01 Tacoma power adders
Discussion in '1st Gen. Tacomas (1995-2004)' started by HenrySR5, Oct 15, 2023.
  1. Oct 15, 2023 at 6:16 PM
    HenrySR5
    HenrySR5 [OP] Member
    2001 SR5 4X4 Tacoma lunar Mist Metalic
    I bought a 01 Tacoma SR5 4x4 with the 5vz-fe engine. I was wondering if there were any power adders that I could add to it to gain some performance. I am not really looking to buy the TRD supercharger.
  2. Oct 15, 2023 at 6:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There are none that make any power “cheap”.
    You’re a 4x4, so even a regear is going to expensive.
    You have 2 option.
    Do nothing and enjoy the truck for what it is.
    Or spend money. Lots of money.
    BTW, Welcome to TacomaWorld.
    Nessal and HenrySR5[OP] like this.
  3. Oct 15, 2023 at 6:29 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Nope, pretty much just forced induction. There's no tuner for the factory ECU either, so you'd have to go standalone if you want to gain power that way.
    Deckplate mod might gain you 5HP if you're lucky though, but you're best off just making sure all the maintenance items are up to date and fluids are the proper ones.
  4. Oct 15, 2023 at 6:31 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
  5. Oct 15, 2023 at 6:33 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  6. Oct 15, 2023 at 6:35 PM
    tacoman2001$
    I had mine powder-coated so that's another 5hp. Its a 2x if you add it to a supercahrger
  7. Oct 16, 2023 at 12:31 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
  8. Oct 16, 2023 at 5:43 AM
    HenrySR5
    How would the Diablo tuner work on the Tacoma, isn’t the ecu non tunable
  9. Oct 16, 2023 at 8:00 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I moved my seat closer to the gas pedal, butt dyno estimated +5 HP
    Bonus, this also improves brake performance.
  10. Oct 16, 2023 at 10:08 AM
    Wyoming
    Wyoming Well-Known Member
    Alex
    Nunya, WY
    03 Lunar TRD 4x4 Xtracab
    sunflower seeds under the seat
  11. Oct 16, 2023 at 10:11 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It wouldn’t, people are just being silly.
    Kwikvette likes this.
  12. Oct 16, 2023 at 7:44 PM
    HenrySR5
    That’s what I was thinking just wasn’t sure.
  13. Oct 16, 2023 at 7:45 PM
    HenrySR5
    Are there any good turbo kits
  14. Oct 16, 2023 at 9:54 PM
    jjackson27
    jjackson27 Member
    Seems like the cx turbo kit is the most common one
  15. Oct 16, 2023 at 9:57 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    It's the only one I'm aware of for the 5VZ. Time saver for sure, but by no means an all in one solution
  16. Oct 16, 2023 at 10:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How deep are your pockets?
  17. Oct 16, 2023 at 11:02 PM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    I'm not sure which is faster, but I've always been of the opinion that two stripes down the center of the car made it faster than one (late 90s Viper vs. Camaro). Not sure about that dyno stats on a single offset stripe though... :rolleyes:
    rocknbil and treyus30 like this.
  18. Oct 16, 2023 at 11:24 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    What about two at the same time?
  19. Oct 16, 2023 at 11:27 PM
    e.deCastro
    Eric
    San Diego
    I don’t know what a Diablo tuner is but I’m assuming it’s a piggy back. I have a URD piggy back and I can control afr and timing. But it’s only tricking the ECU and not tuning the ECU but the piggy back.
  20. Oct 21, 2023 at 3:33 PM
    HenrySR5
    Yeah I guess it would be better for power to 5.7 tundra swap it than to turbo it
