01 Tacoma v6 204k. Recommended maintanence?
Discussion in 'Technical Chat' started by Bren, Nov 19, 2013.
  1. Nov 19, 2013 at 5:46 PM
    Bren
    Bren [OP] Well-Known Member
    CT
    01 Tacoma SR5 V6
    I just bought it and I am dropping it off for an oil change. Is there anything I should have my mechanic check for while it's there? I obviously know the timing belt, but is there anything else? Thanks!
  2. Nov 29, 2013 at 6:55 AM
    Nitrofish88
    Nitrofish88 Active Member
    Zach
    Houston
    02' TRD Pre-Runner V-6
    Only wheels and tires... For now... Muahahaha!!!
    Good question, I just bought an 02 with now 204k myself. I can almost guarantee any kind of tune up maintenance you can do will improve your ride. Timing belt and water pump are probably a must. I found a tune up kit on ebay for about a hundred bucks... here's the link ----> http://www.ebay.com/itm/OEM-NGK-Wir...2002|Model:Tacoma&hash=item5d38028bd0&vxp=mtr
    They kinda got my order botched but I ended up with enough stuff for another 2 tune ups lol.
  3. Nov 30, 2013 at 5:53 AM
    Bren
    CT
    01 Tacoma SR5 V6
    Thanks for the reply. I'm changing the rear and front diff oil monday and I bought a new engine air filter. I'm also going to do the fuel filter, radiator fluid, transfer case oil, tranny, oil, spark plugs, and anything else I can think of. I'm impressed with how well it runs, but I'm not getting great gas mileage and I hope with these things, I can improve it my 2 mpg. I'm getting between 15-17 mpg. One time I got 12.5, but I was doing a lot of stop and go, so hopefully that was the case. Congratulations on your purchase!
  4. Dec 1, 2013 at 9:36 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
  5. Dec 2, 2013 at 9:12 AM
    Bren
    CT
    01 Tacoma SR5 V6
    Thanks for the link. Seems like a good price. I'm gonna have to watch that on my ebay until I got the money.
  6. Dec 2, 2013 at 9:24 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Go synthetic in the diffs too
  7. Dec 2, 2013 at 9:26 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    Look into a pcv and fuel filter as well.
  8. Dec 2, 2013 at 4:44 PM
    Bren
    CT
    01 Tacoma SR5 V6
    Too late for the diffs. I already put in conventional, oh well. I'll have to do synthetic next time. I'm going to do the fuel filter within the next two weeks.
  9. Dec 2, 2013 at 6:02 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Oops, just noticed that you did already mention the fuel filter. PCV valve for sure and maybe run some Techron-like additive through the tank and run Seafoam through the vacuum line.
  10. Dec 2, 2013 at 7:01 PM
    Bren
    CT
    01 Tacoma SR5 V6
    I'll buy the pcv valve from the dealer tomorrow. Do you know if it comes with the rubber grommet at the bottom? I've always been leery about those fuel additives and sea foam. I was always told not to put anything but oil and gas in an engine.
  11. Dec 3, 2013 at 4:18 PM
    Bren
    CT
    01 Tacoma SR5 V6
    Just replaced the pcv valve. The old one was all gunked up, deff needed one. I also ordered a new pcv valve hose because it was all rotted. After changing the diff oil, I did notice that the truck felt like it wasn't working as hard to move itself and I have seen improved gas mileage of about 2 . I will calculate my mpg with the new pcv valve installed and see what happens.
  12. Dec 3, 2013 at 6:32 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    I was always a bit leery but once I hit 100,000+ I decided to run a quality fuel system cleaner through at each oil change and I tried Seafoam for the first time fairly recently. Results vary, but it seems like it helps, I like it... even if it's mostly psychological :rolleyes:
  13. Dec 4, 2013 at 7:42 PM
    Bren
    CT
    01 Tacoma SR5 V6
    Just calculated my city mpg and with the air filter, new diff oil and pcv valve, I have went from 14-15 to 17.5 and that 17.5 was with a heavier foot than when I was getting 14, so I'm pretty pleased.:D I expect to get atleast 20 mpg on the highway.
  14. Dec 4, 2013 at 8:45 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Nice, good to hear. I get about 21mpg hwy with my 2000 manual. And that's with 33" tires, lift, and an extra 350lbs+ tacked on. My truck is pretty well tuned... and I usually keep my tire psi a bit high and have a fairly light right foot.
  15. Dec 5, 2013 at 8:22 AM
    Bren
    CT
    01 Tacoma SR5 V6
    Wow 21 mpg, that's pretty impressive. I'm going to do my spark plugs next. After 200k on the originals, they are in need for some new ones. I was contemplating doing them myself after finding a really good writeup, but I foresee a disaster because of how long they have been in there, so I think I'll have my mechanic do it and let him deal with it. Do you know roughly how much that would cost for labor, not including the cost of plugs? I'm going to get the oem plugs, but I heard that half of them are denso and the other half are ngk. Should I stick with that combo or can I buy 6 of the same?
  16. Dec 5, 2013 at 9:59 AM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    No idea on labor... I'd try it yourself, chances are none are seized. NKG and Denso are both good, but I'd get 6 of the same.
  17. Dec 7, 2013 at 9:53 AM
    Bren
    CT
    01 Tacoma SR5 V6
    Ok I'll give it a shot. Also, I just put a new hose on the pcv valve and I didn't notice before but is this normal? When you are putting the new pcv valve in and when you feel and hear that little pop, is it normal for the valve to wiggle around?
  18. Dec 11, 2013 at 4:24 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    :eek:
    Maybe take it out and compare it to the old one, make sure you didn't break it.
  19. Dec 11, 2013 at 4:33 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    21 MPG is not hard to achieve, if you are in a big city with lots of stoplights and whatever, then it will suffer...I actually can get about 23 MPG on the freeway, I have jack the tire pressures up a bit and I will kinda hyper mile behind big rigs that are hauling ass, and I got an Ultra gauge, really helps understanding how your right foot is operating....every little bit helps, especially with cross country trips, which I do every year for 6 weeks of vacation and visiting in California...
  20. Dec 11, 2013 at 5:02 PM
    Nitrofish88
    Zach
    Houston
    Man, I bought the wrong kit. lol
