04 Cruise Control
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrentSR5, Sep 25, 2008.
  1. Sep 25, 2008 at 10:11 AM
    BrentSR5
    BrentSR5 [OP] New Member
    Central MS
    04 SR5 4x4 Ext. Cab
    Hi everyone,
    I'm new to the site, and need some help. I just bought an 04 Tacoma V6 5spd 4x4 ext. cab. I bought it even though it did not have cruise control, which I used on a daily basis in my 94 4Runner. I really want to get cruise control on it, but wasn't sure if a dealership could install a kit or if there were any aftermarket kits that work. I really appreciate the help. Thanks,
    Brent
  2. Sep 25, 2008 at 12:24 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
  3. Sep 26, 2008 at 11:41 AM
    BrentSR5
    Central MS
    04 SR5 4x4 Ext. Cab
    Thanks for the reply, wing. I looked at that link and it looks very helpful. It says that the truck in the demonstration is a 2005. Do you think it is still pretty much the same as my 04 as far and layout is concerned? I'm not real sure fot the major differences between the two so that's why I ask. Thanks again,
    Brent
  4. Oct 2, 2008 at 5:38 PM
    installersam
    installersam Well-Known Member
    raleigh NC
    03 Double Cab
    we do cruise controls for dealers from time to time. A lot of cars come with the cruise already installed, you just have to install the stalk. I haven't did a tacoma, but i have did some toyotas. I would check to see if the truck has two throtle cables under the hood, one going to the pedal inside, and one going to the cuise module. If thats the case just order the stalk. if thats not the case, their are universal cuise controls that would work. Thats not realy a DIY kind of project unless you have some experiance. Most trusted car audio shops can do a cruise install .
