01997 Tacoma SX v6 5sp TVS1320 supercharged 300 HP! Haltech ECU, Reg Cab 800,000 Build
Discussion in '1st Gen. Builds (1995-2004)' started by 1997tacomav6, Mar 1, 2017.
  1. Mar 1, 2017 at 8:28 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    https://m.youtube.com/watch?v=bi8BJ5L5gLA
    So I have had a lot of people suggest I create a build thread so here goes.
    Bought this little truck new in 1997 and had to wait for it to come in with the v6 option in the reg cab in white with 5 speed. Paid around 16,000 plus 2500.00 for the supercharger, was an expensive truck back in 1997.
    My first car was a jeep cj5 with a chev 350 when I was 16, that's where it started.
    I have had two 1970 and 1971 240z Datsun, 1963 corvette spit window, 1965 Porsche speedster, 1986 porche 944 turbo, Audi A4 turbo, and two chey Tahoe,
    And a 1969 jaguar 2 seater XKE.
    The most fun and reliable of all those cars is the Tacoma, a truck you can drive the wheels off
    with little repairs and a ton of power with the supercharger.
    1997 Tacoma, SX package, v6, 4x4
    The reg cab with a 3.4 v6 was made in 1995.5-1997 in the 4x4 verson. In 1997 they upgraded the ECU and that’s when the TRD supercharger was first made, so the trd supercharger was only available for the reg cab for that year in 1997 only,
    1998 forward the v6 was not available anymore in the reg cab. The ECU does not work with the supercharger for the 1995.5-1996 v6 years. So there are very few v6 3.4 trucks with a trd supercharger in the reg cab design that are original.
    A rare truck in the v6 reg cab with a supercharger with 10 pounds of boost with methanol injection, around 300hp crank.
    EDIT: UPDATE 9-20-2020
    Now 300 Hp and 325 torque at 12 pounds of boost at the rear wheel.
    My boost varies from 10-12 pounds depending on heat, weather, summer or winter. Typical it’s at 11-11.5
    Rear wheel Dyno shows 270 torque 245 hp with 9.80 pounds of boost at 6000 feet,
    At sea leave the boost and hp and torque might be higher.
    (Update 1-1-2020
    Boost is at 11 pounds, rear wheel hp is 275 and torque 285 with methonal, 2” pulley and ported supercharger.
    Boost fluctuates between 11-12 pounds depending on weather, temperature, humidity.) at 6000 feet.
    If you have ping issues, look into a methanol injection kit, might be your answer!!
    (Methanol kit will lower supercharger temps 100 degrees,
    https://www.tacomaworld.com/threads/show-me-your-water-meth-setups-on-the-5vz-fe.481407/
    Will add octane to 115, will correct the AFR lean out from pinging,
    Can run a smaller pulley without pining or lean out,
    No need to install high flow fuel pump or larger injectors or an intercooler,
    Also you get a steam cleared Intake to eliminate carbon build up,
    Lowers supercharger temps by 100 degrees, means longer supercharger life for bearings and nose seal that fail because of high temps, each one pound of boost
    adds 10 degrees to the supercharger, so this is a perfect solution, no heat soaked supercharger anymore)
    Wish I had done this upgrade years ago @6000 feet
    a weight of only 3300 pounds
    Truck has original paint except the hood because of the scoop
    Truck has all original running gear except engine
    Never been in an accident
    Colorado Truck,
    So what I have and have done is as follows.
    Original motor was supercharged its whole life for 489,000 miles till it had head gasket issues.
    Was cheaper to replace the old motor with a low mileage newer motor than to fix cracked head and gaskets.
    Replaced original motor with a 2004 motor that had around 100,000 miles
    https://www.tacomaworld.com/threads...89-000-miles-repair-or-replace-engine.397363/
    Replaced every outside seal, from main seals to valve covers gaskets etc and bearings for timing belt and water pump relateted items and knock sensors and harness, all clutch parts before installing the newer engine.
    Added grey TRD supercharger in 1998, rebuild it each 150,000 miles, now has 600,000 miles on original supercharger
    Added all Gates belts including Gates supercharger belt
    Added SUPERCHARGER emblems tags to top of rear bed of truck
    Added snow injection methanol progressive kit, July 2017, 526,000 miles
    Added green light on boost guage for when methonal when spraying + Amber for low fluid
    Added "METHANOL ONLY" windshield cap made of brushed aluminum inscribed in red paint
    Added "METHANOL INJECTED" timing cover emblem made of brushed aluminum inscribed in red paint.
    Added a 4Runner hood scoop that was cut into the original hood as functional
    https://www.tacomaworld.com/threads...into-1997-tacoma-for-trd-supercharger.452234/
    Added hood struts, red line,
    Added KN cold air intake, (have not bought an air cleaner in 525,000 miles)
    Did the air intake elbow conversion which actually makes a nice difference for the KN system to work better for the supercharger
    Added air conditioning to the truck
    Added Smitty built front push bar
    Added viper alarm system with electric locks and remote
    Added 2” Pulley
    Added Pulleyboy supercharger pulley
    Added DENSO IK22 531
    plugs
    Added TRD alloy oil cap
    Added dick cepek rims and locks
    Added Dyno pro ATM tires 31x15LT(Last 100k miles)
    Addead boost guage on pillar of truck
    Added fixed gps garman on top of steering column
    Added gentex rear view 453 mirror with, temp, compass, auto dim function, Homelink
    https://www.tacomaworld.com/threads...mp-compass-auto-dimming.553041/#post-17999152
    Added Honda 76810-TK8–A01 windshield spray pattern nozzels
    https://www.tacomaworld.com/threads/windshield-sprayer-upgrade.542571/
    Added 4Runner dual console over head lights
    Added LED bulbs for over head console
    Added 2004 door mirrors
    Added 4Runner speaker pod for tweeter
    Added Alpine head unit with satilite reciever
    Added 300 watt sub amp
    Added 12" kicker sub speaker and kicker enclosure
    Added polk audio split speaker, tweeters in doors and tweeter pods
    Added Corbeau LG1 seats with sliders and new seat belts
    Added Leather TRD shit knob black
    Added black 4Runner low range shift knob to match black shift knob
    Added Tinted windows all sides
    5 speed standard transmission
    Added Amsoil Extreme oil for diff and redline 4 transmission, original trans and diff at 530,000
    Added magnet phone mount
    Added Door sills covers
    Added side nerf bars
    Added 4 Cadillac horns, no more beep beep
    Added red top optima battery
    Added spray in X-LINER for the bed
    Added TRD fender extenders(1st style, made of fiberglass)
    Added class V towing hitch for towing double axle enclosed 14 foot trailer
    Added electric towing brake module
    Added, add a leaf springs for towing
    Added stainless steel hitch reciever and ball, no rust to deal with
    Added 550,000 miles since new
    Added Tacoma rubber mats"
    Added Tacoma cloth mats
    Added EBC high carbon rotors
    Added green stuff EBC 7000 series brake pads
    Added 2012 rear tail gate TACOMA badge
    Added cat back exhaust
    Added free flowing exhaust muffler, nice little rumble sound
    Added SS exhaust tip
    Added TRD Stainless steel skid plate
    Added Raised dual exhaust flush with body line by the exhaust tip
    every exhaust pipe line should be nice and tight like this
    Added TRD battery hold down bracket
    Added Scanguage II
    Added Volvo MAF tube non restrictive swap
    Added DESNO quick change port with Volvo MAF
    Added stainless steel brake lines front and back, LCE
    Added Innovation digital combo boost and AFR Gauge.
    Added Custom made aluminum Extruded design radiator
    Added wireless tire pressure and temperature remote kit
    Added the throttle body bored out for more air flow
    Added having the supercharger ported inlet and outlet,
    Added DENSO 105 amp alternator
    Added Doug Thorley headers
    Added custom dual exhaust
    Added king coils, struts in the front.
    Added bilstien 5100 in the rear.
    Added custom leather steering wheel
    Added leather gear shift boot
    Added electrical antenna
    Added Dual shiftglow temp gauge for input and output temps of supercharger
    Added Osram 860 lm =35 watt=50 w bulbs for rear brake lights
    Added LED smoked rear lens Anzo
    Added LEDs for 3rd brake light
    Added smoked 3rd brake light lens
    Added rear backup camera
    Added projector headlights
    Added custom leather steering wheel wrap
    Added Lexus front drain differential plug
    Added powder coated valve covers
    6kax190 .335” 6kak190
    Added retrofit projector HID MORIMOTO MINI H1. 7.0 Headlights
    https://www.tacomaworld.com/threads...on-morimoto-mini-h1-7-0.643068/#post-22280459
    Installed new supercharger into new truck in 1998
    Grey supercharger 1st gen with 550,000 on supercharger
    Added butt screw on top of snout so oil can be changed in 5 minutes WITHOUT removing the supercharger.
    Oil change every 40,000 miles now.
    Complete rebuild every 150,000, includes new rotor pack plate, recoating rotors, double lip rear seals, high temp double lip nose seal.
    Running at 6000 to 12,000 feet.
    With 2.2 or 2.1 pulley slight to no ping issues at 7.5 pounds of boost with 2.1.
    With 2" pulley 10 pounds of booost there definitely pinging so added
    Snow methanol kit stage II progressive using the one gallon wiper reservoir that eliminated the ping.
    2" pulley engine needs methonal spray to come on at 4.5 pounds of boost up for me
    Methonal nozzel size is a number 1, and I get about 1500 miles per gallon, with perfect AFR.
    Number one nozzel tends to plug up after 10,000 miles because it's so small. Easy to just replace it with a new one at 15.00 and cooling is not a great as the number 2 nozzel.
    Number 2 nozzel definitely sprays more and a big difference in supercharger temps,cooling effects
    I can place my hand on the supercharger without it being too hot even after a hard run.
    So I run the number 1 nozzel for winter and number 2 nozzel for summer heat.
    Number 2 nozzel gets about 400-600 miles per gallon depending on driving. System uses methonal
    after 4.5 pounds of boost only.
    If you run out of methanol it's no issues driving it under the boost level of 4.5. Using windshield fluid that's 20 negative if needed is ok, but is not distilled water,
    Using a #2 nozzel is best.
    I would suggest inspecting the nozzel if it's a number 1 size and or cleaning it each 10,000 miles, takes 5 minutes to do.
    The methonal system works fantastic for me but is higher maintenance, it addresses the issues of heat soaked supercharger and because there is no intercooler for these superchargers It definitely can reduce temps 100 degrees.
    Remember each added pound of boost adds 10 degrees of heat!
    My power gains are pretty consistent regardless of the outside temperature now.
    If I don't want to deal with using the methonal kit for what ever reason maybe
    across country trip or whatever I always have the option of just putting the 2.1 pulley back on as I have no ping issues with the 2.1 or 2.2 pulley at 6000-12000 feet.
    Every engine 3,4 responds differently to ping and definitely to this setup so this is
    what works perfectly for me with zero issues at 6000 feet up to 12,000 in Colorado.
    Your results my be different. Some people will have to go the 7th injection route,some will need to replace the fuel pump. But only the methanol kit can lower supercharger temperatures by 100 degrees.
    Please note,
    There are some 3.4 motors that ping a lot and some that don't ping at all or very little under the exact same setups and altitude. No one knows why this is.
    I'm lucky and I have an engine that doesn't like ping, my 1997 motor did ping
    abit while the replacement 2004 motor doesn't ping.
    Stock ECU
    No piggy back
    No fuel mod
    2004 injectors, abit larger than 1997
    KN airfilter
    Elbow mod
    2" steel pulley, not soft aluminum
    URD pulleys are made of soft aluminum and will wear and start slipping around 25,000 miles and will need to be replaced. What happens is the center ribs wear down and loose grip and the belt then rides on the sides of the pulley ears and slip on high load. URD uses a protective coating but will only last a short time.
    High temp nose seal
    DENSO IK22 5310 plugs
    Pillar boost guage
    Methonal green light indicator,lights when pump is spraying at 4.5 pounds and up next to boost guage
    Methonal low level light sensor next to boost guage
    TRUCK is where I want it to be as a daily driver for now!!! I think, haha not really :)
    https://m.youtube.com/watch?v=RuwVemwhXs4
    https://m.youtube.com/watch?feature=youtu.be&v=TAc7AHzn9-s
    https://m.youtube.com/watch?v=HkPFZWd8wj4
    BACK IN 1997 WHEN SHE WAS NEW, 1ST MOUNTAIN TRIP AT 12,000 FEET
    Cadillac horns above
    Had to add this photo of my new project, 1969 XKE JAG being trailered home
    My new project:)
    Finished the Jag 2 seater!!!
    All spit shined up
    Headers, powder coated valve covers
    King shocks, coils, geartek splash guards
    Custom Aluminum Extruded core radiator, ported supercharger
    Scanguage, Glowshift supercharger temp gauge
    DUAL EXHAUST
    Custom wrapped my wheel with seams at 10-2 o’clock
    October 1st, 2020
    ALMOST 13 pounds of boost,
    Now pushing over 300hp rear wheel numbers.
  2. Mar 1, 2017 at 8:29 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Awesome truck! :thumbsup:
  3. Mar 1, 2017 at 8:42 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Subbed!! Finally one of my favorite trucks here in tw has a build thread
  4. Mar 1, 2017 at 8:50 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    This is amazing.
    1997tacomav6[OP] likes this.
  5. Mar 1, 2017 at 8:56 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    This is also one of my favorite trucks here.
    big_jarv and 1997tacomav6[OP] like this.
  6. Mar 1, 2017 at 9:34 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Hey buddy! Hope the motor is treating you well!! Trucks looking good. Love the Corbeaus!
  7. Mar 2, 2017 at 9:49 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    sub'd for a great truck and owner
  8. Mar 4, 2017 at 12:13 PM
    04yota
    Angelo
    Central New Jersey
    Hey John what oil have you used throughout the life of your taco? Synthetic or regular and how often was it changed
    Any maintenance regimen you followed?
  9. Mar 4, 2017 at 12:16 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Love this truck. Glad you finally made a build!
  10. Mar 4, 2017 at 3:41 PM
    1997tacomav6
    Denver
    Oil changes like clock work every 3000 miles by the dealer, drive train is all original nothing rebuilt,
    running amsoil in the diff, front and rear, trans, and transfer case every 50,000 miles change
    GQ7227 and JuanitoBonito like this.
  11. Mar 4, 2017 at 3:49 PM
    hitech
    hitech Well-Known Member
    Blair
    Southern MD
    2014 MGM DCSB TRD Sport 4x4
    Just some dumb regular crap everyone else has
    Wow! very nice truck. nice to see someone keeping their truck 20+ years and it still looks and runs awesome.
  12. Mar 4, 2017 at 3:55 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Sweet! Those seats look awesome. What did it take to fit them?
  13. Mar 4, 2017 at 3:59 PM
    1997tacomav6
    Denver
    To much, lol, 800.00 for seats plus 210.00 for track sliders plus 75.00 for shipping, after 500,000 miles
    bouncing and sliding in the 4 runner seats I decided it was time. Now the interior smells new because of the new seat, :) and these seat fit like a glove and recline,
    Took an hour to do the swap with these LG1
  14. Mar 4, 2017 at 4:20 PM
    04yota
    Angelo
    Central New Jersey
    So oil change at the dealer :eek:
    They are prolly using conventional oil! So what's the hype about synthetics then lol. I mean aside from the extended oil change intervals
    GQ7227 likes this.
  15. Mar 4, 2017 at 4:24 PM
    1997tacomav6
    Denver
    I've never used synthetic oil for the engine, synthetic oil you change at 5,000 miles as you know, the oil they use at my dealership seems to work just fine.
    Old engine even at 489,000 never consumed any oil,just fell to the head gasket issues.
    GQ7227 and 04yota[QUOTED] like this.
  16. Mar 6, 2017 at 2:34 PM
    BestWest
    BestWest New Member
    I hope my '17 holds up for this long....and looks as good when we hit 500k miles. I'll set a reminder to post a build thread in 2037!!
    dborrer, GQ7227, 04yota and 1 other person like this.
  17. Mar 9, 2017 at 8:46 PM
    rj95lss
    rj95lss Well-Known Member
    Robert
    Pinelands, NJ
    '92 HZJ73 - 1HZ diesel RHD
    SOA with OME, Lockers, 37's, ARB
    Do you know which part#'s you used for the Corbeau slider brackets? I am only showing brackets on their site for the bench seats or the 60/40 split. But my '96 came with buckets like your '97.
  18. Mar 9, 2017 at 8:56 PM
    1997tacomav6
    Denver
    This is a copy of my invoice, you can call them also if you need.
    Toyota Tacoma (OEM Bucket,60/40) 95-04 Seat Brackets E1104/1105-E1104-E1105 1 $210.00
    Seat Bracket Selection
    1 x Driver Seat Bracket with Slider $105.00 E1104
    1 x Passenger Seat Bracket with Slider $105.00 E1105
    2002Tacoma4x4 likes this.
  19. Mar 9, 2017 at 9:23 PM
    rj95lss
    Robert
    Pinelands, NJ
    Awesome thanks! I just figured out the factory mounting locations are the same for the buckets and the 60/40. Bench is different.
  20. Mar 9, 2017 at 9:39 PM
    1997tacomav6
    Denver
    Perfect, what seats are you think of getting? Whatever it's worth I would highly recommend test driving whatever seat you're thinking of buying, I was originally going with the GTS II until I sat in the LG1 seats,
