03 tacoma 2.7 starts and dies
Discussion in '1st Gen. Tacomas (1995-2004)' started by statortot11, Sep 30, 2016.
  1. Sep 30, 2016 at 10:08 AM
    statortot11
    statortot11 [OP] New Member
    Sam
    03 Tacoma Prerunner 2.7 2wd automatic
    none
    Hi all. New member as of today. i have an 03 tacoma pre runner 2.7 automatic 2wd. truck just died on me while driving, it will start then die. put new fuel pump in, same thing. swapped main relay with new one. no change. pulled spark plug and checked spark, it is good. injectors fire when started then no injector pulse after that. If i turn key off then i crank it over it starts and dies. if i dont turn key off and crank it over i have no injector pulse, but still have spark. Any help would be appreciated
    Jlr19 likes this.
  2. Sep 30, 2016 at 10:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like a possible circuit opening relay failure. Have you checked the obvious like fuses?
  3. Sep 30, 2016 at 11:20 AM
    statortot11
    Sam
    none
    yes. all fuses are good, swapped out circuit opening relay with new one. i also checked every ground that i could find with Mitchell on Demand. Mitchell does not have a No Start trouble tree for this vehicle. Just for the knowing, I am an ASE Certified Mechanic for 30 years. This Problem is just eating my lunch. Fuel Pump Runs and Coils fire, Just the injectors don't fire once engine is started and dies without turning key off then back on in the start/crank position. Injectors only fire for a few seconds before it dies. While the key is left in the run position, i crank it over, and i have fuel pressure and spark, just no injector pulse with noid light. CPS shows 1970 ohms, which is in spec. My scanner shows RPM. No Codes! Thanks
    Jlr19 likes this.
  4. Sep 30, 2016 at 12:00 PM
    98tacoma27
    Ben
    Not Beech Creek
    Could be the engine temperature sensor on the back of the head (one on the front is for the gauge in the cluster).
  5. Sep 30, 2016 at 12:20 PM
    statortot11
    Sam
    none
    My scanner is showing 86 degrees. Which is the temperature here in north east fl.
  6. Sep 30, 2016 at 1:00 PM
    98tacoma27
    Ben
    Not Beech Creek
    The injectors should have voltage constantly. The ECM provides the path to ground to fire the injectors.
    There are only a few things that will cause the injectors to lose the pulse:
    • Temperature sensor
    • Crank Position Sensor
    • ECM
    • Bad ground
    • Bad ignition
    • Ignitor (found on previous models)
    davidstacoma likes this.
  7. Sep 30, 2016 at 1:26 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Have you tried starting the truck with the MAF disconnected? Not sure if it will change anything, but if it does then it might be a clue.
  8. Oct 3, 2016 at 9:57 AM
    statortot11
    Sam
    none
    unplugging maf does not help
  9. Sep 19, 2021 at 11:47 AM
    Jlr19
    Jlr19 Member
    I'm having the same problem on my 02 tacoma 2.7
  10. Sep 19, 2021 at 1:13 PM
    Glamisman
    Glamisman Well-Known Member
    see if this helps. at this point in time all I can think of that would require a new start/crank signal is the IGF output from the igniter.
    put you scanner on her and see what she says both current and pending.
  11. Sep 20, 2021 at 9:51 PM
    Junirol
    Junirol Well-Known Member
    Rolando
    San Diego California
    05 Tacoma Prerunner SR5, 10 Tacoma 4x4 Off road
    E85 Flex fuel, TRD CAI, Magnaflow exhaust, TRD Supercharger
    This above ^^^. check sensors and ignition if those are good might be a bad ECU...
  12. Sep 21, 2021 at 1:46 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I wouldn't believe that it would be a bad ECU just yet. There has to be a reason why the computer is not allowing voltage to the injectors. I am not experienced with Toyota but if it were my truck with these symptoms I would be looking at an oil pressure switch or sensor. I believe that there is a reason why the fuel is shut off.
  13. Sep 21, 2021 at 8:56 PM
    Junirol
    Rolando
    An ECU definitely would be the last resort / final step. 1st gen tacomas aren't to complicated, the oil pressure sensor is nothing but a light on the cluster and would not prevent it from running even with no oil, lol trust me I've tried on other toyota models newer than a first gen tacoma. I'll check out some wiring diagrams and see what powers these injectors, fuses, relays grounds.
  14. Sep 21, 2021 at 9:12 PM
    Junirol
    Rolando
    Read this, and see if it helps :).
    • PST.pdf
      File size:
      18.4 KB
      10
    • FP.pdf
      File size:
      102 KB
      7
  15. Sep 22, 2021 at 6:45 AM
    Glamisman
    I got to thinking about this and there are few things that I can think of. It is the "reset" via cycling the ingition that has me scratching me head.
    does this truck have an anti-theft system?
    The ignition switch has 2 feed wires to power the truck, IG1 and IG2. IG2 is the one that feeds the elctronics for the system. Verify at a convienient point that there is power at all times the key is in the ON position.
    The other thing I would check is to see if the Fuel Injection relay stays powered up during the re-crank.
  16. Sep 22, 2021 at 6:54 AM
    Jlr19
    Jlr19 Member
    No it doesn't. I was told to check the idle air control valve.
  17. Sep 22, 2021 at 6:55 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    MIL on? Any codes? Is your anti-theft/security system behaving normally? This is exactly the behaviour I had after water got into a connector and shorted a couple of pins for the anti-theft system.
    Bivouac likes this.
  18. Sep 22, 2021 at 7:32 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Sounds like the ECM sees a fault and shuts off the fuel.
    What codes have been pulled.
  19. Sep 22, 2021 at 8:04 AM
    Jlr19
    Jlr19 Member
    No anti-theft.
  20. Sep 22, 2021 at 9:19 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    How does it behave when it dies? Does the cluster light up like when you stall? Could it be a bad ignition switch?
