport MT
    Thanks for the photos help/tip, I`ll try it tomorrow...My son is buggin me to use the computer to play his Star Wars Game.
