05 Tacoma SAC and 4.7 V8 Swap
Discussion in 'Solid Axle Suspension' started by canadian bum, Nov 11, 2017.
  1. Nov 11, 2017 at 6:51 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Ouch. Glad you're ok and rebuilding!
  2. Nov 11, 2017 at 6:54 PM
    canadian bum
    canadian bum [OP] Well-Known Member
    Alberta, Canada
    2005 SAC DCLB
    Spacer lift with 42s
    Thanks yeah I was initially attempting the rebuild but just decided it was too far gone in requirement for parts and repairs and started fresh on this truck. Still have the old one but it's pretty stripped. Just a parts rig now.
    SoCOTaco[QUOTED] likes this.
  3. Nov 11, 2017 at 7:00 PM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    I love a good frankenbuild . Curious as to your process for welding the cast. Lots of pre heat, missle rod, peen, cool slow. Anyway, love builds like this.
  4. Nov 11, 2017 at 7:08 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Pirate is still good, but the Tacoma section there is a little dead, but it's been that way for years. I'm on that forum the most still
  5. Nov 11, 2017 at 7:08 PM
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    Normally I handle my own welding but I'm calling in a friend who is a welder to do this. He liked how it reacted to a spark test which makes it better for welding.
  6. Nov 11, 2017 at 7:15 PM
    deog
    snicklefritz
    work in progress
    The cast has a lot of carbon, this is what makes it hard to accept a good weld to steel like 4130. You must preheat the cast to between 4 and 600 degrees, then keep constant heat on the material. Special rod and someone that knows how to tig very well. Peen the weld to take out the stress, and cool as slowly as possible. It is a science. I had a truss break away from the center section in a Dana 60, after that, I left that work to those who know what they are doing, and even then , it is not a exact science.
    Good luck.
    Torspd and canadian bum[OP] like this.
  7. Nov 11, 2017 at 8:17 PM
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    I left the housing bare for that reason I knew there would be some heat involved with the welding process and didn't to have cooked bearings/carrier and puddles of melted rubber for seals haha.
    Torspd likes this.
  8. Nov 12, 2017 at 7:40 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    What vehicle did your 05 engine come out of and did you buy a donor vehicle?
  9. Nov 12, 2017 at 7:49 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Subbed for this
  10. Nov 12, 2017 at 8:21 AM
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    Came out of a 2005 tundra with complete drivetrain so I have a spare trans and tcase. I don't have the actual truck though.
    Holloman likes this.
  11. Nov 12, 2017 at 11:04 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    So on the previous truck you had your front spring hanger attaced to the bumper? Looks that way from the pic. Just curious about it 'cause I have never seen a build like that.
  12. Nov 12, 2017 at 3:12 PM
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    Nope definitely not to the front bumper. The cross member for the front of the frame dropped perfectly to make spring hangers. I just reinforced it all.
    malburg114 likes this.
  13. Nov 14, 2017 at 8:56 AM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Got any more pics and details on the leafs set up? I’m prolly gonna sas in a few years and am thinking of doing leafs for the simplicity and cost. Seems like everybody else does 3 link and coilovers.
  14. Nov 18, 2017 at 5:34 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Cool. I guess the pics fooled me :D
    It's really a matter of personal preference when it comes to leafs vs links. They both have pros and cons.
    Either way is gonna be a shit ton of work and expensive. If you do a SAS right it will cost a ton of money regardless of what suspension you go with.
    nfs257 likes this.
  15. Nov 18, 2017 at 7:09 AM
    #35
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    I have lots of pics and detail on the first swap on leaf springs. And it wasn't actually too expensive all said and done. Some of the negatives about it where it had a little bit of axle wrap at times. And I needed a long spline shaft, the stock slip would sometimes separate under high flex and a little spinning. For those interested in the first truck just PM I'd like to keep these builds separate.
    Now onto more details about this build I ordered up some 4 inch McNeil fenders and bedsides yesterday at an attempt to avoid being hassled by cops. They currently have a 15% off sale so I couldn't pass it up being i was planning on getting them at some point.
    nfs257 and Holloman like this.
  16. Nov 18, 2017 at 7:24 AM
    #36
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  17. Nov 19, 2017 at 1:25 AM
    #37
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Consider going with the Advanced sale. I was very unhappy with what I got product wise and customer service wise with this sale last year.
    Besides that, McNeil almost always does 25% starting Wednesday or Thursday.
  18. Nov 19, 2017 at 2:34 AM
    #38
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    What was so bad about your experience with McNeil? Would like details on what was disappointing about the quality of the product.
  19. Nov 19, 2017 at 4:05 AM
    #39
    Hawk373
    2012 TRD Sport DCLB
    The thickness of the fenders and bedsides is not completely reinforced with fiberglass. They must lay up resin in the mold to about half the thickness and then a very thin layer of glass.
    They use an absurd amount of blue body filler to cover up the warping and incomplete layup/breakage. The front piece that wraps under the headlight was just a 1/4" thick blob of blue filler that fell off when I was trying to attach the adjoining plastic as just one instance. The tabs that are supposed to screw down along with the head light tabs were nonexistent on one side, I had to glass in my own tabs back around the door hinge. They paint the inner fenders black to cover up all their tricks and all the blue filler is sprayed with a cheap with spray paint that reminds me of kilz. The bedsides also do not come with the forward section that attaches to the bed requiring custom fabrication (not bolt on like other brands). The bed sides hang too far over the inner rail and I had to just cut that entire lip flush with the inner bed to allow the rail to be reattached. The rear tail lights fit very poorly.
    Not to mention they never told me they shipped, UPS Freight didn't tell me they arrived and they sat for three weeks. The packaging was minimal at best to travel across the country and the one bedside was crushed. They only offered $100 off to repair myself or to refuse the shipment and have a new side molded and returned. I opted for the latter. They then agreed to send me an entirely new set while that one was on the return and I even offered to be charged for the second set until the damaged one made it back. They reneged on that promise and almost two weeks later said they had finally arranged for the old shipment to be sent back and at that point would mold me a new bedside. I didn't want to argue and conceded, but stressed that this had been going on a long time and I was shortly going on TDY with the Army. They assured it would arrive in time. Well, this time around I got a tracking notification and a call from UPS. I went to inspect at the terminal and it was the same exact bed side. They had smeared some blue filler on and spray painted. It of course was rebroken and I noticed even more damage in another area.
    I called them immediately and was given more excuses. I was promised a new bedside shipped greyhound free of charge. Sounded good to me... sucker. They never sent anything but an invoice a day later. I went on TDY and started a dispute process which of course got their attention and won.
    I read a few instances where their war of attrition with dissatisfied customers has prevailed. It's usually someone like us who lives far away. I assume that's their opportunity to push off the glass that no one local would pay for and if things get damaged, most people give up before long. I have extensive photo documentation including the repairs needed, the coverups and poor quality of glassing.
    While doing the repairs it became apparent the bedside was previously damaged (and probably returned) because they had glassed over their black coverup paint on the inside in a number of places. Let me know if you want photos or more elaboration, emails, etc.
  20. Nov 19, 2017 at 4:19 AM
    #40
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    Do the advanced bedsides allow for a topper if desired? I might try and cancel my order...
