03 tacoma tail gate latch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Red rocket22, Aug 6, 2022.
  1. Aug 6, 2022 at 12:22 AM
    Red rocket22
    Red rocket22 [OP] Member
    Thomas
    Red 2003 tacoma 4x4 v6
    My 03 Tacoma’s tailgate has a hard time closing. I can not get it to latch just by closing the tail gate normally. Only way I can close it is if I open the handle then let go once it is in place. How can u fix this?
  2. Aug 6, 2022 at 3:16 AM
    Madjik_Man
    Colorado Front Range
    Lube up all the moving parts specifically the latch.
    Red rocket22[OP] and nagorb like this.
  3. Aug 6, 2022 at 7:26 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I had to take mine apart after my brother slammed it shut. A plastic piece got knocked out of place. Since then I only close by holding the handle and letting it go gently. I haven't had any problems after the fix. Same goes for the glove box, hold the handle to close it, when you let go give it a gentle push until it clicks. Slamming it shut will only shorten its life span.
    Red rocket22[OP] likes this.
  4. Aug 6, 2022 at 7:48 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    The tailgate on my 2003 is, I think, a little sprung out-of-square from lawn & garden stuff hauled by its previous owner. I have to push extra hard on the passenger side to get it to latch.
    The alignment of my gate could probably be improved, and the the closing too. I haven't fooled with it. Just not that big a deal right now.
    But maybe you could check that your tailgate is closing "square"?
  5. Aug 6, 2022 at 11:28 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    That is how I always close my tail gate keeps from breaking things.
    On every pick up I have ever had or used.
    Also things get lubed every oil change or when I walk past with the spray lube in hand.
  6. Aug 7, 2022 at 3:12 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup, mine got like that eventually, had to pull up on the handle to get it to close. I greased the latches (not the handle), both sides. Closes fine now just like it used to.
  7. Aug 7, 2022 at 4:02 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Mine was exactly the same a while ago. I removed the plate on the inside of the tailgate, lubed everything up, including the latches, and now it closes with very little effort.
  8. Aug 7, 2022 at 9:36 PM
    tacotres
    tacotres New Member
    '03 DC Prerunner V6 TRD
    One of the tailgate cables broke at some point on mine before I owned it and the owner didn't bother replacing it, so the tailgate is a little out of square. I have to be gentle with the latch and push harder on the side that didn't have a cable to close or open it. Same thing happened to my grandma's. I replaced it but that's not gonna fix how much it's tweaked already :notsure:
