05 cranks but wont fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LjHarp, Jan 4, 2011.
  1. Jan 4, 2011 at 9:14 AM
    LjHarp
    LjHarp [OP] Well-Known Member
    Reno, NV
    05 SR5 SWB 4x4 2.5 REVTEK lift
    2.5 inch REVTEK lift.
    I tried the search but couldnt come up with anything...
    did all the trouble shooting i could and found out that my injectors are not poping. i found that out because i trouble shot the fuel pump and fuel pressure. and then hooked up a test light to the injector and nothing... I dont have the up to date program to get a code from the code reader.
    the mechainc that was helping me said it was most likly my cam or crank shaft position sensor is their another likly cause?
    the situation was it started great in the morning drove to work parked and when i got off work i went to start it and I got nothing but it cranking but not fireing
    thanks in advance for any help
  2. Jan 4, 2011 at 10:02 AM
    Akron1
    Akron1 Member
    David
    Ohio
    20 TRD Sport 4X4
    No mods yet
    Sounds like the security system to me. My sister had this problem with her Corolla. She went and had a steel key cut to fit her car. It unlocked the doors and turned the ignition just fine. The engine would crank just like you describe, but it wouldn't fire for anything. She put the original key with the radio chip in and it fired right up. I'd check that system before I went around messing with cams.
  3. Jan 5, 2011 at 10:40 PM
    LjHarp
    Reno, NV
    ^^ dude I can not thank you enough.. I cut all the plastic off the vallet key because my dog chewed it up and I needed a place to put it on my ring which removed the security chip im guessing and well found my other set of keys and if fired right up.... you just saved me a ton of time and headachs thank you again
  4. Jan 5, 2011 at 10:57 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    fantastic resolution! great job Akron1.
  5. Jan 5, 2011 at 10:59 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I hate that chip in the key my dog chewed up my key too and now I only have one set of keys and the dealership they over charge you to get a new key freakin gay
  6. Jan 5, 2011 at 11:21 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Pos rep for this guy! :woot:
  7. Jan 6, 2011 at 5:37 AM
    Akron1
    Akron1 Member
    David
    Ohio
    20 TRD Sport 4X4
    No mods yet
    Glad it was that simple. :)
