05 4x4 brakes very low after fr brake job
Discussion in 'New Members' started by hcasanova, Jun 16, 2011.
  1. Jun 16, 2011 at 4:37 PM
    hcasanova
    hcasanova [OP] New Member
    Rhode Island
    05 4x4 tacoma dual cab trd
    Long story. Front right bearing was going. Thanks to forums fixed bearing and while repairing bearing noticed brake pads thin so decided to replace. Put all back together and now brake pedal goes low (to the floor) every 4th or 5th push. Bled (Bleeding) brakes didn't help. Had mechaninc check Master Cylinder and checked out good. Told me to take to Toyota. Does anyone have any ideas. Could it be one of the calipers since i had to press them back. Any ideas would be appreciated.
  2. Jun 16, 2011 at 5:14 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There are only a few reasons why the pedal would do that. A leak would be a constant problem. The master cylinder could be either constant or intermittent. Air in the lines would be a spongy pedal. The abs system can cause some screwy symptoms.
  3. Jun 16, 2011 at 5:26 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i vote air in the lines.........
    unsafe get it checked out.
    and welcome to TW.
  4. Jun 16, 2011 at 7:12 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I misread your post, op.
    You only need to bleed the lines when you open the system. Replacing pads does not count. You still have air in the system from when you "bled" them.
