02 Taco deckplate mod?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bs 02 Taco, Jul 9, 2008.
  1. Jul 9, 2008 at 2:26 PM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Does anyone have the specs on the deckplate mod for an 02 4x4 Taco?
  2. Jul 9, 2008 at 3:03 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Jul 10, 2008 at 7:11 AM
    Bs 02 Taco
    Amelia, Ohio
    Janster, you ROCK!!!
    I have the 2.7 engine, do you know if this will work for me?
    And once you completed the mod yourself, did you ever need the plug?
    If so when did you actually put it on?
  4. Jul 10, 2008 at 7:25 AM
    Janster
    Jandy
    Lancaster, PA
    I left the plug off most of the time.
    Whenever I'd go offroading - I'd put the plug back in.
    Here's some threads... (2.7L)
    http://www.toyotanation.com/forum/archive/index.php/t-215206.html
    http://forums.off-road.com/toyota-tacoma/210541-deckplate-mod-question-2-7-liter.html
    http://www.customtacos.com/forum/showthread.php?t=33045
    Hope that helps...
  5. Jul 10, 2008 at 9:32 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    FWIW i've RARELY put my plug back in...even offroad or in monsooning rains...and only once did i find the slightest bit of mud that squeaked by the filter...
    im running an K&N filter and ive had no issues with not closing it up...i even occasionally go thru the car wash with it open
  6. Jul 10, 2008 at 3:19 PM
    Bs 02 Taco
    Amelia, Ohio
  7. Jul 10, 2008 at 3:20 PM
    Bs 02 Taco
    Amelia, Ohio
    Thanks a lot, you have been a great help
    I think I am going to give you a great rep :)
  8. Jul 11, 2008 at 1:23 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Gentlemen, will this modification void our 5 year/60,000 mile powertrain warranty??? I would hope not.
  9. Jul 11, 2008 at 1:32 PM
    JimBeam
    JB
    2015 Tundra
    only if you have a problem that toyota can directly link to your modification
  10. Jul 11, 2008 at 9:15 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Unless you get water in it I dont see how making an engine breathe better will hurt it.
  11. Jul 12, 2008 at 5:18 AM
    Janster
    Jandy
    Lancaster, PA
    Put the cap in and you've the stock airbox back.
  12. Jul 12, 2008 at 5:55 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Well, I did it today! 4" deck plate, and the K&N 33-2054 drop in filter. Have not driven it yet, but I did start it up and let it run for a minute, and it didn't sound any different. I will keep you posted on if I think it makes any difference versus the stock set-up. It would be cool if i got another mile per gallon. Dream on, right?
  13. Jul 12, 2008 at 6:33 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Rain will not be a problem with this modification, will it? I only plan on screwing the "plug" in when I hose out the engine compartment about once a year.
  14. Jul 12, 2008 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Rian wont be a problem! Enjoy the new mod! :)
  15. Jul 13, 2008 at 9:11 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Have most of you that have done this mod taped off the entrances to the 2 silencers? Is there a performance gain to blanking these off? If so, do you think some foil air conditioning tape would be a good thing to use to blank these off? It is a very heavy duty foil tape used for sealing duct work.
  16. Jul 13, 2008 at 9:24 AM
    Bs 02 Taco
    Amelia, Ohio
    Congrats on your mod, I did mine yesterday as well!
    There is a noticable sound diference at WOT and it feels like a turbo type kick in as well
    It took longer than 1 hour as well, but I broke my brand new Dremel in the process so I had to use a hand file...
  17. Jul 13, 2008 at 12:06 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Yeah, I would like to see someone do the whole job in 1 hour. B.S. Did you blank off the silencers coming off of the intake tube ? This is supposed to help with air flow.
  18. Jul 13, 2008 at 12:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "blanking off" the resonators will give no performance gain at all. :)
  19. Jul 13, 2008 at 12:37 PM
    Bs 02 Taco
    Amelia, Ohio
    Like Chris said, I dont think it does anything...
