05+ Official Perforated/Rusted Through Frames
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 30, 2013.
Is your frame perforated/rusted through
  1. Yes, It looks like swiss cheese
    26.4%
  2. Yes, but it's only a little
    73.6%
  1. Aug 4, 2014 at 9:12 AM
    #361
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
  2. Aug 4, 2014 at 12:13 PM
    #362
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    So, are any of you with good frames taking steps to try to keep them that way?
    My 2011's frame still looks flawless, and I'd like to do what I can to keep it that way. Someone suggested spraying it with bedliner. I've just been trying to keep it clean so far.
    My boss's '06 SR5 DCSB looks horrible. Just from what I can see from the sides there is virtually no paint left on the frame. Totally covered in rust. Body is fine. No rust or paint issues there other than some scratches and stuff that it's gotten over the years. He's got an appointment to have Toyota look at it.
    Know another guy who had a Gen 1. Toyota replaced the frame and he was pleased enough that they were doing that that he bought a brand new Tacoma for himself while it was in the shop and gave the Gen 1 to his daughter when the frame was swapped. She's still driving it.
  3. Aug 4, 2014 at 1:03 PM
    #363
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    All the posters from salt and rust free areas like to slather fluid film on things. Personally I think you can put off or slow down the surface rust but the delamination and sandwiched areas are another story.
  4. Aug 4, 2014 at 1:12 PM
    #364
    joshua721
    16 f150 xlt v6
    Also avoid contact or parts swapping with other Tacoma's I bought ruggedt's lift and I think his truck gave mine frame rot...m
  5. Aug 4, 2014 at 1:57 PM
    #365
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Ahh it contagious :rain:
  6. Aug 4, 2014 at 7:32 PM
    #366
    heckeng
    heckeng Active Member
    So are the frames the same as they currently install, or have they done anything to the new ones to prevent this?
  7. Aug 6, 2014 at 1:36 PM
    #367
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    New ones (09 and up I think) are a different frame manufacturer. I think they're still somewhat of an Achilles heel, but not as much as the 05-08s. Read through a few threads and you should get a better idea.
  8. Aug 6, 2014 at 1:37 PM
    #368
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    no rust at all on mine. i've had it for 5 years now.
  9. Aug 6, 2014 at 2:37 PM
    #369
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    No snow - no salt ?
  10. Aug 6, 2014 at 2:38 PM
    #370
    weezer
    southeast
    tacoma 4x4
    snow but not really any salt. i live in alabama. they only salt the bridges when it snows not the roads.
  11. Aug 6, 2014 at 2:40 PM
    #371
    george3
    New Jersey
    No salt - no rust. Toyota even thinks about salt and rusts.
  12. Aug 19, 2014 at 4:50 AM
    #372
    TopShapeCabrio
    TopShapeCabrio Active Member
    Ontario
    07 4x4 TRD Yamaha Edition
    Raider Lo-Rider Elite Tonneau Cover, Weathertech Floor Mats, LED 4x4 Switch, Blu Logic Bluetooth, Toyota Roof Rack
    Got the recall :mad:...2007 Dbl Cab Long Box 4x4 TRD Yamaha Edition with less than 80 000KM!!!
    Oil sprayed EVERY year by a top quality guy...
    If I need a new frame with the LOW mileage and the oil spray, a lot of folks will need one as well...
    I'm in Ottawa, Canada so we have snow and salt. :rolleyes:
  13. Aug 25, 2014 at 11:54 AM
    #373
    meta4
    meta4 Member
    PA
    07 Tacoma OR
    folks that are in NY will need to write to their respective local Attorney General's office to start the litigation process to get the E0D campaign approved in your state.
    in your letter, specifically mention the campaign, your situation, safety concerns, and that your vehicle will not pass inspection with holes in your frame.
    additionally, you should file a complaint with the nhtsa. this will create an investigation into the problem and may warrant further action on the part of Toyota
  14. Aug 25, 2014 at 4:54 PM
    #374
    SixPounder
    SixPounder Member
    Jordan
    Pittsburgh, PA
    05 Tacoma SR5
    Got an email today that they will be completing the recalled frame within the next 6 months! Bout damn time. This is how the phrased it -
    We looked into the frame question on the Tacoma and the good news is help is on the way. Your frame will fall under a limited service campaign LSC-EOD which Toyota has started to roll out in mid May. Toyota has already launched this out in the Boston region with area's being added as availability increases for frames and rust resistant compound. They have not given us an exact date as to when this will begin in our region which is Central Atlantic, but based on past experiences normally it's not beyond six month's. I would encourage you to register your information if you have not at Toyotaowners.com this will insure that any correspondents from the manufacture reach you in a timely manner. I will keep you informed as more information becomes available.
  15. Aug 26, 2014 at 10:17 AM
    #375
    ron wo
    ron wo Member
    r
    willow grove pa
    05 reg cab 4x4
    aftermarket rims
    2005 Tacoma reg cab 4x4with major rust issues. holes is frame. would not pass pa state inspection. what pisses me off the most is the dealers attitude of there's nothing we can do. only 47,000 miles on it. now I have to play the waiting game.
  16. Aug 26, 2014 at 12:31 PM
    #376
    MassEffect
    MassEffect Active Member
    Guarantee you go thru another winter before PA gets this 'fix'.
  17. Aug 29, 2014 at 8:33 PM
    #377
    iiman65
    iiman65 Member
    Greg
    Morton, PA
    2005 Tacoma Crewcab
    Bilstien 2.5 Lift, Borla Catback, ProComp 7028 wheels with 33" Toyo MT's
  18. Aug 29, 2014 at 8:44 PM
    #378
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    This thread is depressing. 47k and rusted out like that. I hope they got their sh*t together with the 2013 frames, but they probably didn't. Sooner or later I'll be in this boat...
  19. Aug 30, 2014 at 11:05 AM
    #379
    weezer
    southeast
    tacoma 4x4
    wow my 2009 has the same mileage and the frame still looks brand new. no rust at all anywhere. i live in the southeast though not the northeast.
    if i saw that i think i would trade my truck in for a nissan frontier.
    at least toyota will replace it with a new frame.
  20. Aug 30, 2014 at 9:33 PM
    #380
    iiman65
    iiman65 Member
    Greg
    Morton, PA
    2005 Tacoma Crewcab
    These frames are rusting from the inside out, I was changing the oil and saw some heavy blisters, pressed my thumb right through it. I went to town with a ballpeen hammer and a cutoff wheel. I FILLED a large ziplock bag with damp rust scale the first time I cleaned it out.
    I was gonna weld it up but what's the point just gonna keep it raw and start emailing the NTSB, if we all join up hopefully we will get the recall.
    Sucks though I love the damn truck just wish the frame wasn't so trash.
