01 Tacoma Shifter Shake
Discussion in '1st Gen. Tacomas (1995-2004)' started by JCH, May 15, 2013.
  1. May 15, 2013 at 5:52 PM
    JCH
    JCH [OP] Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    Hey guys so here is a video of the shaking my shifter does. Sorry about the bad angle. The video is in fifth gear and I think somewhere around 60-70 mph. The rattling isn't the shifter its some stuff in my cup holder. Do you guys think this is normal? I was kinda thinking U-joints or maybe the transmission mount could be contributing. Thanks for the help.
    http://www.youtube.com/watch?v=uHveRnFKFss
  2. May 15, 2013 at 6:50 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
  3. May 15, 2013 at 8:10 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    My shifters shake a little, but only when going over rough roads. On a smooth highway they don't shake at all. You didn't write how many miles your ride has...
    1998, 69000 miles
  4. May 15, 2013 at 8:27 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
  5. May 15, 2013 at 8:28 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    120,000 Miles. I was the highway when i video'd this the road is pretty smooth but not perfect.
  6. May 15, 2013 at 9:35 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Hows the rest of the truck in terms of shaking? I had the same problem, thought it was the shifter seats which I heard is common. Turned out to be tire balance.
  7. May 15, 2013 at 9:43 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    I think the tires actually do need rebalanced. I have felt the wheel shake like the tires are out of balance but it wasn't really doing it while I took the video, I suppose it still could be it though.
  8. May 15, 2013 at 9:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Seems excessive for a smooth road. My 2nd gen doesn't move much at all. My 86 4x4 I don't believe moved that much either.
  9. May 16, 2013 at 6:51 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine probably shook about like that when I had my old tires. Hell my 4wd shifter shook itself right out of existence! (JK I never had a 4x4 shifter :( )They kinda slowly got out of balance and I didn't really notice because of how gradual it happened. Got new tires last week, holy crap! This thing is like a cadillac now
  10. May 16, 2013 at 8:20 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The tranny shifter seems to be shaking more than the TC shifter. One possible culprit is the shifter nylon bushing, where it connects to the shifter forks (?). Is the shifting a bit sloppy?
    On older pickups, this is replaceable. Marlin sells the bushings as well as the dealer. I replaced mine on my '84 4Runner. Access to the bushing is thru the top of the tranny. Fairly easy job with normal hand tools. Tacoma trannies may be the same.
  11. May 16, 2013 at 9:15 AM
    Bmangdog
    Bmangdog Active Member
    Brady
    Rogue River
    2000 Tacoma Ex Cab 3.4L 5 Spd
    Ive got 170000 on mine.... Doesnt shake like that at all. :crazy:
  12. May 16, 2013 at 9:20 AM
    Madjik_Man
    Colorado Front Range
    I have the shifter wiggle when in 5th gear and on the throttle but nothing like that. That seems to be pretty wild.
  13. May 16, 2013 at 10:32 AM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    So yesterday I went and checked out the transmission mount. The rubber itself really doesn't look that bad. There are some hairline cracks in it towards the bottom though. Also I noticed that just pushing on the transmission by hand the mount rubber on the mount will move very slightly. Does it sound like the mount is bad? Another thing that makes me think mounts is that on a 2-3 shift I you don't balance the pedals just right there is a clunk sound when you let the clutch out and you can feel it in the shifter. Thanks again.
  14. May 16, 2013 at 4:22 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Mine looks similar to yours actually and I just posted a thread last week about it. Mine only happens in 5th, but is much more consistent, while it only completely stops shaking in 5th while decelerating. As soon as the gas is pressed it gets right back to "normal". I'm leaning towards the bushing...just because it's the cheapest.
    Sub'd
  15. May 23, 2013 at 6:52 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Anybody know about that clunk on the 2-3 shift I was talking about?
  16. May 23, 2013 at 8:10 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My guess would be that the driveshaft slip joint needs to be greased. My 86 used to do that, the 2006 hasn't done it yet, but it doesn't have a lot of miles on it either.
  17. May 23, 2013 at 10:37 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Mine does this, but I have a HD Transfercase mount.
  18. May 24, 2013 at 1:27 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Well I went out to try and grease the slip joint an discovered something. As I was putting grease in I saw it was just coming out on the other side of the grease zerk. Comparing it to my dads 05 tundra it looks like I'm missing the "cap" on the slip joint that faces the u joint. So the slip joint isn't sealed up at all. Anybody know where I could get this cap?
  19. May 26, 2013 at 10:36 AM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    So It looks like its called a freeze plug. Does anybody know what size?
  20. May 27, 2013 at 6:46 AM
    CliffordBRD
    Cliff
    Tampa, FL
    If you fill up the zerk it'll overflow whenever it is full...If I'm portraying this right....got a pic?
    Does this happen on in certain gears?
