04 Tacoma Prerunner question...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Motorunit, Oct 14, 2008.
  1. Oct 14, 2008 at 12:12 PM
    Motorunit
    Motorunit [OP] New Member
    Miami, FLA.
    Hi Guys,
    First, of many future post. Just got my son a 2004 Ex-Cab Taco with a 2.7 L (I4) engine. My question, is this engine known for wasting alot a gas ? i had a 1999 2.4 and it was wonderful on gas (shouldnt have sold it :(). I have a 2007 Taco V6 and its fair at best (18-20mpg) on a good day.
    Thanks Manny
  2. Oct 14, 2008 at 12:13 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Welcome to TW, Manny!
  3. Oct 14, 2008 at 4:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw, Manny!!!
    that motor should be pretty decent on gas. you may want to change your fuel filter and maybe install a good air filter to help wih mileage a bit, and also, running some techron thru the gas tank may help a bit also.
  4. Oct 15, 2008 at 11:25 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    That motor is great on Gas. But your lift and tires are going to kill it...
    See a prerunner and 4X4 are lifted and that increased your resistance to teh Air becuase of this. Then you add larger wider tires and this increases your friction to the road. THen add in the gearing and drive train, Weight and a few other things.
    This is why the gas mile goes down.
    If you took that truck and added Skinny tires small tires, it would get much better mileage, but would look bad.
    Having good fuel, clean Air filter and well adjusted spark plugs will help the most.
    Adding in a Deck plate mod, or Cold Air intake might also help.
    Keeping the Tire filled with as much Air as possible without hurting your tire wear wil also help. To much air wil hurt and to little will also hurt.
    over all this is not a Gas sipper, but a great combo that will get you around..
  5. Oct 15, 2008 at 10:21 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    First off, that's a V6, so your son's truck will do considerably better as you would expect.
    Next, bear in mind that your mpg depends on how what you do with the truck and how you drive it. I have the same truck, just four years older, and I'm getting 27 mpg!
    The catch is that I'm anal about my mpg. I do everything possible to increase it. I always have my tires up at 40 psi (a little higher than the recommended, its fine) because more pressure = less contact area = less friction = more mpg. When I got my truck, I invested thirty bucks in a K&N drop-in filter, which is better quality than the stock one and lets more air in. Next, I did the deck plate mod, which also increases air flow through the engine. The easier the engine breathes, the less gas it needs. Lastly, and this is the most important, I drive with a LIGHT FOOT. Accelerate slowly, do everything possible to keep your momentum up, and don't drive too fast on the freeway because air resistance increases exponentially (meaning 70 mph is much much worse than 60 mph, even tho it's only 10 mph difference).
    I realize that this is your son's truck, not yours, but if you make him pay for gas I'm sure he'll be motivated to do all this stuff and you'll see some decent gas mpg numbers pretty soon.
    Enjoy your taco! Update us on how it goes!
