05+ TRD wheels on an 02?
Discussion in 'Wheels & Tires' started by boatillo, Jul 24, 2008.
  1. Jul 24, 2008 at 8:19 AM
    boatillo
    boatillo [OP] Member
    I have some plain 16x7J steelies on my 02 Tacoma (4x4, 4cyl) that aren't looking so hot and missing 2 center caps, so...
    http://i55.photobucket.com/albums/g136/pattycakes77/4runner/TacomaWheels.jpg
    I know these wheels are also 16x7J with the 6 bolt 5.5" pattern, but I do not have any information on backspacing. I want to transfer my current tires which are still in good shape over to these - will they bolt right up no problem? Might they rub anything?
  2. Jul 24, 2008 at 8:40 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    I'm not sure about the 16x7, but I had the stock 2008 TRD Sport wheels (17" - 6 by 5.5 bolt pattern) and gave them to my buddy who has a 98 Tacoma. They fit his truck perfectly.
  3. Jul 24, 2008 at 9:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    those should work just fine. if you did a lift and all, you may need spacers, but with the current setup, you should be ok!
  4. Jul 25, 2008 at 7:10 AM
    boatillo
    So the backspacing is the same on both wheels? There is only about 0.5-1" clearance between my 265/70/16 tire and the upper control arm.
  5. Jul 25, 2008 at 7:14 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats the only thing im not too sure of is the back spacing.....but if you leave 265/70's on their, you'll probably be fine. do you have a dc or ac?? i have heard that those wheels will work on a reg. cab or an ac, but not too good on a dc without a spacer........with the size of 265/75/16, so i think you will be fine.
  6. Jul 25, 2008 at 7:43 AM
    boatillo
    I have the access cab, everything is stock on the suspension.
    Hah, I need to try and find one of these rims in RL and just try mounting it for clearance check!
  7. Jul 25, 2008 at 7:46 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think they will fit fine, but it would be a wise decision to make totally sure before you buy them.
