05+ Tacoma 3-leaf pack with Bilstein rear shocks
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by prodigy808, Jan 19, 2013.
  1. Jan 19, 2013 at 3:00 PM
    prodigy808
    prodigy808 [OP] Active Member
    TX
    2011 Tacoma DC, LB TRD Sport 4x4
    Up for sale is a Wheelers HD 3-leaf pack with bilsteins 5100 shocks. Brand new never installed. Asking $300 for everything. Local pickup preferred will ship at buyer expense.
  2. Jan 19, 2013 at 3:21 PM
    jslum
    jslum Well-Known Member
    jason
    SoFL
    sent you a PM
  3. Jan 19, 2013 at 9:40 PM
    marcballz
    marcballz Well-Known Member
    Marc
    Mcallen,Texas
    08 PreRunner SR5 TRD
    Electrical: 24/7 aux pwr, cabin ac outlet, fog light on, 55 watt hids (5k), engine bay lights, dash color swap, led cab/footwell lights, Exterior: air compressor w/ dual tank & dual horns, toolbox, headache rack Audio: pioneer head unity 12" jbl sub , (4) db drive 6x9, 360 db amp, 600 dual amp
    are these the extended rears ment for 3-4 inches?
  4. Jan 20, 2013 at 11:14 AM
    prodigy808
    TX
    Yes these are the F4-BE5-B110-T5 rear shocks meant for use with TSB or 1.5" aal according to DSM website.
    Note for rear shocks:
    Rear shock Part #24-186728 will work with Non-TSB and Non-TSB with a 1" or 1.5" AAL.
    24-186728 Dimensions:
    Extended Length: 22.94"
    Collapsed Length: 14.02"
    Rear Shock Part # RCD/Bilstein BE5-B110-T5 will work with TSB and 1.5" AAL or a 3" to 4" lift as stated.
    BE5-B110-T5 Dimensions:
    Extended Length: 27.28"
    Collapsed Length: 16.34"
    When running the RCD/Bilstein BE5-B110-T5 you may need to modify your bump stops so that the suspension does not bottom out on the shock.Also due to the longer extended length of the shock a longer rear brake-line is recommended.
  5. Jan 20, 2013 at 1:29 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    Where in TX are you located?
  6. Jan 21, 2013 at 11:38 AM
    prodigy808
    TX
    Abilene
  7. Jan 21, 2013 at 1:53 PM
    IluvTEA
    South Dakota
    Same here. Now I have some thinking to do.
  8. Mar 4, 2013 at 5:09 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
  9. Mar 4, 2013 at 5:47 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Care to sell the shocks separate?
  10. Mar 5, 2013 at 6:42 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    If you sell the shocks seperate, and are near DFW, I'd take the leafs.
  11. Mar 5, 2013 at 5:09 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Sounds good to me...
  12. Mar 5, 2013 at 11:40 PM
    selfmade
    selfmade Well-Known Member
    DC
    SO CAL
    BLUE BEAST
    everything....
    ill take the shocks for sure if you get separate!!
  13. Mar 6, 2013 at 4:01 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    Wait in line.... :boink:
    lol
