01 light switch ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mike sacc, Feb 27, 2011.
  1. Feb 27, 2011 at 8:03 AM
    mike sacc
    mike sacc [OP] Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    my 01 has a light switch to the left of the steering wheel that doesnt seam to work anything. its afactory switch, the light on the switch comes on when pushed but thats it. had the truck since october and it doesnt appear that the previose owner tinkerd withANYTHING. i would appreciate any info. thanks.
  2. Feb 27, 2011 at 1:10 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If the switch is clearly marked as being for lights, it's not a factory / OEM item.
    My guess would be that it's a 4Runner fog lamp switch the previous owner installed to control some lights. The 4Runner switches fit the Taco dash slots and look stock, so they're a favorite switch to use when adding aftermarket lights.
  3. Feb 27, 2011 at 1:14 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
  4. Feb 27, 2011 at 1:16 PM
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    Possibly clutch cancel start button? Pic would help
  5. Feb 27, 2011 at 1:16 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x2
  6. Feb 27, 2011 at 1:23 PM
    ARC
    ARC Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    bet you guessed it. I had the same thought.
  7. Feb 27, 2011 at 1:57 PM
    mike sacc
    r.i.
    its not the clutch cancel switch . i' ll work on as pic thanks.
  8. Feb 27, 2011 at 3:52 PM
    mike sacc
    r.i.
    here is a pic
  9. Feb 27, 2011 at 3:56 PM
    NelsonTacoma
    Tucson, AZ
    That's not a stock switch. Probably used to run off-road lights or something. I would get under the dash and follow the wires to see where they go.
  10. Feb 27, 2011 at 4:45 PM
    mike sacc
    r.i.
    i doo have a bull bar but i dont se anything going to it. i must investigate.
  11. Feb 27, 2011 at 4:56 PM
    Pingo
    North Pole, AK
    Damn I definitely thought I was going to be right. x2 on following it to see where it goes, probably use to be some off road lights that got taken off before you bought it
  12. Feb 27, 2011 at 5:03 PM
    mike sacc
    r.i.
    thought it was a factory switch, looked similar to the switch in my 09. silly me the switch in the 09 doesnt illuminate when its suppose to be on and i bought that new .like i said when i joined up, i like the 01 much better..
