04 Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by mag, Jun 25, 2010.
  1. Jun 25, 2010 at 11:17 AM
    mag
    mag [OP] New Member
    I'm considering an 04 4x4 5spd 4cyl sr5 access cab. it's got mid 50K on it. Is there anything in particular that I should be looking at? How long should this truck last if maintained, also, it would be seeing mostly highway millage, 75miles per day.
    thanks for any info.
  2. Jun 25, 2010 at 11:18 AM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    check for frame rust
  3. Jun 25, 2010 at 11:45 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    yep. just the frame rust. Everything else should be pretty solid.
    Also, just so you're aware, you probably wont be getting better than 20-25mpg, so expect to drop about $50-60/week in gas. You probably will have to fill up every 4 days.
  4. Jun 25, 2010 at 11:49 AM
    mag
    mag [OP] New Member
    thanks for the input. I've got a VW jetta tdi, averge about 48mpg, but i'm at 227K, they will go longer, but may have to start replacing more and more parts. I used to have a nissan hardbody, then an F-150, then a Jeep Xj with 3" lift, then to the jetta. good car, buts lots of quirks. I wish they'd bring over the 4cyl diesel thats in the Hi-Lux, mid 30mpg for the 4x4 with 5spd.
  5. Jun 25, 2010 at 12:41 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    It'll be painful for ya. I really dont drive much, but I went from about the same mpg to what I'm getting now.
    The tank is over twice as large, so I fill up about the same frequency, but instead of only spending $20/tank, its now over $50. Quite a huge jump.
    I'm right there with ya in getting diesel engines. It's really too bad Tacoma's dont get one here.
  6. Jun 25, 2010 at 3:51 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I guess if you worry about gas mileage you have no business driving a 4X4, get ya a Yaris!
    I was driving a Honda CRV ( all wheel drive ) got 20-21 in town, the Tacoma( V-6 ) gets an average 16.75 to 18.0 mpg in town if you don't have your foot in it from stop light to stop light, I try and keep the RPM's under 2K.
  7. Jun 25, 2010 at 6:53 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That's like unbearably slow for the average driver. I can barely keep my truck below 3500. But I also like to hear my exhaust.:D
  8. Jun 25, 2010 at 8:10 PM
    scocar
    scocar hypotenoper
    Really? I was stunned at how much low-end torgue the 3.4 has when I got this truck. I used to have a 22RE, and I had to wind that thing up like crazy, but even then I was between 3-3800 rpm. The 3.4 seems very happy running at about 2K rpm or under, and I rarely go near 3k, even getting on the freeway. I only go over that for "oh shit" moments. Generally, I barely touch the gas pedal. I haven't seen the torque curves for this engine, but it ain't built for ricing...it is a truck.
  9. Jun 25, 2010 at 9:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The 3.4L has incredible torque and is way under rated. It is a trail monster because of its torque ability.
    At the same tine, if you open it up, WOT, it breathes very well. Especially if you have no restrictions. This is why the deck plate mod and straight thru mufflers are so effective for mpg and power on this motor.
    It is quite amazing for a v6.
  10. Jun 26, 2010 at 12:09 AM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    2000-2500 is about what I drive my v6 most of the time. Granted that its fun to punch it once in a while to remind yourself whats available, but I guess I just drive slow. I dont feel like I'm slow though, since I'm keeping at about avg with everyone else off the line and up to speed.
    But on the other hand, in following the guys at our last meet, I did notice they were pushing it a bit more than I usually do on the way to the trail, so maybe I'm just getting old.
  11. Jun 26, 2010 at 9:56 AM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i have the same truck and mine is about to turn over 150k miles. Toyota replaced my frame and other things that go along with that TSB but other than that i have had no problems and my truck is good for another 100k miles since the frame and structural components are all new haha.
    can be a little underpowered at times but honestly the K&N intake really helped but i would just do the deckplate since u get the same performance but half the price. It does get 20mpg around town though with a 2.5" lift. I used to have a 98 reg cab 4cyl before this one and although they have the same engine my 04 ext cab def goes better cuz it has 4.30 gears in it and the 98 prob had like 3.91 so it made up for it with the slight weight increase.
    If u could find a V6 i would get that one cuz i always wish i did have a V6 taco and it will def be my next one...
