05-08 Drivers side Headlight disassembled.
Discussion in 'Buy / Sell / Trade' started by Marc M, Feb 27, 2009.
  1. Feb 27, 2009 at 4:46 PM
    Marc M
    Marc M [OP] Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I have here a used OEM right side headlight that I took apart to fool with and try the BHLM.
    Well I took it apart, and it ended at that, I put it on a shelf where it's been sitting open for months, so it's dusty. The clear lens is in excellent condition, as well as the reflector that gets painted black for the BHLM.
    The rear housing itself has 2 tabs broken off, as well as the place where the grille clips in.
    So, if you attempted the mod and it went up in flames, here are some parts.
    Located in Washington PA
    Asking for $25.00 plus shipping, unless someone picks it up.
    Wow, 65 views and nobody corrected me on the listing. Sorry this is NOT a driver side light.
    Marc M
  2. Feb 27, 2009 at 8:30 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    do you by chance have the rear rubber boot that goes around the H4 bulb? i messed both mine up trying a mod and only need one more to replace.
    i'll drop you $5 for it shipped cheap first class to 90025, let me know please, thanks!
