06 4x4 help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stumeister, Feb 13, 2008.
  1. Feb 13, 2008 at 9:26 AM
    Stumeister
    Stumeister [OP] Carolina Alliance: Dirty South Division
    06 PreRunner sr5 4x4
    I am a complete noob when it comes to knowing about truck stuff. So anyways I was out mudding today after it finally rained to have a little fun. I decided to put it in 4 wheel drive to see what my taco could do. So I put it in 4x4 and take off towards this puddle. I hit the puddle and water splashed up over the truck.
    I am going a little fast so I tap on the breaks......but I can't push them in. I had to push down pretty hard and it sounded kinda bad when I was pressing them in. Finally they worked fine after the truck slowed down a little more. Am I just an idiot or what is going on??? I then took the truck out of 4x4, tested it out, put in back in, and now everything seems to be going fine. What did I do wrong.
    By the way I have an auto transmission
  2. Feb 13, 2008 at 9:57 AM
    Tacoma_CT
    Tacoma_CT Active Member
    Bristol CT
    06 Tacoma Double Cab 4x4 with TRD Sp
    True Flow XDI Air Intake, Borla exaust, Hunter brush gaurd, Hunter nurf bars, Toyota Roof rack Comming SOON.. Glass works fenders
    probly water in between the breaks i have the same problem when i powerwash my truck or theres a lot of snow it goes away after a couple seconds i dont think its your 4x4 but im not an expert hope this helps
    Tacoma_CT
  3. Feb 13, 2008 at 9:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If I had to guess... it's probably because your brakes were wet. Takes more pressure (so to speak) to squeeze down on 'em, get the water off, and effectively work like when they're dry.
  4. Feb 13, 2008 at 2:07 PM
    Steve-B
    Steve-B Member
    1997 GMC Sierra
    I agree - probably wet brakes. The noise was probably the antilock system.
    Take that with a grain of salt - I'm not a mechanic, nor a Tacoma owner (yet).
