05+ DRL (Daytime Running Lights) Install OEM
Discussion in 'Technical Chat' started by 007Tacoma, May 10, 2007.
  1. Nov 22, 2012 at 3:57 AM
    #381
    bassman
    bassman New Member
    Just reading this mod you have posted here while searching the net...thanks for the info btw....parts prices here at my local dealer for my Tacoma were around $35. for the relay and $135. for the jumper!! Kind of crazy....will order the parts from your post....and gladly pay the $25. shipping charges to Nova Scotia Canada on top of the $52. parts!! The Truck is USA brought into Canada....Canadian Tire did a DRL mod to it to make it legal in Canada....one of the worst wiring jobs I've seen in all my life...this mod will clean it up just fine...thanks for the post :)
  2. Dec 1, 2012 at 1:06 PM
    #382
    tewoods
    tewoods New Member
    Tacoma Base
    Mod worked great on 2011 Tacoma Base model. Some extra photos are attached that help between steps 2 and 3. Photos show the back of the unit removed, the components to remove and the jumper/relay installed.
    BruteTaco, CleanYota and Shaun017 like this.
  3. Dec 1, 2012 at 1:22 PM
    #383
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Great pics.
    Clarifies it for those of us who have not yet done the mod and are wanting to do it without taking the dash apart.
  4. Dec 1, 2012 at 2:04 PM
    #384
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I did mine 4 years ago and best I can recall the plugs that are shown in the pics are on the back side of the block and you have to unscrew the block to get to it. I don't know if you can get to it without removing the lower dash panel which really isn't that difficult and I am an old fat man with fat fingers.
  5. Dec 1, 2012 at 2:48 PM
    #385
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya... I don't have fat fingers.
    Someone recently posted having to remove the washer reservoir to replace the passenger headlight and I was thinking WTF?
    Wouldn't you know it... I drove to work the next morning with one headlight and replaced both before leaving for home.
    Nope... it was tight but I did it.
  6. Dec 2, 2012 at 11:24 AM
    #386
    Whiplash777
    Whiplash777 Well-Known Member
    Upstate NY
    '09 Blue Double Cab Off Road
    Side steps, DRLs, DynoLock
    The kit that TDRParts4U has is only for model years 2005 - 2011: http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-5551
    They do not (yet) have a kit for 2012-2013.
    I was able to confirm with my local dealership that there are different electronics in the 2012 (and thus also 2013), but I haven't been able to track down the correct part numbers. If anyone finds them, please post here!
  7. Dec 13, 2012 at 10:06 PM
    #387
    pevangel
    pevangel Member
    Paterno
    Hello Sir,
    I have a 05 Toyota Tacoma, Pre-Runner V6, Crew cab. Please help me, I'm a bit confuse about the jumper and relay harness. Do I need to buy both of the parts Toyota Part # 81980-35020 (jumper), and Toyota Part # 82241-04030 (relay harness). Where do I need to install this parts.
    Thanks,
    Paterno
  8. Jan 7, 2013 at 2:01 PM
    #388
    Sendit2Wil
    Sendit2Wil Member
    2006 Tacoma Pre-Runner Double Cab
    Hey pevangel, I got the parts you need. Hit me up.
  9. Feb 13, 2013 at 9:18 PM
    #389
    calixto25
    calixto25 Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
  10. Feb 25, 2013 at 7:32 PM
    #390
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    Awesome!
    Question:
    what happens when you use the turn signals with the headlights on and headlights off?
  11. Feb 25, 2013 at 8:35 PM
    #391
    Rich91710
    Rich
    Los Angeles
    08 Base
    Using factory parts, the DTRLs will be on when the headlights and parking light are off, turn off with the parking lights.
    They operate as normal turn signals whether on or off.
    Please read the entire thread.. 2012 and 2013 take different parts.
  12. Mar 1, 2013 at 3:32 PM
    #392
    Yoshio
    Yoshio Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    This doesn't contribute to the melting headlights, does it?
  13. Mar 1, 2013 at 7:06 PM
    #393
    Rich91710
    Rich
    Los Angeles
    08 Base
    Some years it may.
  14. Mar 1, 2013 at 7:44 PM
    #394
    Yoshio
    Scott
    Central Coast, CA
    Any in particular? I really want this for my 2007
  15. Mar 1, 2013 at 7:59 PM
    #395
    Rich91710
    Rich
    Los Angeles
    08 Base
    No way to tell. Some trucks have a problem, some don't. Doesn't seem to be pinned down to a specific year range or model, hot weather may contribute.
    There's a dozen threads on the melting issue, and the data points span nearly all years.
    I've got the kit, and aftermarket light housings, but I'm stalling until I can do the flasher resistor mod and run LED.
  16. Mar 3, 2013 at 5:04 AM
    #396
    Yoshio
    Scott
    Central Coast, CA
  17. Mar 8, 2013 at 11:37 AM
    #397
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    If someone could help me out that would be nice, maybe I'm a little thick but I can't figure out where the second white plug goes in.
    I got the grey one, but I can't seem to find where this white one goes in. From the pictures it looks like it goes
    To that grey one with the blue dashes? But it doesn't seem to fit. Thanks and sorry for the crappy pics
  18. Mar 8, 2013 at 11:51 AM
    #398
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Not sure if that's the part being talked about, but it says in the OP that there is a grey cap/cover that has to be removed before plugging the new plug in...
  19. Mar 8, 2013 at 12:07 PM
    #399
    dlooney
    Dennis
    Wilmington NC
    I'm pretty sure I got that part, unless that grey piece with the blue lines needs to be removed. ImageUploadedByTapatalk1362773226.169030.jpg
    I got that one out
    EDIT never mind figured it out thanks.
  20. Mar 19, 2013 at 3:03 PM
    #400
    LongIslandTaco
    LongIslandTaco New Member
    Nick
    Long Island, NY
    just ordered my DRL jumper and relay...should be here tommorrow and will try and install before my hockey game
