04 tacoma xtra cab cannot start
Discussion in '1st Gen. Tacomas (1995-2004)' started by LONGBED, Jan 20, 2008.
  1. Jan 20, 2008 at 7:40 PM
    LONGBED
    LONGBED [OP] Member
    doublecab longbed 4x4
    I have a yota 04 xtra cab that cannot start.changed the fuel pump and the fuel relay switch. still won't start. engine did try to start when we managed to get some fuel in the carb. if you have any ideas let me know.mahalo
  2. Jan 20, 2008 at 11:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The carb? The Taco is fuel injected.
    When you try to start it, are the dash lights working? Do you hear only clicks? Have you checked the battery?
  3. Jan 21, 2008 at 12:51 AM
    LONGBED
    LONGBED [OP] Member
    will be trying to get a code reader,and we have checked the fuses. mahalo for the advice
  4. Jan 21, 2008 at 1:02 AM
    LONGBED
    LONGBED [OP] Member
    didnot notice the dash lites but will be checking it now, battery had to be recharged to full swing,don't know what you mean by clicking noise?whether it cliks while we are trying to get started ,or just the clicking sound when i turn the key an nothing else. mahalo
  5. Jan 21, 2008 at 8:21 AM
    LONGBED
    LONGBED [OP] Member
    no smell of raw gas,as for filter thats something that could be looked at.mahalo
  6. Jan 21, 2008 at 8:23 AM
    LONGBED
    LONGBED [OP] Member
    yes intake,no back fire an smell of raw gas.need to chek filter mahalo
  7. Jan 21, 2008 at 10:45 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    also if the crank position sensor is out it will just crank and crank no fire
  8. Jan 22, 2008 at 1:25 AM
    LONGBED
    LONGBED [OP] Member
    aloha, GOT IT STARTED!!!!.The problem was corrosion in the harness under the steering.green corrosion was the problem.I guess the beach surf an open doors with the stereo going while parked on the beach has its price.Mahalo to all who took time to give us a hand.
