04 Tacoma MT really stiff when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Darkstar21, Jan 12, 2021.
  1. Jan 12, 2021 at 2:24 PM
    Darkstar21
    Darkstar21 [OP] Member
    PA
    2004 Tacoma sr5 3.4l 4wd 5 speed
    When cold I can hardly get it in gear. After driving for a little it shifts pretty smooth. Any ideas why this is and what I might do about it? Thanks for any help!! Just bought the truck a few days ago.
    Black DOG Lila likes this.
  2. Jan 12, 2021 at 2:27 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Change out the fluid to start.
    Check your clutch fluid- probably black. I’d drain it and don’t forget to bleed it.
    Darkstar21[OP] likes this.
  3. Jan 12, 2021 at 2:31 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Shifter bushings and 75w90
    Welcome to TacomaWorld
    JPinFL and Darkstar21[OP] like this.
  4. Jan 12, 2021 at 2:31 PM
    Darkstar21
    PA
    What type of fluid does it use? Is this difficult to do?
  5. Jan 12, 2021 at 2:41 PM
    Black DOG Lila
    Virginia
  6. Jan 12, 2021 at 2:50 PM
    Black DOG Lila
    Virginia
  7. Jan 12, 2021 at 4:35 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Define Cold ??
    To me Cold is below zero F to some 50 degrees F is bitter cold
    JudoJohn likes this.
  8. Jan 12, 2021 at 4:38 PM
    gearcruncher
    Canadain bumper technician
    Just purchased the truck ?
    Got any warranty ?
  9. Jan 12, 2021 at 4:43 PM
    Darkstar21
    PA
    It has been in the 30's. Bought as is, no warranty.
  10. Jan 12, 2021 at 4:57 PM
    gearcruncher
    Any service records come with the truck ?
    If not , check out whats been done to the truck at the dealer and what TSB,s and recalls are needed
    This way , you get a track record of what was done
    https://www.toyota.com/owners/home. You will need your vin # handy
    We are for a looking clutch job , clutch master cylinder or slave cylinder replacement .
  11. Jan 12, 2021 at 5:09 PM
    Darkstar21
    PA
    I was told the master and slave cylinder were just replaced but no records. Under the hood it does appear to be new. I'm hoping to fix it up and get everything mechanically sound but I don't have much money. I did get the frame inspected/undercoated and it is solid, so that is awesome.
  12. Jan 12, 2021 at 5:19 PM
    gearcruncher
    Alright , thanx for letting us know the clutch master and clutch slave are both new .
    Go to the website below and pick out your shifter bushing
    https://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-sockets
    If you can wait until you get the shifter bushing , you can fill your transmission with new fluid from the top
    Once the new shifter bushing and fresh fluid have been installed , road test and get back to us
  13. Jan 21, 2021 at 4:29 PM
    Darkstar21
    PA
    I changed the fluid and the problem is still there. It's actually starting to get worse I think.
  14. Jan 21, 2021 at 4:47 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Fk that, it was 69F and hard nipple chilly today
    Wyoming09[QUOTED] likes this.
  15. Jan 21, 2021 at 4:51 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    They all are stiff when cold, least the majority of ours are. I live in az and even in the 30s it's noticably stiffer if I don't let it heat up for 5 10 min. I just start the truck and let it sit in the winter time.
  16. Jan 21, 2021 at 4:52 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    I know my shifter bushing is shit bc it pops out of gear when hitting a bump engine breaking, and fluids need to be done on mine. However, many others have all said it's common
  17. Jan 21, 2021 at 4:53 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    to anyone with MT knowledge, could he have tried a thinner fluid?
  18. Jan 21, 2021 at 4:54 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    @Wulf has recommended redline to fix this before, but if he's got fresh fluids already idk if brand will help
    Wulf likes this.
  19. Jan 21, 2021 at 7:23 PM
    Darkstar21
    PA
    It's more than a common inconvenience. I can't even put it in gear at first. Have to put it in second when it's not running then drive around slow for a while. It grinds and is extremely hard to shift for quite a while. Getting hard to even drive. A friend said to bleed the line since the slave cylinder was just changed. Gonna give that a try next I suppose.
    Wulf likes this.
  20. Jan 21, 2021 at 7:28 PM
    Darkstar21
    PA
    The transmission fluid definitely needed changed though. It looked really crappy and smelled horrible. I put Mobile one 75w90 in it. That's what was recommended and it said good for cold weather.
