02 Double Cab Build
Discussion in '1st Gen. Builds (1995-2004)' started by whitetoblack, Mar 13, 2012.
  1. Mar 13, 2012 at 3:21 AM
    whitetoblack
    whitetoblack [OP] ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    http://youtu.be/6thim3EY9Dg
    http://youtu.be/g3Oufhv3Q0s
    http://youtu.be/pPR27HfoC6c
    Modifications:
    Cosmetic:
    Fiberwerx 1 Piece 2nd Gen Conversion Clip
    Glassworks 6" Bedsides w/LED taillights
    Front and Rear tube bumpers
    3 LED Rear Light Box
    Vinyl Flooring
    180W LED Light Bar
    240W LED Roof Bar
    Snugtop Camper Shell
    Front Suspension: Bumped/Strapped 16" travel
    Custom 6.5 over kit built by Johnny Branch
    2.5x10" King Dual Rate Coilovers
    2.0x2.5" King Hydraulic Bump Stops
    Upper arm gussets
    Plated coil bucket and frame
    Plated and tubed shock hoops with Engine Cage
    Solid mounted Lower Arms/Heimed Upper Arms
    Solid Motor Mounts
    Solid/Boxed Transmission Mount
    Rear Suspension: Bumped/Strapped 18.5" of travel
    Giant 64" Link Killer Kit
    King 2.5"x16" Triple Bypasses
    Tundra Axle
    Frame Plating
    All fabrication done by EJV Fab
    Stereo:
    Jensen 7" head unit
    Alpine Type R door speakers
    600 watt Alpine 4 channel amp
    Alpine Type R 10" Sub
    1500 wattt Alpine monochannel amp
    Wheels and Tires:
    MB Motorsports Machined Aluminum Rims 17"x9"
    Toyo Open Country MT 35"x12.5"
    Next purchases:
    Internal Roll Cage
    Well been on this site for a while now never thought to do a build thread but here it goes. The truck has changed tremendously since I bought it, for better or worse depending on your style. Bought it back in April 2009 with 105k miles on the v6. Had a Fabtech lift kit with the coils cranked all the way, add a leaf in the rear, 17" Helo rims, 33x12.5 Durango Radial XTRs, Jensen Head Unit, and a blown stock sound system. Heres how she looked the day i got her.
    First off, the blown speakers were a critical part to replace. Instead of replacing them with new stock components, i decided to go with alpine Type R door speakers, a 4 channel 600 watt amp for the speakers, a 10 inch Alpine Type R Sub with a 1000 watt amp to power it. Ended up spending just under $1000 and was very happy with the way it works, very loud and extremely clear and crisp sound. I personally wasnt a big fan of the Helo rims and Durango tires, so I posted them for trade and traded straight across for a set of 15" Pro Comp Streetlocks and 31x10.5 BFG All Terrains.
    After throwing on the wheels and tires, i realized the 31s were not big enough. So, when they wore down after a few months, I bought a set of 33x10.5 All Terrains.
    As i started to run my truck more and more in the dirt, I realized that I was becoming more concerned with how well my truck rode. The first thing i did was swap out the Fabtech's with some Icon Coilovers and I was extremely satisfied with the improvement. The truck sat about and inch and a half lower but the ride was improved 100x.
    Next step was trying to get the rear up to speed. I picked up a set of Deaver j59s from a friend of mine. Even before swapping out shocks, I had already noticed another night and day difference in ride quality. At that point, another friend of mine was selling a set of 2.5x8" King Smooth Bodies with Remote Resi's for a price I could not turn down. I bought them and installed them with my Deavers.
    I was extremely satisfied with the ride quality on and offroad. At that point, I began piecing different things together that I thought added to the looks as well as improving different aspects of the truck. A friend of mine had been building bumpers for a number of people so I decided to have him build me a rear bumper. I was extremely satisfied with the results...
    At around the same time, I picked up a Defiant Light Bar and 2 ProComp 9" lights...
    Ran it like this for quite a while and was extremely happy. Then, as I continued to run it harder, I lost control in the dirt on my bald BFG's and crashed. The damage was limited to a dented hood, mangled bumper and light bar, broken grill, and dented core support...
    After that incident, I realized it was definitely time for new tires. Luckily, General had just released the Grabber Red Labels a couple weeks before and I picked up a set for an incredible deal.
    At this point, after taking my truck to the desert a number of times with it's current set up but not being able to keep up with all my friends rangers and such, I began saving for a new front end. While I was saving, I came across a set of brand new Glassworks Fenders for only $125 so I jumped at the deal and picked them up...
    Also picked up a dust light in the meantime...
    Decided to try a slightly different look that I had not seen before so i painted the rear fender flares white. I liked the way it turned out so they are staying that way for a while...
    After months of driving with a busted core support and hood, I finally saved up enough coin to get it all fixed. And now, this is how she sits...in my garage ready to get a full makeover.
    Picked up a long travel kit used on dezertrangers and some 2.5x10" Kings from a friend the real build begins.
    Added a couple more gussets to the coilbucket and shock mounts. Still gotta do a little more plating and run the tubes to the frame and over the engine.
    Bumper Started as well as resi’s mounted
    Bumper finished
    Mounted my license plate and light on a hinge to reveal the tow hitch easily
    Picked up some glassworks bedsides with the taillights section filled in ready for oval LEDs.
    Plated the backside of the shock tower and put a removable hoop over the motor.
    To be continued.....
    Yossarian, Dalandser and LBCDUBCAB01 like this.
  2. Mar 13, 2012 at 3:24 AM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    Nice pickup man!!
  3. Mar 13, 2012 at 12:32 PM
    travis9287
    travis9287 Well-Known Member
    Travis
    Tuscaloosa,AL
    2003 Tacoma, 2006 GX470, 2000 Jeep TJ, 1985 C10
    a lot lol
    Looks good man!
  4. Mar 13, 2012 at 1:17 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Awesome Runner!
  5. Mar 13, 2012 at 2:29 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I like it! Nice job...what do you plan on doing for the front bumper?
  6. Mar 13, 2012 at 2:52 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Sick truck!
  7. Mar 13, 2012 at 6:44 PM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    What size are the grabbers? Sick truck!!
  8. Mar 13, 2012 at 7:30 PM
    whitetoblack
    Tyler
    SoCal
    Picked up some vinyl flooring to replace the old shitty stock carpet.
    photobucket-8312-1348164619193_zpsdf8af8_87eb506f6231f345a83d71acea9848ed71dc8022.jpg
    Next I got some 17x9 machined aluminum wheels to clear the Tundra axle along with some 35x12.5 Grabber SCTs.
    photobucket-27522-1348164569480_zps53865_9eb1a72cb5356c5e0944cfbc2d69a8bd28e75374.jpg
    photobucket-31970-1348290436024_zps51ec1_6d15bf4d38fcf00f38409bfb4578acc85d06a047.jpg
    photobucket-37281-1348290454377_zpsdb4a3_197d594016068090cd835f9325d525164a2e7ceb.jpg
    photobucket-37685-1348512831706_zpscf4d3_9a3174040010994ddc0d4212ad6d50eb043f5260.jpg
    Threw a 32” LED light bar on the bumper.
    Installed some 2.0x2.5" stroke King Bump Stops
    Picked up Giant 64" Kit.
    Before
    photobucket-44045-1359686116020_zps76702_764ec75464094a7f15647d5e165967d3d5595fae.jpg
    After
    photobucket-40822-1359684082118_zps09eda_cfac40253f0f531ada762833292674a60fcf0406.jpg
    Bump
    photobucket-40175-1360030083306_zps58031_ac3bd7630ea26a466fd0842c72564278e09fc0ee.jpg
    Extra Pics and gussets
    photobucket-37147-1360030266681_zps0ed46_6e29d795c3146d47c48ce2e24844ba5128407111.jpg
    photobucket-7499-1360030208656_zps2a5f43_d487c61b1bc1d22a2583b8bbd05d3a9069cd1e1a.jpg
    photobucket-41419-1359772269059_zps6199e_6b19fb90d095d064bec8598bbcc8c35a2e742f4e.jpg
    photobucket-3426-1359772252459_zps9b1dde_75d13159b9796709ce19d59998076f8a7014eabb.jpg
    photobucket-3887-1359772298373_zpsb31dc2_307972b93baad1129869ea65749f10425b6786dd.jpg
    photobucket-23569-1359772440846_zps4e4af_a210414509515a6ea0662a55a9d804e4fe3f73f1.jpg
    photobucket-4651-1359858063966_zps606484_57f95e6c5ca7ef8fab14b5ea5278dce648d78462.jpg
    photobucket-41624-1359858097491_zpsab785_d8e7e78ca9eeb907a772be7e65a66cac98f552b4.jpg
    photobucket-3897-1359867727038_zps38f5ac_8be15ca6abf6a179aadeab93895d750d4d1afc34.jpg
    photobucket-47939-1359858082669_zps6dd90_f2ba7d62f8ed90dfa3863b77f36b798e280976c8.jpg
    photobucket-22604-1360128253581_zps0fb03_a899b91d53d872f4cf606b13d57cfc6d102791ba.jpg
    Next was the bedcage
    photobucket-3908-1360214032096_zpsd3e2a3_3ec432cb2b0706273b4e66ecacc1b9a8ffc26dcb.jpg
    photobucket-2754-1360214188906_zpscbccf4_854e5e402f3f0081f56b3cd959619a4eaa0aeb5c.jpg
    photobucket-34295-1360214288964_zps76d67_5e683aa47b630c065efea835e457795539994465.jpg
    photobucket-4706-1360358621902_zps382dbb_0e3e785fcc9e295a53926dfb67fcb3e2411a7e66.jpg
    photobucket-44465-1360358845221_zps67549_22aaa82eac4310b785ea584ca9690f30fc2c4cac.jpg
    photobucket-33199-1360359155517_zps3d2d4_098bf3f1dd0214ff215c63b101a8852b1590b8fd.jpg
    Took the truck out for its shakedown run and it works awesome! Had a few expected issues but nothing with the suspension or fab work.
    Ran it through a pretty rough section of the race course and it floated awesome over some 3-4 foot whoops and a couple heavy g-outs. Started hearing a clunk up front so we stopped and looked. One of the light bar bolts had shaken out and caused the bar to bounce and shear off the aluminum mounting bracket. The light itself was in good shape still so we yanked it off and pulled the corner lights out and continued on.
    Got a bunch more runs in and pulled off to check the bolts and everything was working great. The truck pulls through the whoops awesome without shuffling side to side at all.
    Screenshots952013-03-02-16-52-16_zps11b2_af81961a42d01687f56ff3eddfe2dff21b9f846e.jpg
    After that we made our way back towards the highway and hit the race course once again. It did awesome in the trenches with the ground clearance of the 35s. Through it up on a rock to check the shock clearance and it has no rubs whatsoever. After running it hard through the biggest stuff out there, we did a final check and found the stock steering rack bushings had blown out. Also, as expected the alignment cams had been knocked out of whack because they were not tacked. On top of that the driver side motor mount is blown.
    All in all it was an awesome shakedown. The frame did not flex like it used to and everything felt sturdy. Did not touch bump once in the rear!
    First thing I did when I got back was install poly bushings on the steering rack. It is an upgrade I would recommend to everyone. It made my steering feel a lot tighter and noticeably more responsive.
    Next step was to heim the upper arms to get rid of the weak stock alignment cams.
    The final step in addressing all the issues from the shakedown was solid motor mounts and boxed frame perches.
    Old motor mount
    New motor mounts
    Now that it is completely done suspension wise, I have just been driving the heck out of it and enjoying all of the time, cash, and hard work I have put into it.
    As mostof you know, it is never really over. At the moment I am saving for the cage and that will most likely be the last step for a long time. Stay tuned
    In the mean time before the cage, we figured might as well put the one piece conversion on. My friend said he wanted to try and mount it all to a sub-frame so that it could swing up and not have to come off everytime I need to do anything under the hood. Here is what he came up with. Extremely impressed with how it turned out considering he had never done this before!
  9. Mar 13, 2012 at 10:09 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Dont you have a LT kit ready to go on?
  10. Mar 13, 2012 at 11:00 PM
    whitetoblack
    Tyler
    SoCal
    Also picked up a mint condition Snugtop Camper Shell
    Yossarian likes this.
  11. Mar 14, 2012 at 9:34 PM
    whitetoblack
    Tyler
    SoCal
  12. Mar 14, 2012 at 9:36 PM
    Anthony250
    Anthony
    Rialto CA
    Your tire is pretty close to that spindle at turn.
  13. Mar 14, 2012 at 9:56 PM
    whitetoblack
    Tyler
    SoCal
    Calipers are not on and the tire is not even fully mounted just two bolts to hold it on. Just trying to get a rough estimate of width. Need to trade the 8s I have for 10s also.
  14. Mar 15, 2012 at 12:21 AM
    Anthony250
    Anthony
    Rialto CA
    Oh ok Gotcha. What are you doing for rear?
  15. Mar 15, 2012 at 1:25 AM
    whitetoblack
    Tyler
    SoCal
    Still deciding exactly what I want to do but a Tundra axle for sure along with either 62s or possibly a 64 kit with the wider axle. Still deciding. Looks like im gonna be pulling 16" strapped with the front kit so I still gotta choose. Planning on caging it later this year also so might as well go all out. Still a pretty slow step by step process though haha
  16. Mar 19, 2012 at 10:12 PM
    whitetoblack
    Tyler
    SoCal
    No goin back now haha
    Mocked up the 8 just to make sure I need 10s and sure enough it wouldn't cycle the full 16 where the tab is on the arm. So I am still looking for 10s. Plus I want to be able to run dual rates so it will work out well
  17. Mar 19, 2012 at 10:31 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    very nice. truck looks sweet man.
  18. Mar 28, 2012 at 6:28 PM
    whitetoblack
    Tyler
    SoCal
    Trucks coming along should be done this weekend. Scored some brand new kings from my buddy yesterday for $600! Got the coilbuckets done, upper arm gussets cut and being welded in tonight as well as the shock hoops. Gotta hand it to my buddies doin all the fab work its coming out even better than I could have expected. Here's a couple pics. Need to pick up that tundra axle quick cuz she sits wiiiide. Also possibly switching to the 2nd gen fiberglass front clip.
  19. Mar 30, 2012 at 7:01 PM
    whitetoblack
    Tyler
    SoCal
    Got the shock tower up and welded in. Now all it needs is a couple more gussets to the coilbucket and upper mounts, bracing on the sides of the shock tower, resi mounts, and the engine hoop. Also bumper will get started Monday. Plus I still gotta find some top springs for the coilovers.
    Got some pretty cool ideas for the rear suspension and fiberglass that I haven't seen done before so I will continue to update.
  20. Mar 30, 2012 at 7:29 PM
    tacotrd647
    Caleb
    Ridgeway, Iowa
    Holy shit, you weren't kidding! That fucker is wiiiiide! Sick build dude, what kit is that on the front?
    Fab work looks amazing..looking forward to more progress!
