05+ Official Perforated/Rusted Through Frames
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 30, 2013.
Is your frame perforated/rusted through
  1. Yes, It looks like swiss cheese
    26.4%
  2. Yes, but it's only a little
    73.6%
  1. Feb 11, 2015 at 7:04 PM
    #641
    skygear
    skygear                    
    Thats awesome!
    Now my question stands then.
  2. Feb 11, 2015 at 8:07 PM
    #642
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    if your frame pass the inspection and will be sprayed. i would talk to them bout the overspray. when i spray the frames im very careful to avid stuff. cause if it was my truck i would be pissed.
    and if you get a new frame they dont get spayed
  3. Feb 11, 2015 at 8:14 PM
    #643
    skygear
    skygear                    
    This is what I was looking for. Mine will not pass inspection. Not with the amount of material that I I saw fall off. You tap it with anything lightly and the metal fractures and falls off.
  4. Feb 12, 2015 at 2:06 PM
    #644
    Blacktaco2042
    wisconsin
    sounds like a new frame for you
  5. Feb 12, 2015 at 4:49 PM
    #645
    skygear
    skygear                    
    Got the word. I will be the first frame this dealership does. Not the most comfortable about that info... But that also means that they might get a frame quicker than anyone else due to getting the go ahead from Toyota to do the frames. It was told to me that there is an 80 frame backorder right now though. Dealership is still another couple weeks out from getting the OK from the County and all the certs up to par. Then its game on.
    After the inspection, they told me that they needed to get the GM's approval, but said it was not going to be an issue to do so. That was 0830. I called just to verify around 1700 and was told that they wanted to put me in a rental or loaner. Um, I politely declined and was told that the GM would make a decision tomorrow on the Loaner deal. They are not still certified and no official word when a frame will be available. Not really sure I want to be in a loaner for an extended period of time with an open ticket on when i will get mine back. I also said I would take the loner when they got my frame in while the work was done.
    I mean, do they really want me to put 15k-20k on a loaner in the next few months? Treating it like mine, might end up with a lift and 35"s by the time I return it. !!!
    TLDR - > I'm getting a new frame.
  6. Feb 12, 2015 at 8:11 PM
    #646
    Blacktaco2042
    wisconsin
    bring it to wisconsin and ill do it
  7. Feb 12, 2015 at 8:12 PM
    #647
    skygear
    skygear                    
    you got a frame? ;)
  8. Feb 13, 2015 at 3:46 AM
    #648
    Blacktaco2042
    wisconsin
    i currently have 6 frames sitting outside at work that i have to replace and i think ill have a few more in a week or two
  9. Feb 14, 2015 at 5:02 AM
    #649
    FISHSTIX1
    FISHSTIX1 Member
    Ted
    Milford Pa
    TRD
    3" lift ,265/70/16 ,Vision wheels , Leer cap, Yakima kayak racks
    The dealer i'm using in Northern New Jersey has a stack of frames,but no wiring harnesses.They say when the harnesses come in they can do one frame a day.
  10. Feb 14, 2015 at 11:11 AM
    #650
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Two Questions?
    - I "thought" they ordered the Frames with your VIN attached (i.e. the frames are not just off the shelf and can be swapped as wanted?)
    - When you swap the frames are you making decent/more money or just the same as a full day of repairs??
  11. Feb 14, 2015 at 1:54 PM
    #651
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    What wiring harness? I wasn't aware it was a part if the frame
  12. Feb 14, 2015 at 2:39 PM
    #652
    Canufixit
    New England
    Toyota, rightfully in my Opinion, Changes some parts on their nickel to ensure that it's fixed correctly and does not want trucks coming back for electrical problems from a damaged (from road use or frame swap damaged) harness. So they change it when they do the frame swap...
    There are invoices posted in these threads that list the affected parts - although some parts might be part of a "kit" on the invoice.
  13. Feb 14, 2015 at 4:47 PM
    #653
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Mhmmm. Good to hear.
  14. Feb 15, 2015 at 9:50 AM
    #654
    skygear
    skygear                    
    Dayum. Would be nice if I got a current harness so I can eliminate the Camera Wiring I put there myself.
  15. Feb 15, 2015 at 8:23 PM
    #655
    skygear
    skygear                    
    Was offered a 2015 as a loaner. For an indeterminate amount of time.
  16. Feb 16, 2015 at 3:28 AM
    #656
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Tacoma? Or car? Im thinking about doing the loaner deal.
  17. Feb 16, 2015 at 6:45 AM
    #657
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Fishstix -
    I've been waiting since mid Nov in N Jersey my dealer says cant get frames.
    Wounder if my guy is telling truth
  18. Feb 16, 2015 at 7:26 AM
    #658
    FISHSTIX1
    FISHSTIX1 Member
    Ted
    Milford Pa
    TRD
    Tacofish, When I took My Tacoma on Jan 28th to Newton Toyota the service manager told me I needed a new frame which I knew being the welds have disintegrated. I asked how long the wait would be for a frame?And he showed me a stack frames behind the dealership but said he was waiting for wiring harnesses that are hand made and could be 2 to 4 months.????
  19. Feb 16, 2015 at 10:01 AM
    #659
    skygear
    skygear                    
    Tacoma. Said it was the same make/ options. DCSB 4x4 OR V6 Auto Prerunner SR5 TRD etc.
  20. Feb 16, 2015 at 5:53 PM
    #660
    tacofish
    N NJ
    14 ext cab 4x4
    Fishstix-
    I went to Toyota in Little Falls
    Its funny how we're getting to diff answers. Since you saw the stack of frames makes me wonder whats up wit my toyo dealer.
    Did they tell ya what they are replacing at no cost?
