02 Suddenly started pouring oil.
Discussion in '1st Gen. Tacomas (1995-2004)' started by parrishga, Jul 12, 2008.
  1. Jul 12, 2008 at 5:26 PM
    parrishga
    parrishga [OP] New Member
    Georgia
    02 Tacom TRD
    My wife was driving my 02 Tacoma, when she said it made a loud thud noise and started shaking like it had a flat tire. She pulled over saw oil very steadily dripping under the passenger side of the engine. By the time i got there 10 min. later, the puddle was about 12 in in diameter. i checked the oil level on the dip stick and it was still showing a normal level. I will have it towed to a mechanic Monday, but I am scared to death it has thrown a rod or something. It only has about 105,000 miles and I have religiously changed the oil. Any ideas what might have happened?
  2. Jul 12, 2008 at 5:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Can you see where the oil is/was leaking from?
  3. Jul 12, 2008 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sonds like it could have been something hit the tranny? Good luck. I hope this ends well. :(
  4. Jul 12, 2008 at 6:57 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Losing that much oil is never a "good" thing, where is your oil filter ?
  5. Jul 12, 2008 at 7:35 PM
    parrishga
    Georgia
    02 Tacom TRD
    The oil filter is still intact and shows no signs of oil loss in that area. l could not tell exactly where it was coming from because it had sprayed everywhere on the passenger side of the engine below the manifold.
  6. Jul 12, 2008 at 7:40 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Do you have a 4cyl or a 6?
  7. Jul 12, 2008 at 8:00 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    How's the steering?
  8. Jul 12, 2008 at 10:05 PM
    parrishga
    Georgia
    02 Tacom TRD
    This is a 6 cyl. and the steering hasn't been effected.
  9. Jul 13, 2008 at 7:51 AM
    concrete jedi
    Rochester N.Y
    Well... if it "sprayed" that means it's under pressure, I would check the EGR valve if your model has one. If not think where pressure would be, heads, valve covers, oil pan, etc. Be sure to check the fan, it could be blowing the oil from some place and make it look worse.
  10. Jul 13, 2008 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking its the tranny. If the engine oil level is good, and that much oil leaked under the engine, It would have showed a loss on the stick. Hows the tranny pan look.?
