03 Headlights -
Discussion in 'Lighting' started by Big Daddy, Feb 25, 2017.
  1. Feb 25, 2017 at 4:11 AM
    Big Daddy
    Big Daddy [OP] Well-Known Member
    Jeff
    New Jersey
    2003 Tacoma Dbl Cab 4WD
    Looking for any experiences / Pictures of trucks with after market headlight turn signal upgrades that worked well and look good.
    I had replaced mine once with some cheapies. look better than the fogged old ones but don't fit as they should and wobble in the adjusters. Surprise surprise the cheap ones aren't that good.. Hah
    Need some recommendations on lights from actual experience. Went to one web site and lights looked great, reviews though ? Obviously all bogus.
    Thanks for chiming in with your thoughts ! They don't have to be stock, something custom would be ok.
  2. Feb 25, 2017 at 11:02 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Look here
    https://www.tacomaworld.com/threads/proper-headlight-upgrade.407879/
    Basically, there aren't a lot of headlights out there for our trucks that aren't form over function. They look cool, but end up leaking or don't fit very well. Your best bet is some CAPA certified housings ($40ish a piece) and, if you want to go for something really bright, some Osram 80w bulbs and an upgraded wiring harness (described above). All in you're looking around $250.
    I've so far gone with the CAPA housings (from rockauto.com) and the harness, but haven't done the super bright bulbs yet.
    DON'T get LED's or HID's that fit into your stock housings, they will scatter the light, and basically suck.
  3. Feb 25, 2017 at 11:05 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This sums it up pretty well.
    DustStorm4x4 and Big Daddy[OP] like this.
  4. Feb 25, 2017 at 1:11 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    As far as custom turn signals go, I Love my headlight filler panel signals.
    https://www.tacomaworld.com/threads...als-misc-led-dtrls-bolt-leds-write-up.349058/
    Not very good quality leds that I used. But I was starting to work on a fix for that. Need to try and coat them with something uv protective. The bolt housings tend to discolor and the lenses fall off over time. So hopefully coating/dipping them in a clear coat will help seal and protect them. There are better quality leds, but are expensive for something like this. Maybe the ozniums would be better. Or at least give you an idea for something else maybe.
    Big Daddy[OP] likes this.
  5. Feb 25, 2017 at 5:25 PM
    Big Daddy
    Jeff
    New Jersey
    OK so I think Im in. Ill keep the headlight assemblies I have - Toyota will have to adjust them for me after the frame replace and suspension lift. Ill see how they go and maybe apply some silicone caulk to adjustments that allow them to wobble ever so slightly. When I get it home I'll apply to corporate for funding for this light project. She's a great wife :) I don't see a problem and Ill touch base with you guys with an update as soon as my new lights go online :) Thank you for this awesome upgrade idea !
    The only question I have is concerning which harness I would need with no driving lights on an 03.
  6. Feb 25, 2017 at 5:47 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You are likely ground switched with an 03, but I laid out the test procedure in the ultimate headlight upgrade thread.
    Big Daddy[QUOTED][OP] likes this.
  7. Feb 25, 2017 at 5:54 PM
    Big Daddy
    Jeff
    New Jersey
    Thanks again - I may PM you when Im ready with any other questions. I appreciate your help.
  8. Feb 25, 2017 at 5:55 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Retrofits!
  9. Feb 25, 2017 at 6:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Happy to help! PM me when you are ready.
  10. Feb 25, 2017 at 8:45 PM
    NightProwler
    Harlan
    Maricopa, Az
    Oh I thought you were talking about the turn signal housings being loose.. So is it the corner/marker lenses that are loose?
  11. Feb 25, 2017 at 10:15 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    According to FSM the non-DRL are power switched and DRL are ground switched. As crazy as that sounds.
  12. Feb 25, 2017 at 10:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Interesting. I can only say from experience my non-DRL 03 was ground switched. Hence recommending the test procedure.
    mechanicjon[QUOTED] likes this.
  13. Feb 25, 2017 at 10:32 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Correction I have that backwards non-DRL are ground switched DRL is power switched. But at the actual switch on the column they are both ground switched.
    Yes do the test.
  14. Feb 26, 2017 at 3:08 AM
    Big Daddy
    Jeff
    New Jersey
    One is loose coincidentally. But the actual headlight housings have a slight wobble if you touch them. That's what Inwas talking about. I can see it's the adjusters where the little bit of play is.
  15. Feb 26, 2017 at 3:37 AM
    NightProwler
    Harlan
    Maricopa, Az
    Ok yeah I guess I just got a lil confused when you said turn signals. Ha. Yeah the capa ones seem to be the better choice. I've heard of depo being good too. Idk if those are capa. Kinda surprised though that the actual headlight housings are wobbly as you say. First I've heard of that with any of the 2 piece units.
  16. Feb 26, 2017 at 3:48 AM
    Big Daddy
    Jeff
    New Jersey
    I looked around last night and couldn't find CAPA housings for the 03? Found Toyota OEM at $185 EACH. UGH
  17. Feb 26, 2017 at 3:51 AM
    NightProwler
    Harlan
    Maricopa, Az
    Idk mang. Not too experienced with the two piece units myself. I have the crappy 1 piece spyder junk housings(with retros). Probably gonna be changing back so I'll be looking into This myself at some point in the future. I'm sure others will chime in.
  18. Feb 26, 2017 at 10:22 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    There are a bunch out there. I bet you put 2003 in your search? A tip for using good search key words, specify the first or last year of the model compatibility, as that what will likely be listed for the part. You have a 03, a part is unlikely to list all the years of compatibility as: 2001, 2002, 2003 2004 so that you get a hit on the 03 designation. Instead it will more likely be listed as 01-04 or 2001-2004.
    Some CAPA certified headlights for 01-04 on Amazon: here.
    CAPA certified corner lights for 01-04 on Amazon, left here and right here.
  19. Feb 26, 2017 at 12:38 PM
    Big Daddy
    Jeff
    New Jersey
    THANKS ! They are all in the cart at Amazon as well as turn signal lenses. Toyota is putting on a new bumper when they do the frame replace and Im going now to get on the list for a grille from HomerTaco. Ill paint the valance and be sporting a "new" front end with super powered headlights.. THANKS again !
    crashnburn80[QUOTED] likes this.
