05 Corrola keyless entry on a 06 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silverstreak06, Aug 18, 2008.
  1. Aug 18, 2008 at 6:11 AM
    silverstreak06
    silverstreak06 [OP] Member
    Oklahoma
    06 Dcab 4x4
    265 75 16 BFG AT Fllowmaster super 40, K&N filter, hi-lift jack, ramsey pro plus 9k, 2.5 in lift,gps ,cobra cb, husky liners front & rear, painted grill, mag light seat mod and more to come.
    Is it possible to have a dealer program the remotes off of another Toyota to work with my Tacoma? I have a couple of remotes left over from our old 05 Corrola laying around.
  2. Aug 18, 2008 at 6:28 AM
    ap53
    ap53 Well-Known Member
    Art
    NJ
    06 PreRunner
    No need to go to the dealer and pay for it if you can do it your self.
    I’m not sure if Corolla’s remote will work.
    The vehicle should meet the following conditions before proceeding; *The key is NOT in the ignition *Driver’s door is OPEN (The others are CLOSED) *Drivers door UNLOCKED (Not necessary for Echo) 1) INSERT and REMOVE the key from the ignition cylinder, TWICE within 5 seconds 2) CLOSE and OPEN the driver’s door TWICE within 40 seconds 3) INSERT and REMOVE the key into the ignition cylinder 4) CLOSE and OPEN the driver’s door TWICE within 40 seconds 5) INSERT the key in the ignition and CLOSE the driver’s door 6) Turn the ignition switch from LOCK to ON and back to LOCK at approx. 1 sec. Intervals “ 2” times to enter REWRITE MODE 7) REMOVE the key from the ignition (The door locks are cycled LOCK-UNLOCK within 3 seconds TWICE to let you know that you have selected REWRITE MODE) 8) Within 40 seconds press BOTH the LOCK & UNLOCK buttons on the transmitter simultaneously for 1 second (Press and release). 9) Within 3 seconds press and release the LOCK button on the same transmitter (The door locks will cycle ONCE if the transmitter was recognized and TWICE if it was not recognized {if you get two cycles start over}). 10) Within 40 seconds repeat step 8 and 9 with any other transmitters you wish to program 11) One of the following will END the Rewrite mode; *40 seconds elapses *Drivers door is opened *Key inserted into the ignition cylinder *4 transmitters are registered
  3. Aug 18, 2008 at 6:35 AM
    silverstreak06
    Oklahoma
    06 Dcab 4x4
    Thanks man, I'll try it tonight.
