'02 Automatic Trany Fluid Capacity
Discussion in '1st Gen. Tacomas (1995-2004)' started by bajaracer, Oct 6, 2008.
  1. Oct 6, 2008 at 3:50 PM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    I have an '01 3.4 Automatic Prerunner and want to change the tranny fluid. Seems pretty simple. My question is how much do you put in after you drain iti? 4, 5, 6 quarts? Thank you.
  2. Oct 6, 2008 at 3:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i drained my 04.....it was about 5 quarts or so(but then again....i dropped the pan and cleaned the filter too), so yours may not be quite that much. i would get 5 quarts of the toyota type t-iv(t4) to be on the safe side.
  3. Oct 6, 2008 at 3:57 PM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    I have my Haynes book out. Its saying 1.7 quarts for automatic... I know when i did my manual transmission it was very close to book capacity.
  4. Oct 6, 2008 at 4:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i did mine, i drained everything into a mobil1 5 quart jug, and it was right near the top of that when i dropped my pan to clean the filter.
  5. Oct 6, 2008 at 4:16 PM
    TengoTaco
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    Does the automatic transmission have a fill bolt or do you pour it in from the dipstick hole?
    Thats odd we are so far apart.
    Baja your safe buying more than you need for the transmission b/c if you dont use it all you can do the differential.
  6. Oct 6, 2008 at 4:48 PM
    bajaracer
    Charly
    Chandler
    i bought 5 quarts from the dealer,, a bit expensive at 6.50 a quart. im going to do tonight.
    ps i have a second home un Mexicali.
  7. Oct 6, 2008 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you fill from the dip stick, and for the diffs.........75w90 is called for.
