01 coilover top hats/mounts
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1bad2k, Jul 12, 2021.
  1. Jul 12, 2021 at 1:27 AM
    1bad2k
    1bad2k [OP] Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    What's up guys, I have a 2001 and bought the bilstein 6112 front kit for the truck but don't have the upper mounts. After spending a bunch of time searching and finding a bunch of contradictory info, I figured I'd just ask. Who has bought a upper mount/ top hat kit that works, and has the rubber spring isolator that goes under the top hat? I have seen the Monroe 904900, but it supposedly doesn't include that isolator and some other hardware. I've also seen the kyb sm5640 that does include those other parts, but supposedly doesn't fit. Anyone ordered a kit and it work for a first gen? Thanks for any help.
  2. Jul 12, 2021 at 1:57 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    The Monroe is what you want the kyb is 05+
    1bad2k[OP] likes this.
  3. Jul 12, 2021 at 2:03 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Awesome, thanks! Do you know of anyone that sells them with the needed bushings and hardware?
  4. Jul 12, 2021 at 2:10 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    The bottom bushing is built into the top hat, so you’ll use in order... rod adapter/lower washer included with the strut/top hat/upper bushing/upper washer/nut from strut.
    Your local auto parts store should have them in stock, go check um out.
    1bad2k[QUOTED][OP] likes this.
  5. Jul 12, 2021 at 2:11 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
