05+ Official Perforated/Rusted Through Frames
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 30, 2013.
Is your frame perforated/rusted through
  1. Yes, It looks like swiss cheese
    26.4%
  2. Yes, but it's only a little
    73.6%
  1. Jul 31, 2014 at 2:17 PM
    #341
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Doesn't look that bad. Surface rust. I think mine looked like that at the 5 yr mark.
    ^This.
  2. Jul 31, 2014 at 2:18 PM
    #342
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    +1
    You and I must have the same dealers from the School of The Customer is Never Right and is to be Made to Feel Like a Dumbass.
  3. Jul 31, 2014 at 6:21 PM
    #343
    Aloe
    Aloe Well-Known Member
    05 SWB TRD Sport access cab 4x4
    URD Short throw Fisher Plow
    I was told today there is no 15 year warranty on these frames
  4. Jul 31, 2014 at 6:51 PM
    #344
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I've got the same year and same mileage, and my frame looks exactly like that too :(
  5. Aug 1, 2014 at 6:13 AM
    #345
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    The reason construction companies supply material is because we warranty it. This isn't me complaining about a wheel bearing going bad faster because my lift its a frame material failure.
  6. Aug 1, 2014 at 10:47 AM
    #346
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :laugh:
    thats worse than my 08' with 94k on it.
    you guys really need to start doing some preventative maintenance.
    It's not like the past 20 years worth of Toyota pick up frames hasn't rusted out. No way in hell should a 2011 look like that IMO.
    We all know the frames are crap so start taking care of them.
  7. Aug 1, 2014 at 11:30 AM
    #347
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    To which Picture are you referring?
  8. Aug 1, 2014 at 11:38 AM
    #348
    jeeprjames
    jeeprjames Well-Known Member
    James
    Summerville, SC
    2006 DCLB 4X4 TRD Radiant Red
    ICON Stage 2, Retrax Pro, frame replaced by Toyota!
    Have you looked beside each catalytic converter? Seems to be a common area for perforation.
  9. Aug 1, 2014 at 12:39 PM
    #349
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2. I don't understand how they can keep buying crap frames. There must be a lot of stupid people with no common sense getting paid a lot of $$ to make these decisions. I wish I knew how to get a jobs like that.
  10. Aug 1, 2014 at 8:37 PM
    #350
    seanmccarthy1
    seanmccarthy1 Member
    massachusetts
    05 sr5
    Had my 2005 double cab frame inspected. Dealership said it passed and then sprayed it. Does spraying rust with a "rust inhibitor" really work ? If something starts to rust from the inside out isn't it a little late for a rust inhibitor ? I'm no metallurgist but I can probably assume my frame is on borrowed time.
  11. Aug 2, 2014 at 4:09 AM
    #351
    george3
    New Jersey
    I'm curious with all this spraying - do the just spray the outside of the frame or do they also spray the inside ? My 1st gen rusted thru from the inside so I bet they don't bother with that. I ass-u-me they just spray over all the rust to cover it up and make it pretty. Probably a waste of time. Thanks for any reply. Curious George
  12. Aug 2, 2014 at 6:06 AM
    #352
    joshua721
    16 f150 xlt v6
    Its an 05 any warranty it had was gone in 3 years. So what warranty are you speaking off.
  13. Aug 2, 2014 at 7:38 AM
    #353
    Canufixit
    New England
    I got this from Toyota when I asked .... Is this what you mean??
    "You are correct that a Customer Support Program has been issued for the Tacoma and that program extends the warranty for frame corrosion for 15 years, unlimited miles but it is specific to the 1995 - 2004 model year Tacoma trucks. "
  14. Aug 2, 2014 at 10:16 AM
    #354
    XXXX
    sKiP
    05 Prius
    I just used brush on Rustoleum rust reformer on all the portions of rust I could not sand down. Time will tell if it works. I then top coated with automotive primer followed by rubber undercoating (I would not recommend it - I just used it to hide the rust because I have given up), and top coated that with gloss spray paint.
    I will never touch my frame again....after 4 years of sanding and spraying I'm done. My 18 YO Ford Explorer's frame is in better shape and I'm just doing this last painting to hold off the inevitable replacement.
  15. Aug 3, 2014 at 12:17 AM
    #355
    george3
    New Jersey
    Hope they eventually have the same program for the 2005-2013 because the frames are no better then the 1995 - 2004.
  16. Aug 4, 2014 at 2:58 AM
    #356
    Deuxdiesel
    Deuxdiesel Well-Known Member
    SE MI
    '12 Silver Streak stocker
    I stopped by a local dealer yesterday to browse their used Tacoma selection. First of all, they want stupid money ($26 K) for a '07 90,000 mile A/C in well used condition- others on the lot were similarly (over)priced. There was significant frame corrosion on 3 of the 4, and the 4th had huge chunks flaking off. I even checked under a used FJ and was concerned about it's future. Compared to similar year and mileage Xterra's and Fronty's (which look pretty sound), this is a concern if you are buying a used Tacoma from MI. I will expand my search to drier climates.
  17. Aug 4, 2014 at 6:13 AM
    #357
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    I don't mean to derail the thread, but I just received the "bring in your Tacoma so we can check your frame for rust" letter. I have some surface rust going on, but my biggest concern is that I just had sliders welded on a few months ago. Is that going to affect the way the dealership treats me? I have a picture or two from right before the installation of the sliders showing some surface rust, but nothing too in depth.
    I was thinking I would let them inspect it, and since they (hopefully) won't find anything wrong with it, just let them spray the POR15 or whatever the treatment they're offering is.
    Advice would be appreciated.
  18. Aug 4, 2014 at 7:35 AM
    #358
    vjherrera
    vjherrera Well-Known Member
    Vince
    Chicopee,MA
    Here is my take, if you have an area that has corrosion on it that is no where near where you sliders were welded on then there should not be an issue, however if you they do find something serious within the general vicinity of the welds you know they are going to cover their ass.
    my advice if the sliders were done at a quality shop then bring in all the paperwork to show the dealership that it wasn't done buy a group of guys in their garage drinking beers on the weekend
  19. Aug 4, 2014 at 7:38 AM
    #359
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    First part I agree with, and am hoping that it's the case. Second part is going to be hard to do because it was totally welded in a garage, and there was probably beer involved.
  20. Aug 4, 2014 at 8:20 AM
    #360
    vjherrera
    Vince
    Chicopee,MA
    well hopefully you can get a good working relationship with the dealership and it wont be an issue,
    common sense would say they (the dealership) knows there is a good majority of guys out there who mod their truck in some way shape or form, hell I will bet dollars to donuts that the tech performing the inspection has the same mod as you...but I am sure there are incentives for a good ratio of sprayed to replaced frames from corporation...either way good luck to you
