02 Tacoma doublecab 3-Link on FJ80 axles
Discussion in 'Solid Axle Suspension' started by rocktaco02, Oct 17, 2016.
  1. Apr 7, 2018 at 6:52 PM
    #421
    rocktaco02
    rocktaco02 [OP] Well-Known Member
    socal
    02 dcab Tacoma
    too many to list
    Made more progress.
    Tubing adapters burned into the upper/lower links.
    You can call me the human lathe.
    Everything is somewhat in the place it needs to be.
    Adude, BYJOSHCOOK, jubei and 5 others like this.
  2. Apr 7, 2018 at 7:06 PM
    #422
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Are you painting your whole truck with that - rattle can or sprayer?
  3. Apr 7, 2018 at 9:22 PM
    #423
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    @Dalandser I haven't decided yet, I really don't want to spend a bunch of money on something that's just going to get scratched up. I'm leaning toward wrapping the truck. I found a company that will print custom colors on vinyl.
    Dalandser likes this.
  4. Apr 7, 2018 at 9:23 PM
    #424
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm in the same boat - I'll have 4 different body colors once I'm done so I'm considering raptor liner in a similar color since textured finishes hold dirt...
  5. Apr 8, 2018 at 10:39 AM
    #425
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    I'm completely lost on where to start with spring rates and coil spring lengths. Im running 14" coilovers, I know the general rules of having your bottom coil be long enough for the slider to no droop below the body, lighter spring on top and to keep the rates within 150 pounds of eachother.
    Ritchie likes this.
  6. Apr 8, 2018 at 10:43 AM
    #426
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    For lengths you should use coils for 14” travel coil overs. When you order them I’d call and talk to someone versus doing it online.
    As for rates I believe Brian Reynolds is running 175/250. He has a double cab first gen but id assume that wouldn’t matter much
  7. Apr 8, 2018 at 11:00 AM
    #427
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    subd...sick build man, cant wait to see it in the dirt
  8. Apr 8, 2018 at 12:33 PM
    #428
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    I’m running 200lbs/250lbs on my 12” coilovers. 200x12 upper and 250x14 lower.
    I’d do 200x14 upper and 250x16 lower on 14” shocks.
  9. Apr 8, 2018 at 12:49 PM
    #429
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    @Rockbaron1 whats your ride quality like. I'm coming from king bolt in coil-overs with a 700 lb spring. I like a little bit firmer ride, for example coming down off a ledge I dont like a lot of compression just enough to eat a little uptravel. Also not going to have a sway bar on the rig that will be driven to the trails.
  10. Apr 8, 2018 at 2:16 PM
    #430
    Rockbaron1
    Pat
    03 Tacoma
    everything
    The ride quality is going to be far more dependent on your shock valving. I started with a pyramid stack of .015 shims on compression side and that was way to stiff for me, but I kinda like a soft cadallac ride. I changed to a flutter stack using a combo of .010 and .015 shims and the deference was pretty noticeable, much better. Also this is for an FOA shock, valving is going to be depentant on shock brand and piston design. Different pistons need different valving.
    Springs just need to set the ride hight without binding at full bump or loosing preload at full droop.
    stumbles and Dalandser like this.
  11. Apr 8, 2018 at 3:42 PM
    #431
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Check out my reply to questions about spring rates on my build. https://www.tacomaworld.com/threads/03-prerunner-4wu-3link-up-date.407191/page-9
    View post #178... this may help you.
    Good luck.
  12. Apr 9, 2018 at 8:31 AM
    #432
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
  13. May 8, 2018 at 12:03 PM
    #433
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    She lives. lot of small things to do but it's getting there.
    please ignore my rusty exhaust, that's all getting cut out for a new cat back setup.
    Prayn4surf, Jay-coma, Ritchie and 6 others like this.
  14. May 8, 2018 at 12:16 PM
    #434
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Body lift? Mind if I ask why you added one?
  15. May 8, 2018 at 12:44 PM
    #435
    Broke Okie Ty
    Ty
    Looks good! How long are your links and what kind of angle?
  16. May 8, 2018 at 1:11 PM
    #436
    Rockbaron1
    Pat
    03 Tacoma
    everything
    Looks nice man. I’m so not used to seeing hi-steer on an fj80 axle.
  17. May 8, 2018 at 3:05 PM
    #437
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    1) Clearance for the dual cases inside the trans tunnel
    2) move my rock sliders up
    3) to give more clearance inside the fenderwells
    4) room to mount the solenoid box for my winch under the grill hopefully
    Ritchie likes this.
  18. May 8, 2018 at 3:10 PM
    #438
    Ritchie
    Looking good.
    A couple questions:
    1. What is your caster set at?
    2. What is your wheelbase?
    My caster is 3.4 DS, 3.7 PS. The .3 difference is built into the Diamond axle. Wheelbase is 105.5" DS, 105.7" PS.
  19. May 8, 2018 at 3:29 PM
    #439
    rocktaco02
    socal
    02 dcab Tacoma
    too many to list
    Haven't got it professionally aligned yet, set everything with a tape measure just to get it roll-able. I let you know
    when I do
  20. May 8, 2018 at 3:53 PM
    #440
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Sorry but I can't see how you would determine a body lift?
