'03 4x4 DblCab Brake Rotor Removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo93, Mar 29, 2010.
  1. Mar 29, 2010 at 1:53 PM
    Buckaroo93
    Buckaroo93 [OP] Member
    I need to replace the rotors on my truck. Like it says, it's an '03 Taco 4x4 DblCab. Anything "special" I need to be aware of? Any "special" tools before I get into this? I'm very mechanical so I'm sure I can handle the process. I just didn't want to get into it and realize I didn't have the tool or tools I needed.
    Thanks
    Vinny
  2. Mar 29, 2010 at 1:55 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    their are special tools but you dont have to have them. A strait srew driver will work. Just leave one side together so you have something to look at when putting it back 2gether. And welcome to TW
  3. Mar 29, 2010 at 2:03 PM
    Buckaroo93
    Thanks. The Haynes manual says all I need to do is remove the caliper and the rotor comes off. Is this true AND this simple?
  4. Mar 29, 2010 at 2:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep...its a free standing type rotor. if its on there good.....tap with a hammer to break it free.
  5. Mar 29, 2010 at 2:12 PM
    Buckaroo93
    Good deal.
    Also, is it true that rotors can warp when the wheels are put on with an air wrench? I have always heard that. I believe Wally World did this when I had them R&B my tires. Ever since I had them do this last summer the pulsing and chattering has gotten progressively worse and the bad thing about it, I had JUST gotten new brakes a month or so prior and they were SMOOOOOOTH.
  6. Mar 29, 2010 at 2:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....it can and does happen. its really best, that if using an impact wrench.......just snug the lugs up with that and then torque them.
  7. Mar 30, 2010 at 7:08 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    could you explain how that happens? i'd think as long as you apply the same torque to all the lugs, it wouldn't be an issue. ..so what's the process by which this happens?
    also, from what i've read, there is a difference in a warped rotor and a rotor with material build up caused by deposition of pad material to the rotor.. ...warped rotors won't cause pulsations. ....ones with depositon of materials will.
    taking from another site.. not sure of accuracy ..but it's worth reading.
    this much i know for fact. ..based on my experience.
    brembo blanks and stock pads are not a good combo. ..pulsation within 1 month of city driving. this is probably moreso due to the brake pads as opposed to the rotors. when i looked at the rotors when i took them off, it was obvious that there was material transfer from the pad to the rotor ..and it wasn't an even transfer. ..this is what was causing the pulsation.
    i changed up last time and went with centric premium rotors and porterfield racing pads. i've run this combo over a year and my brakes are like new. ..no pulsing ...no vibes ...it stops as if it were a sports car.
    i also put centric premium rotors and ebc yellow stuff pads on my jeep w/33" tires ...i've run that combo for almost a year and have had no pulsing ...no vibes ....it also stops on a dime.
    at last inspection, the rotors on both vehicles showed no signs of deposits. ..they were clean as can be and smooth as silk.
  8. Mar 30, 2010 at 11:15 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
  9. Mar 30, 2010 at 2:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats the thing.........most folks....myself included, dont use the same amount of pressure with an impact gun. it doesnt matter that you have it dialed in for a certain torque....if you keep hammering on it....you aint gonna have evenness. most half inch impact guns....and the electrics are set to way the hell over what lug nuts are supposed to be torqued to....ours which is around 85 ft. lbs on the 6 lug trucks.
  10. Mar 30, 2010 at 9:03 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Ive used a air gun on mt lugs a few time but at a low setting and my gun max isnt all that powerful anyways. But I make sure to tighten evenly in a cross pattern and then stug them up with the torque wrench. But usually the air gun does the trick. And I havent had any issues.
